Page 9 of 55
Re: Rooting Toon (or boxx)
Posted: Sat Aug 05, 2017 4:21 pm
by bwbboot
Nice. Thanks Marcel!
Posted: Sat Aug 05, 2017 4:31 pm
by marcelr
Nice!, in the Etelka font. Looks better than the new one.
Posted: Sat Aug 05, 2017 5:08 pm
by bwbboot
Marcel did you use a special gimp plugin for editing the framebuffer raw image? Can's seem to get the image recnogized using GIMP for OSX.
Posted: Sat Aug 05, 2017 5:13 pm
by marcelr
Not that I can remember. You should read the framebuffer file as a raw image, and then set size (800*48) and format (RGB or BGR). I pretty quickly got fed up with that, so I wrote a matlab script to convert the raw images to BMP and back. Made life a lot easier. If you happen to have matlab (which is unlikely) , I'll be happy to send you the script.
Re: Rooting Toon
Posted: Sat Aug 05, 2017 5:58 pm
by Billybob
Manyakim wrote:Hello, unfortunately no progress has been accomplished from my side yet.
Im still stuck at the booting process and i can't even do a reset to boot my Toon.
If you have any information on resetting Toon to his original setting(or better, rooting FW 2010.9-R10), please let me know.
U-Boot 2010.09-R10 (Dec 14 2015 - 19:28:18)
CPU:   Freescale i.MX27 at 400.168 MHz
Prodrive B.V. ED2.0
DRAM:  128 MiB
NAND:  128 MiB
LCD: 800x480, pbb 4
LCD: Drawing the logo...
In:    serial
Out:   serial
Err:   serial
Configure for LCD: TDA-WVGA0700F00048
LCD: 800x480, pbb 4
Display-bmp: 800 x 480  with 16777216 colors
Net:   FEC
Address in SROM is         00:00:20:03:00:00
Address in environment is  00:0f:11:07:05:8a
Enter password - autoboot in 2 sec...
NAND read: device 0 offset 0x300000, size 0x300000
 3145728 bytes read: OK
## Booting kernel from Legacy Image at a1000000 ...
   Image Name:   Linux-2.6.36-R10-h23
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2210272 Bytes = 2.1 MiB
   Load Address: a0008000
   Entry Point:  a0008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.36-R10-h23 (jbraam@dvl) (gcc version 4.5.3 20110223 (prerelease) (GCC) ) #1 PREEMPT Mon Dec 14 13:05:57 CET 2015
CPU: ARM926EJ-S [41069264] revision 4 (ARMv5TEJ), cr=00053177
CPU: VIVT data cache, VIVT instruction cache
Machine: Prodrive B.V ED2.0
Memory policy: ECC disabled, Data cache writeback
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32512
Kernel command line: ubi.mtd=4 root=ubi0:rootfs rw rootfstype=ubifs mtdparts=mxc_nand:512K@0x00100000(u-boot-env)ro,1536K(splash-image),3M(kernel),3M(kernel-backup),119M(rootfs) console=ttymxc0,115200 mem=128M lpj=999424 lcd=TDA-WVGA0700F00048
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB = 128MB total
Memory: 125596k/125596k available, 5476k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xffa00000 - 0xffe00000   (   4 MB)
    vmalloc : 0xc8800000 - 0xf4000000   ( 696 MB)
    lowmem  : 0xc0000000 - 0xc8000000   ( 128 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .init : 0xc0008000 - 0xc0024000   ( 112 kB)
      .text : 0xc0024000 - 0xc03dd000   (3812 kB)
      .data : 0xc03f6000 - 0xc041bec0   ( 152 kB)
Hierarchical RCU implementation.
        RCU-based detection of stalled CPUs is disabled.
        Verbose stalled-CPUs detection is disabled.
