Toon app: ToonStore
Re: Toon app: ToonStore
Postby Toonz » Sun Dec 09, 2018 7:51 pm
Hi, you are using a resource file for Toon 2 (which has a higher screen resolution).
Download the correct resource file for your firmware version here: http://qutility.nl/resourcefiles/
(use the resources-qb2.... ones, which are for Toon 1)
Extract the zip file and put the two rcc files in /qml/qmf
Postby Templar » Wed Dec 19, 2018 12:05 am
There is a problem with the Changelog screen with the calendar app. It isn't possible to correctly scroll down.
Using Toon 1 FW 4.22.7 - Toonstore 2.0.2 - TSC 1.3.2
Templar
Postby Toonz » Wed Dec 19, 2018 7:56 am
Templar wrote:There is a problem with the Changelog screen with the calendar app. It isn't possible to correctly scroll down.
do you mean it flips back to the top quickly? This is intended (maybe not wanted) behaviour, usually you want to see only the latest changelog.
I have never implemented a proper scrollbar there......will put it on the to-do list (not the highest priority)
Postby Templar » Sat Dec 22, 2018 3:13 pm
Toonz wrote:do you mean it flips back to the top quickly? This is intended (maybe not wanted) behaviour, usually you want to see only the latest changelog.
Yes I do. Okay, thanks for the info.
Templar
Postby alcomys » Tue Jan 08, 2019 9:06 pm
I have an strange problem,
when installing an app from the toonstore it is not installed after.
the status in toonstore is that the app is not installed even after reboot the toon.
when i do install manual the app is normal installed.
can some help me out here ?
alcomys
Postby Toonz » Tue Jan 08, 2019 9:29 pm
can you check this file for error messages: /mnt/data/update/_opkg.nxt-uni-9.9.99.script.sh.log ?
Postby alcomys » Tue Jan 08, 2019 9:43 pm
Toonz wrote:can you check this file for error messages: /mnt/data/update/_opkg.nxt-uni-9.9.99.script.sh.log ?
the file on my toon is empty
alcomys
Postby Toonz » Wed Jan 16, 2019 10:58 pm
version 2.1.2 of ToonStore is available on ToonStore.
Changelog:
- firmware 5 compatibility of the installer, no new functionality
Postby Xavier » Fri Jan 18, 2019 2:59 pm
Toonz wrote:Hi all,
Changelog:
Tested on Toon1 with firmware 5.0.4, this is working fine.
Toon1 with 5.0.4 firmware
Xavier
Previous
Return to Toon Apps
