Toon app: ToonStore
Re: Toon app: ToonStore
Postby TheHogNL » Fri Apr 05, 2019 8:58 pm
You posting a question about updating a toon on the toonstore topic.
Postby Daniel » Sat Apr 06, 2019 7:55 am
It isn’t about updating the toon,
I just installed toonstore on a toon with firmware 4.9.23 but when I push the + in toonstore and bijwerken nothing happen.
I bought it whit 2 apps installed before Buienradar and dasticz the Buienradar didn’t work dasticz don’t know.
Daniel
Postby TheHogNL » Sat Apr 06, 2019 10:02 am
Ah ok. Probably you then just need to reinstall toonstore.
Postby Daniel » Sat Apr 06, 2019 3:04 pm
I have reinstalled toonstore, unfortunately the problem remains.
There is still Dashticz present on top of screen, just cannot find how to remove this.
this is the log.
Toon:~# opkg install toonstore_2.1.2-r0_qb2.ipk
Installing toonstore (2.1.2-r0) to root...
Executing pre-install script for toonstore-2.1.2
New installation of toonstore.
Backing up public keyring ...
Backing up /etc/hosts ...
Editing /etc/hosts to enable toonstore ...
hcb_config process ID now: 688
Restarting hcb_config ...
Waiting for 3 seconds ...
hcb_config process ID now: 2210
Creating backup for /qmf/etc/qmf_project.xml ...
Patching /qmf/etc/qmf_project.xml for 403-forbidden error ...
Restarting http server ...
killall: lighttpd: no process killed
Cleaning garbage....
rm: can't remove '/HCBv2/qml/apps/toonstore/*.qmlc': No such file or directory
rm: can't remove '/HCBv2/qml/apps/toonstore/*.jsc': No such file or directory
rm: can't remove '/HCBv2/qml/apps/toonstore/*.txt': No such file or directory
ToonStore pre-install script completed ...
Configuring toonstore.
Executing post-install script for toonstore-2.1.2 ...
Writing app version number to /HCBv2/qml/apps/toonstore-2.1.2/version.txt ...
Adding toonstore key to opkg keyring ...
OK
This is a Toon QB2, checking to Globals.qml
Adding toonstore to Globals.qml ...
No settings to be restored
Creating symbolic link /HCBv2/qml/apps/toonstore to /HCBv2/qml/apps/toonstore-2.1.2
Firmware version 4 or lower detected, no changes needed...
Posting message ...
Daniel
Postby rbak » Sat Apr 06, 2019 9:39 pm
Finally decided to update my Toon 1 from version 4.22.7 to 5.2.11 using the update-rooted.sh script. All went flawless and after the system started up it is stating the software version is 5.2.11 now. Sofar all seems to work but I get the impression the response of the sofware is slower than my previous version 4.22.7. Nevertheless I will see how it performs in the next week(s).
One thing I did notice is that in the Toonstore the screenshots of the apps are no longer showing. When I press the questionmark the changelog is updating correctly and showing the number of screenshots. But when I click on the screenhots button nothing happens. I have rebooted the device and also performed an ./updated-rooted.sh -f but no change.
Does anyone else have the same problem and/or is this a known issue? Any suggestions how to get this resolved?
rbak
Postby Toonz » Sun Apr 07, 2019 8:27 am
rbak wrote:Finally decided to update my Toon 1 from version 4.22.7 to 5.2.11 using the update-rooted.sh script. All went flawless and after the system started up it is stating the software version is 5.2.11 now. Sofar all seems to work but I get the impression the response of the sofware is slower than my previous version 4.22.7. Nevertheless I will see how it performs in the next week(s).
I have the same impression on a Toon 1 (especially when coming out of dim state) , no difference on a Toon 2 in my case
rbak wrote:One thing I did notice is that in the Toonstore the screenshots of the apps are no longer showing. When I press the questionmark the changelog is updating correctly and showing the number of screenshots. But when I click on the screenhots button nothing happens. I have rebooted the device and also performed an ./updated-rooted.sh -f but no change.
I will see if I can fix this....(image processing changed a bit in recent firmwares)
Postby Toonz » Sun Apr 07, 2019 1:21 pm
found the issue (caused by the new firmwares), will release an updated ToonStore in the near future.
Postby Daniel » Sun Apr 07, 2019 4:17 pm
Today I update the firmware to 5.0.4 whit the update script without problems.
Remove en reinstall toonstore, still the same error.
Is it possible that someone can have a look whit teamviewer some day? Because I’m a dummy and don’t wand to brick the toon.
Daniel
Postby Toonz » Sun Apr 07, 2019 7:01 pm
I can do this tomorrow evening. Just send me a pm with your 06 number..
Postby Toonz » Mon Apr 08, 2019 9:23 pm
Daniel wrote:Today I update the firmware to 5.0.4 whit the update script without problems.
The previous owner messed around with this Toon probably:
- the lighttpd and genModules executables didn't have the executable flag set, in other words, the webserver on Toon was not running
- the hosts file was completely empty.
Both issues were fixed after which the ToonStore worked fine.
Postby Toonz » Sat Apr 13, 2019 2:16 pm
version 2.1.3 is now available in the ToonStore.
Changelog:
- screenshots are now shown again in firmware 5
- a little bit of clean-up in the installation scripts
- a maximum of 3 apps can be installed in one run at the same time
Postby Rudolf » Sat Apr 13, 2019 8:01 pm
Updated several apps after installing ToonStore v2.1.3, works great for me. Thanks.
Rudolf
Postby Toonz » Wed Apr 17, 2019 7:39 pm
version 2.1.4 is now available in the ToonStore, a small maintenance release.
Changelog:
- fix: on firmware 5 the warning icon (cannot download) was shown as a dark grey square instead of an exclamation mark (See EasyEenergy as an example).
Postby PeJeWe » Thu Apr 25, 2019 5:58 am
Maybe a noob question, where do it put the toonstore_2.1.2-r0_qb2.ipk for installation. I can't get it to install
Rooted Toon 1, Domoticz running on a RPI3b+, RFXCOM XL, RFLINK.
PeJeWe
Postby TerrorSource » Thu Apr 25, 2019 8:27 am
PeJeWe wrote:Maybe a noob question, where do it put the toonstore_2.1.2-r0_qb2.ipk for installation. I can't get it to install
If you run the update-rooted.sh script with the -f parameter it should be already installed.
TerrorSource
PreviousNext
Return to Toon Apps
Users browsing this forum: ams123 and 0 guests
