Toon app: ToonStore
Re: Toon app: ToonStore
Postby Edwin66 » Sat Nov 09, 2019 6:36 pm
TheHogNL wrote:
Edwin66 wrote:There is something wrong with the VPN connection on my Toon.
Run this to check why your VPN isn't starting:
/usr/sbin/openvpn --config /etc/openvpn/vpn.conf
Maybe your VPN key is withdrawn. If so, contact me PM. I do have some old not working toon's from which you can have the VPN key from for a small payment.
This is the error-message:
eneco-001-344210:~# /usr/sbin/openvpn --config /etc/openvpn/vpn.conf
Options error: In [CMD-LINE]:1: Error opening configuration file: /etc/openvpn/vpn.conf
Use --help for more information.
Toon® (rooted) | Hue bulbs | TRÅDFRI bulbs | Smart Plug | Domoticz latest BETA |
I'm not a programmer, just wish things work MY way
Edwin66
Postby TheHogNL » Sat Nov 09, 2019 8:16 pm
So yes your VPN config is gone. I have been told that you have rooted your toon years ago using the Quby method (and they removed your VPN config for that).
You can contact me in a PM so I can sell you a VPN config from old broken toon.
Postby Edwin66 » Sat Nov 09, 2019 10:37 pm
Well, it was last year, but yes, Quby rooted the thing.
I'll contact you later. Now it's time for some needed rest.
Edwin66
Postby Toonz » Sun Nov 10, 2019 12:38 am
Toonz wrote:Hi all,
a new version of ToonStore (4.0.0) is available in the ToonStore.
This is the last app store update in a row to move all settings files to the /mnt/data/tsc folder.
This was all to prepare for our move to GitHub with all apps.
The new upcoming TSC scripts will install apps directly from Github, without making use of the ipk packages and signature keys anymore.
The big advantage of GitHub is that everyone can easily contribute to further code development for all apps.
The downside is that we had to drop firmware 4 and lower compatibility.
More to come on this one, stay tuned…….
Changelog:
- settings are now stored in /mnt/data/tsc/toonstore.userSettings.json
- app is only firmware 5 compatible. Support for older firmware has been dropped.
- toonstore apps can only be installed via the supporting TSC scipts on firmware 5
Therefore support for signature keys (needed for app installations on older firmwares) has been dropped as well.
I got a bug report on a Toon 1 with this version. I took it offline to investigate further. Version 3.0.3 is now the actual version in the ToonStore.
If you already installed 4.0.0 and it is working fine then no need to take action.
Postby Toonz » Mon Nov 11, 2019 8:56 pm
version 4.0.0 is available again.
The issue was that in certain circumstances the default value for showing the tray icon is set to false if it was never specified before.
If that happens, go to the ToonStore via the Toon menu and select the right settings in the 'Instellingen' page.
Postby Edwin66 » Tue Nov 12, 2019 1:08 pm
Edwin66 wrote:Well, it was last year, but yes, Quby rooted the thing.
Thanks to TheHog Toon is working with VPN again. Thanks.
Firmware updated to latest
Edwin66
Postby redcell » Thu Nov 21, 2019 5:30 am
Rooted Toon with latest firmware, 5.15.6, then installed toonstore_2.1.4-r0_qb2.ipk found in this topic, and after some reading updated resources, then the toonstore icon showed up, which it first didn't without the resources, but it is impossible to update the toonstore app to 4.0 or download and install any apps.
the output of logfile from _opkg.qb2-uni-9.9.99.script.sh.log:
>> 2019-11-21 04:06:30 +0100 (pid 1810), status = prepare
>> Welcome to the ToonStore updater,
>> brought to you by the Toonroot Software Collective (TSC)
>> 2019-11-21 04:06:30 +0100 (pid 1810) _opkg.qb2-uni-9.9.99.script.sh qb2 uni 9.9.99 prepare
>> 2019-11-21 04:06:30 +0100 (pid 1810), status = preparing
>> Firmware version: 5.15.6, build 0, rev .
>> System load     :
>> Free RAM        : 17804K
>> Flushing file system buffers and cache ...
