P1 "Object reference not set to an instance of an object"
Posted: Thu Jun 23, 2016 4:45 pm
I just installed my Smile P1 running firmware version 2.1.13, and am getting the expected data on the Smile's web page. However, in Homeseer 3 (Linux version 3.0.0.208) using the Plugwise Pro plug-in (version 3.0.3.0) I'm not seeing any data from the P1.
The HS log does show that the plug-in is connecting to the P1, but then runs into an error:
I do not have a gas meter, so my Smile only reports electricity data (/core/modules):
Could that be the problem? Or does anyone else have any idea what the cause of the error could be?
Thanks,
Marc
Jun-23 16:30:08 Plugwise Pro Smile P1 error 2 reading data: Object reference not set to an instance of an object
Jun-23 16:30:08 Plugwise Pro Smile P1 information retreivement -- Smile P1 vendor model = Kaifa
Jun-23 16:30:08 Plugwise Pro PollSmileP1: Query=http://192.168.2.2/core/modules
Jun-23 16:30:08 Plugwise Pro Smile P1 information retreivement -- Smile P1 firmware = 2.1.13
Jun-23 16:30:01 Plugwise Pro PollSmileP1: Query=http://192.168.2.2/update/firmware
<?xml version="1.0" encoding="UTF-8"?>
<modules>
<module id='1568335aa844438cae0bb8195365d41b'>
<vendor_name>Kaifa</vendor_name>
<vendor_model>KFM5KAIFA-METER</vendor_model>
<hardware_version></hardware_version>
<firmware_version></firmware_version>
<created_date>2016-06-23T14:51:20.275+02:00</created_date>
<modified_date>2016-06-23T16:30:59.331+02:00</modified_date>
<deleted_date></deleted_date>
<services>
<electricity_interval_meter id='7d8b5feca9a44d8e9ef45ccc7a1064cd'>
<measurement log_date='2016-06-23T16:00:00+02:00' unit='Wh' interval='PT300S' directionality='produced' tariff_indicator='nl_offpeak'>0.000</measurement>
<measurement log_date='2016-06-23T16:00:00+02:00' unit='Wh' interval='PT300S' directionality='produced' tariff_indicator='nl_peak'>0.000</measurement>
<measurement log_date='2016-06-23T16:00:00+02:00' unit='Wh' interval='PT300S' directionality='consumed' tariff_indicator='nl_offpeak'>77.000</measurement>
<measurement log_date='2016-06-23T16:00:00+02:00' unit='Wh' interval='PT300S' directionality='consumed' tariff_indicator='nl_peak'>0.000</measurement>
</electricity_interval_meter>
<electricity_cumulative_meter id='3228e520b4744bf7a587769f0546bc32'>
<measurement log_date='2016-06-23T16:25:00+02:00' unit='Wh' directionality='produced' tariff_indicator='nl_offpeak'>0.000</measurement>
<measurement log_date='2016-06-23T16:25:00+02:00' unit='Wh' directionality='produced' tariff_indicator='nl_peak'>0.000</measurement>
<measurement log_date='2016-06-23T16:25:00+02:00' unit='Wh' directionality='consumed' tariff_indicator='nl_offpeak'>510.000</measurement>
<measurement log_date='2016-06-23T16:25:00+02:00' unit='Wh' directionality='consumed' tariff_indicator='nl_peak'>0.000</measurement>
</electricity_cumulative_meter>
<electricity_point_meter id='446ff3f048394306a0ef09e00f13a172'>
<measurement log_date='2016-06-23T16:30:49+02:00' unit='W' directionality='produced'>0.000</measurement>
<measurement log_date='2016-06-23T16:30:49+02:00' unit='W' directionality='consumed'>268.000</measurement>
</electricity_point_meter>
</services>
<protocols>
<dsmrmain id='e1ba0a7df7e74ec1931c7d2d6550580b'>
<serial>E0025000042349615</serial>
<dsmrmbuses>
</dsmrmbuses>
</dsmrmain>
</protocols>
</module>
</modules>
Thanks,
Marc