NR_IRQS:272
MXC IRQ initialized
MXC GPIO hardware
Console: colour dummy device 80x30
Calibrating delay loop (skipped) preset value.. 199.88 BogoMIPS (lpj=999424)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
Configured for LCD: TDA-WVGA0700F00048
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource mxc_timer1
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
msgmni has been set to 245
io scheduler noop registered (default)
Serial: IMX driver
imx-uart.0: ttymxc0 at MMIO 0x1000a000 (irq = 20) is a IMX
console [ttymxc0] enabled
imx-uart.1: ttymxc1 at MMIO 0x1000b000 (irq = 19) is a IMX
imx-uart.2: ttymxc2 at MMIO 0x1000c000 (irq = 18) is a IMX
NAND device: K9F1G08U0E detected, disabling sub-page writes
NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit)
Scanning device for bad blocks
RedBoot partition parsing not available
5 cmdlinepart partitions found on MTD device mxc_nand
Creating 5 MTD partitions on "mxc_nand":
0x000000100000-0x000000180000 : "u-boot-env"
0x000000180000-0x000000300000 : "splash-image"
0x000000300000-0x000000600000 : "kernel"
0x000000600000-0x000000900000 : "kernel-backup"
0x000000900000-0x000008000000 : "rootfs"
UBI: attaching mtd4 to ubi0
UBI: physical eraseblock size:   131072 bytes (128 KiB)
UBI: logical eraseblock size:    126976 bytes
UBI: smallest flash I/O unit:    2048
UBI: VID header offset:          2048 (aligned 2048)
UBI: data offset:                4096
UBI: max. sequence number:       351
UBI: attached mtd4 to ubi0
UBI: MTD device name:            "rootfs"
UBI: MTD device size:            119 MiB
UBI: number of good PEBs:        952
UBI: number of bad PEBs:         0
UBI: max. allowed volumes:       128
UBI: wear-leveling threshold:    4096
UBI: number of internal volumes: 1
UBI: number of user volumes:     1
UBI: available PEBs:             0
UBI: total number of reserved PEBs: 952
UBI: number of PEBs reserved for bad PEB handling: 9
UBI: max/mean erase counter: 1/0
UBI: image sequence number:  2044689730
UBI: background thread "ubi_bgt0d" started, PID 319
at25 spi0.0: 32 KByte at25640B eeprom, pagesize 64
spi_imx spi_imx.0: probed
FEC Ethernet Driver
fec_enet_mii_bus: probed
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
mxc-ehci mxc-ehci.0: initializing i.MX USB Controller
mxc-ehci mxc-ehci.0: portsc setup 1: 0x80000000
mxc-ehci mxc-ehci.0: Work around for USB enabled
ULPI transceiver vendor/product ID 0x0424/0x000d
mxc-ehci mxc-ehci.0: Freescale On-Chip EHCI Host Controller
mxc-ehci mxc-ehci.0: new USB bus registered, assigned bus number 1
mxc-ehci mxc-ehci.0: irq 56, io mem 0x10024000
mxc-ehci mxc-ehci.0: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: Freescale On-Chip EHCI Host Controller
usb usb1: Manufacturer: Linux 2.6.36-R10-h23 ehci_hcd
usb usb1: SerialNumber: mxc-ehci.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mxc-ehci mxc-ehci.2: initializing i.MX USB Controller
mxc-ehci mxc-ehci.2: portsc setup 1: 0x80000000
mxc-ehci mxc-ehci.2: Work around for USB enabled
mxc-ehci mxc-ehci.2: Freescale On-Chip EHCI Host Controller
mxc-ehci mxc-ehci.2: new USB bus registered, assigned bus number 2
mxc-ehci mxc-ehci.2: irq 55, io mem 0x10024400
mxc-ehci mxc-ehci.2: USB 2.0 started, EHCI 1.00
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: Freescale On-Chip EHCI Host Controller
usb usb2: Manufacturer: Linux 2.6.36-R10-h23 ehci_hcd
usb usb2: SerialNumber: mxc-ehci.2
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver usbserial
usbserial: USB Serial Driver core
input: TSC2007 Touchscreen as /devices/virtual/input/input0
rtc-isl1208 1-006f: chip found, driver version 0.3
rtc-isl1208 1-006f: rtc core: registered rtc-isl1208 as rtc0
i2c /dev entries driver
tmp431 0-004c: Could not read configuration register (-5)
imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
adt7410 0-0048: adt7410 temperature sensor registered.
