Smoke detector
Posted: Mon Nov 21, 2016 8:00 pm
by stefxx
Hi!
I am looking for (2 or 3) smoke detectors. The requirements are:
- 220v with backup battery
- Connect to HomeSeer HS3 (using Z-Wave or RFXCom)
A matching CO detector would make it even better
Any suggestions? Quality is important, but so is price...
Re: Smoke detector
Posted: Mon Nov 21, 2016 9:15 pm
by mlamie
Probably the Popp sensor is the best you can get with Z-wave. Special note, it can also be used as alarm (you can trigger the siren). I have seen Mertens smoke sensors with z-wave, but I don't know if they share there device specifics to others.
So please check the compatibility for HS3.
Check all the z-wave smoke sensor products
products.z-wavealliance.org/Search/Inde ... Text=smoke
433mhz is probably cheaper.
Re: Smoke detector
Posted: Mon Nov 21, 2016 10:09 pm
by Akatar
perhaps nest? there is a hs3 plugin
Re: Smoke detector
Posted: Tue Nov 22, 2016 10:33 am
by stefxx
Thanks.
I can only find the "Smoke Sensor / Siren (004001)" Popp sensor for ca. 70 euros. And that is without an "optional AC adapter" that costs ca. 20 euros. I bit more than I am willing to spend on a smoke detector.
The nest is even more expensive, but it does include CO detected which is great. Something to think about.
I keep looking... thanks again!
Re: Smoke detector
Posted: Wed Nov 23, 2016 6:47 am
by jeroenc
Be aware that since CO is heavier then air a CO sensor needs to be installed low near the floor, where a smoke detector needs to be installed high.
Any tips for a Domotica proof separate CO sensor?
Verzonden vanaf mijn iPhone met Tapatalk
