ive got the Webeye B101 now for a few weeks, with my Bosch Dinion XF cam on it.
but i would like to publish the image that comes from the Webey on my website.
i tried ( in dutch )
a:Bron weergeven
b:plakken in pagina van de site.(niet de hele bron )
then i tried look at the site , i saw the border of the images ( size etc, but the image stayed on loading...
so any ideas?
kindly regards, Erwin.
Losmandy G-11 | eos 1D 1+ | 350D 1+ | LX90 8'' | SV 102 apo | lenzen |
Eneo cam | Bosch Dinion XF kleur camera | en opzoek naar ip cam
publishing Webey image
Moderator: Esteban
I too saw the same border at first. if you check the top of the web page you should see a prompt asking you to install an activeX control. Once installed the camera comes on line and looks fine
Hello Ray,
i mean, that i want to publish just the image that is genarated, so that i can show it to other people without logging in.
regards, Erwin
regards, Erwin
You can have the WebEye periodically upload it's image to a webserver. You can incorporate it in your webpage, but unfortunately the WebEye plug-in is still required to display the image correctly in your browser because it's compressed with the WaveLet coded. I'm still working on a good solution for that, because I want to the the same.