adt7410 0-0049: adt7410 temperature sensor registered.
nf_conntrack version 0.5.0 (1962 buckets, 7848 max)
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP cubic registered
NET: Registered protocol family 10
ip6_tables: (C) 2000-2006 Netfilter Core Team
NET: Registered protocol family 17
lib80211: common routines for IEEE802.11 drivers
rtc-isl1208 1-006f: setting system clock to 2011-01-01 08:20:26 UTC (1293870026)
uifh oias;
sUBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: file system size:   117833728 bytes (115072 KiB, 112 MiB, 928 LEBs)
UBIFS: journal size:       9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
UBIFS: media format:       w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root:  0 bytes (0 KiB)
VFS: Mounted root (ubifs filesystem) on device 0:13.
Freeing init memory: 112K
usb 2-1: new high speed USB device using mxc-ehci and address 2
INIT: version 2.86 bootingusb 2-1: New USB device found, idVendor=148f, idProduct=5370
usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 2-1: Product: 802.11 n WLAN
usb 2-1: Manufacturer: Ralink
usb 2-1: SerialNumber: 1.0
Enter runlevel: 2-1
Enter runlevel: 2-0
Enter runlevel: 2
INIT: Entering runlevel: 2
INIT: no more processes left in this runlevel
Prodrive B.V. ED2.0
DRAM:  128 MiB
NAND:  128 MiB
LCD: 800x480, pbb 4
In:    serial
Out:   serial
Err:   serial
LCD: 800x480, pbb 4
Net:   FEC
OK
Starting kernel ...
NR_IRQS:272
MXC IRQ initialized
MXC GPIO hardware
TCP reno registered
Serial: IMX driver
UBI: max. sequence number:       353
FEC Ethernet Driver
rtc-isl1208 1-006f: setting system clock to 2011-01-01 08:21:39 UTC (1293870099)
Enter runlevel:
While I was working on things the same happened to me and I was able to solve it.
If your booting process ends with "enter runlevel:" just after the USB boot, there is a problem with your inittab. If you press 5 and it continues, you're missing the "id:5:initdefault:" line. If nothing works, most likely your whole inittab is empty.
So this is how you solve it:
1. Get into UBoot like in the rooting manual
2. Like the rooting process enter this line: "setenv addmisc setenv bootargs \$\{bootargs\} mem=\$\{mem\} lpj=999424 init=/bin/sh"
3. Then enter "run boot_nand"
4. Wait till it is done and go to etc/inittab. If the file is empty, copy the content back in and save. If you don't have a copy try mine. Be aware, openVPN is disabled and no VNC respawn is in it.
si::sysinit:/etc/init.d/rcS
# What to do in single-user mode.
# /etc/init.d executes the S and K scripts upon change
# of runlevel.
# Runlevel 0 is halt.
# Runlevel 1 is single-user.
# Runlevels 2-5 are multi-user.
# Runlevel 6 is reboot.
l0:0:wait:/etc/init.d/rc 0
l1:1:wait:/etc/init.d/rc 1
l2:2:wait:/etc/init.d/rc 2
l3:3:wait:/etc/init.d/rc 3
l4:4:wait:/etc/init.d/rc 4
l5:5:wait:/etc/init.d/rc 5
l6:6:wait:/etc/init.d/rc 6
# Normally not reached, but fallthrough in case of emergency.
z6:6:respawn:/sbin/sulogin
# HCBv2 static stuff
#ovpn:235:respawn:/usr/sbin/openvpn --config /etc/openvpn/vpn.conf --verb 0 >/dev/null 2>&1
