Somfy Connexoon anyone?
Posted: Sat Feb 25, 2017 7:24 pm
Somfy dealers are (more and more) promoting the IO Homecontrol Somfy motors instead of the older Somfy RTS motors. Since the quest in the automation world to smarthack/reverse engineer the protocol is ever ongoing, I'm hoping for a workaround (other than one that involves soldering remotes)
Does anyone might have a Connexoon? Since it's using (apparently 3 different) apps to communicate, there must be an API we can (ab)use?
Might be an alternative for the more expensive Somfy Tahoma.
Any thoughts? Suggestions?
