Is is true or can it be that the AC protocol aint working anymore on 1003 ext2 firmware?
Flashed it two times to day and all my kaku ac modules aren't reacting when i give then commands via Domoticz.
If i flash 1003 ext then those modules are working.
Can't find or i must have missed it any reference about this issue.
RFXtrx433E 1003 ext2 ac protocol aint working
- Starting Member
Hardware:
RasPi B2 - RFXtrx433E
1x Youless ls110
2x Opus XT300 - Temp/Hum
4x Cresta TX320 - Temp/Hum
25x KaKu switches
1x KaKu Dusk Sensor
10x KaKu Contacts
4x KaKu AWST-6000 PIR
1x Selectplus Chime
4x KD101 smoke detectors
DIY Garden Irrigation
1x Youless ls110
25x KaKu switches
1x KaKu Dusk Sensor
10x KaKu Contacts
1x Selectplus Chime
- b_weijenberg
Re: RFXtrx433E 1003 ext2 ac protocol aint working
this should be solved in version 1004 which is on the download page now.
- Starting Member
thx for the quick fix...b_weijenberg wrote:this should be solved in version 1004 which is on the download page now.
Hardware:
1x Youless ls110
25x KaKu switches
1x KaKu Dusk Sensor
10x KaKu Contacts
1x Selectplus Chime
1x Youless ls110
25x KaKu switches
1x KaKu Dusk Sensor
10x KaKu Contacts
1x Selectplus Chime