qtqt:245:respawn:/usr/bin/startqt >/dev/null 2>&1
gett:235:respawn:/sbin/getty -L 115200 ttymxc0 vt102
# WARNING: auto-managed by '/etc/init.d/HCBv2 inittabwrap' with '/HCBv2/etc/start.d/*'
#          lines containing 'inittabwrap' will be removed automagically.
netc:235:respawn:/etc/init.d/HCBv2 inittabwrap hcb_netcon
comm:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_comm
even:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_eventmgr
kpik:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_kpi
pwru:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_pwrusage
scsy:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_scsync
smar:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_smartplug
ther:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_thermstat
user:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_usermsg
weat:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_weather
bxtp:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_bxtproxy
Posted: Sat Aug 05, 2017 6:50 pm
by bwbboot
marcelr wrote:Not that I can remember. You should read the framebuffer file as a raw image, and then set size (800*48) and format (RGB or BGR). I pretty quickly got fed up with that, so I wrote a matlab script to convert the raw images to BMP and back. Made life a lot easier. If you happen to have matlab (which is unlikely) , I'll be happy to send you the script.
Thanks that got me started! Had to rename the extension to .data and change the size to 800*480, its BGR. Interestingly the images will show up in blue in GIMP but are displayed in orange on Toon. Anyway, all images are displayed as it had should have been out of the box :D :D
Posted: Sun Aug 06, 2017 11:51 am
by mAiden
First: Thanks Marcel for youre support and help.. Finally found manual.
I gonna try root Toon with this:
https://www.aliexpress.com/item/1pcs-lo ... 0.0.KLsEJu
Hope that's work, but I think so. Is a Raspberry necessary, or is it possible with a desktop?
Posted: Sun Aug 06, 2017 11:58 am
by marcelr
I wouldn't, if I were you. It's a 5V device, whereas toon is a 3.3V logic level device. Try and find one with a 3.3V signal level, instead of the 5V of this one.
The tools you need depend on the bootloader version of your toon. Up to R8, a serial interface connected to a desktop computer (like this one, but with 3.3V signal level) will do. From R10 and possibly onwards, you will need JTAG hardware, which can be emulated with a raspi.
Posted: Sun Aug 06, 2017 12:47 pm
by Toonz
mAiden,
you will need this to connect your raspberry Pi (GPIO pins providing serial port) to Toon for rooting (just need 3 wires).
Raspberries serial port is already 3.3V.
https://ae01.alicdn.com/kf/HTB1cCMjJVXX ... 40x640.jpg
Posted: Sat Aug 12, 2017 5:53 pm
by pkaak
My Toon is rooted with (a lot of) help of a member here.
Now I noticed that my old Toon connected to Eneco have an option at the 'meters' in the settings to select the time for the low rate (daluren).
That is gone in the one that is rooted.
If I remembered correctly that options also was shown in the graphs.
Is there a way to get that back?
Posted: Sun Aug 13, 2017 1:44 pm
by marcelr
Just a wild guess: Is your toon connected to the service center? If not (anymore), it could be that this low/high tariff information is taken from Eneco. After all, it has to do with the type of contract that you have.
Posted: Fri Aug 18, 2017 9:45 am
by pkaak
marcelr wrote:Just a wild guess: Is your toon connected to the service center? If not (anymore), it could be that this low/high tariff information is taken from Eneco. After all, it has to do with the type of contract that you have.
Toon is disconnected from Eneco. But in the one that is still connected it shows up in the GUI at the meter-config screen. That one will be going offline in october as I stopped my contract with Eneco. Will see if it will be gone from the GUI after that on that Toon too.
Posted: Fri Aug 18, 2017 3:47 pm
by Nielsch
Oops, should have been rejected, not English.
please try again.
Posted: Fri Aug 18, 2017 4:23 pm
by Nielsch
Sorry, didn't notice :oops:
Some time ago I bought this: https://nl.aliexpress.com/item/1pcs-CP2 ... 0.0.kXk4zF
Can I use this to root my Toon, or is it a risk to try it?
I connected it to a USB port and measured 3.3V on TXD and RXD with a multimeter.
Posted: Fri Aug 18, 2017 4:30 pm
by marcelr
In that case, it should work, if your OS supports it.
