Toon app: ToonStore
Re: Toon app: ToonStore
Postby Toonz » Thu Apr 25, 2019 9:20 am
or manually:
opkg install toonstore_2.1.2-r0_qb2.ipk
via ssh
Postby mAiden » Thu Apr 25, 2019 9:34 am
Toonz wrote:or manually:
via ssh
Maybe
opkg install http://files.domoticaforum.eu/uploads/T ... r0_qb2.ipk
will be better work, otherwise he will first have to download ipk file and then install it :D
mAiden
Postby PeJeWe » Thu Apr 25, 2019 11:42 am
Maybe
I’ll get an error:
opkg: unknown sub-command
I have the latest toon software, and I have rooted it with my rpi1 and ToonRooter.
I have ssh access.
Where can I put the file for manual install.
Rooted Toon 1, Domoticz running on a RPI3b+, RFXCOM XL, RFLINK.
PeJeWe
Postby WickedMaster » Thu Apr 25, 2019 1:32 pm
Just run the update-rooted.sh script with -f parameter as mentioned before by TerrorSource, it will fix it (and other things as well) for you.
Download the script towards your Toon. The easiest way is just to use curl from your Toon:
curl -Nks https://raw.githubusercontent.com/IgorYbema/update-rooted/master/update-rooted.sh -o /root/update-rooted.sh
Then run the script with:
sh /root/update-rooted.sh -f
WickedMaster
Postby PeJeWe » Thu Apr 25, 2019 6:45 pm
WickedMaster wrote:Just run the update-rooted.sh script with -f parameter as mentioned before by TerrorSource, it will fix it (and other things as well) for you.
Thanks it works :D
PeJeWe
Postby Toonz » Wed May 29, 2019 5:42 pm
In release 5.5.7 (and onwards I assume) there is now a 60 seconds delay between pressing the 'Toon bijwerken' button and installation of the apps. This is due to the fact that the Toon tries to start the vpn which fails after a minute.
This has no further impact other than the delay itself.
Apps will install as expected.
Postby Toonz » Sat Jun 01, 2019 8:01 pm
to circumvent the minute delay in firmware 5.5.7 when installing apps we have completely redesigned the mechanisme to install apps via the ToonStore (joint effort by TheHogNL and myself).
The result is that apps are installed and removed much faster then before.
Installation log files can now be found in /var/volatile/log/tsc.
During the installation of ToonStore we also update the TSC script (you will get a notification of that).
This new way of installing apps will be applicable on all firmwares from 4.16.8.
On older firmwares the old method will still be used.
Version 3.0.2 is available now in the ToonStore.
Hope you like it.
Changelog 3.0.2:
- implemented new install / remove process for apps because the original firmware upgrade
process is introducing a 60 seconds delay in installing apps from firmware 5.5.7 onwards.
The new install method is not using any Eneco functionality anymore (Thanks to TheHogNL).
This new process is active from firmware 4.16.8 and requires the latest resourcefile/TSC script versions.
For firmwares before 4.16.8 there is no change.
- optimised handling of settings files
- removed unused code for supporting firmware upgrades (now part of TSC menu)
Toonz & TheHogNL
Postby whizzz63 » Tue Jun 04, 2019 11:15 am
Super work! Well done.
whizzz63
Postby RoadXY » Tue Jun 04, 2019 11:32 am
Nice work, well done!
RoadXY
Postby Toonz » Sat Aug 31, 2019 10:12 am
a new version of ToonStore is available in the ToonStore. No new functionality but a few old gui bugfixes.
Changelog:
3.0.3
- The button "Toon bijwerken" is not shown anymore when no packages are selected to be installed/removed but is showing "Terug".
Pressing the button did cause a gui to restart for nothing when no packages were selected.
- Secondly, when looking at the changelog of an app, the "Terug" button is now functioning properly as well.
Postby michel30 » Sun Sep 01, 2019 8:03 am
Thanks for this nice update.
michel30
Postby pkaak » Sun Sep 22, 2019 10:07 pm
Ik keek vandaag even in de Toonstore, en die blijft bij mij helemaal leeg.
Toon heeft wel een op adres, update naar firmware 5.9.6 via TSC ging zelfs goed (had gehoopt dat dat de Toonstore zou helpen).
Restart werkt ook niet.
Waar kan dat aan liggen? Hij start dus wel op, maar geen inhoud.
Geen idee hoe lang dit al is (kijk normaal niet zo vaak in de store)
pkaak
Postby Blacky's Boss » Mon Sep 23, 2019 10:54 am
Oh, I saw the same since yesterday. I assumed I was allmost out of memory again, but maybe there is another reason? I noticed the site was also down for some time yesterday.
edit: Just found this topic. https://www.domoticaforum.eu/viewtopic. ... 04&t=12523
No further questions... :mrgreen:
Blacky's Boss
Postby Edwin66 » Tue Oct 01, 2019 10:21 am
Ik zie dat er een nieuwe versie van de Toonstore is, maar... iedere keer als ik deze selecteer en op bijwerken druk, krijg ik een melding dat de bestanden in de achtergrond worden gedownload, maar daarna gebeurt er verder niets.
Ps. ik zit nog op een oudere versie (firmware 4.19.10), ben het wachtwoord van de Toon kwijt, en kan dus niet mer inloggen via Terminal.
Toon® (rooted) | Hue bulbs | TRÅDFRI bulbs | Smart Plug | Domoticz latest BETA |
I'm not a programmer, just wish things work MY way
Edwin66
Postby Toonz » Tue Oct 01, 2019 11:38 am
Edwin66 wrote:Ik zie dat er een nieuwe versie van de Toonstore is, maar... iedere keer als ik deze selecteer en op bijwerken druk, krijg ik een melding dat de bestanden in de achtergrond worden gedownload, maar daarna gebeurt er verder niets.
Heb je wel de laatste versie van de resourcefiles (te updaten via de TSC tab in het instellingenmenu ("Check for updates").
De firmware update mag je negeren als je maar wel de nieuwe resourcefile ophaalt.
Die bevatten de scripts die de downloads uitvoeren namenlijk....
PreviousNext
Return to Toon Apps
cron