>> Free RAM now    : 28744K
>> Hotfix for writing System Time to RTC
Hardware Clock before: Thu Nov 21 03:06:29 2019  0.000000 seconds
Hardware Clock after : Thu Nov 21 03:06:33 2019  0.000000 seconds
rm: can't remove '/var/lib/opkg/tsc*': No such file or directory
>> Installing wastecollection-4.25 boilerstatus-1.0.6   toonstore-4.0.0
>> Extracting packages from the following repo('s):
src/gz tsc1 http://files.domoticaforum.eu/uploads/Toon/apps/wastecollection-4.25
/mnt/data/update/_opkg.qb2-uni-9.9.99.script.sh: line 568: echo>> dependencies found: tsc-certificates-1.1.1: not found
src/gz tsc2 http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/tsc-certificates-1.1.1
src/gz tsc3 http://files.domoticaforum.eu/uploads/Toon/apps/boilerstatus-1.0.6
src/gz tsc4 http://files.domoticaforum.eu/uploads/Toon/apps/toonstore-4.0.0
>> configured opkg feeds:
>> opkg update
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/wastecollection-4.25/Packages.gz.
Inflating http://files.domoticaforum.eu/uploads/Toon/apps/wastecollection-4.25/Packages.gz.
Updated list of available packages in /var/lib/opkg/tsc1.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/wastecollection-4.25/Packages.sig.
Signature check passed.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/tsc-certificates-1.1.1/Packages.gz.
Inflating http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/tsc-certificates-1.1.1/Packages.gz.
Updated list of available packages in /var/lib/opkg/tsc2.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/tsc-certificates-1.1.1/Packages.sig.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/boilerstatus-1.0.6/Packages.gz.
Inflating http://files.domoticaforum.eu/uploads/Toon/apps/boilerstatus-1.0.6/Packages.gz.
Updated list of available packages in /var/lib/opkg/tsc3.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/boilerstatus-1.0.6/Packages.sig.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/toonstore-4.0.0/Packages.gz.
Inflating http://files.domoticaforum.eu/uploads/Toon/apps/toonstore-4.0.0/Packages.gz.
Updated list of available packages in /var/lib/opkg/tsc4.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/toonstore-4.0.0/Packages.sig.
Signature check failed.
Remove wrong Signature file.
Collected errors:
* opkg_download: Failed to download http://files.domoticaforum.eu/uploads/Toon/apps/toonstore-4.0.0/Packages.sig: HTTP response code said error.
>> 2019-11-21 04:06:37 +0100 (pid 1810) prepare-error-opkg-update 'Exit code 1 for: opkg update'
>> 2019-11-21 04:08:34 +0100 (pid 2101), status = prepare
>> 2019-11-21 04:08:34 +0100 (pid 2101) _opkg.qb2-uni-9.9.99.script.sh qb2 uni 9.9.99 prepare
>> 2019-11-21 04:08:34 +0100 (pid 2101), status = preparing
>> System load     :
>> Free RAM        : 24524K
>> Free RAM now    : 28092K
Hardware Clock before: Thu Nov 21 03:08:36 2019  0.000000 seconds
Hardware Clock after : Thu Nov 21 03:08:37 2019  0.000000 seconds
>> opkg update
Collected errors:
>> 2019-11-21 04:08:40 +0100 (pid 2101) prepare-error-opkg-update 'Exit code 1 for: opkg update'
>> 2019-11-21 04:14:51 +0100 (pid 2868), status = prepare
>> 2019-11-21 04:14:51 +0100 (pid 2868) _opkg.qb2-uni-9.9.99.script.sh qb2 uni 9.9.99 prepare
>> 2019-11-21 04:14:51 +0100 (pid 2868), status = preparing
>> System load     :
>> Free RAM        : 24376K
>> Free RAM now    : 29772K
Hardware Clock before: Thu Nov 21 03:14:53 2019  0.000000 seconds
Hardware Clock after : Thu Nov 21 03:14:53 2019  0.000000 seconds
>> Installing toonstore-4.0.0
src/gz tsc1 http://files.domoticaforum.eu/uploads/Toon/apps/toonstore-4.0.0
>> opkg update
Collected errors:
>> 2019-11-21 04:14:55 +0100 (pid 2868) prepare-error-opkg-update 'Exit code 1 for: opkg update'
>> 2019-11-21 04:18:26 +0100 (pid 3253), status = prepare
>> 2019-11-21 04:18:26 +0100 (pid 3253) _opkg.qb2-uni-9.9.99.script.sh qb2 uni 9.9.99 prepare
>> 2019-11-21 04:18:26 +0100 (pid 3253), status = preparing
>> System load     :
>> Free RAM        : 25372K
>> Free RAM now    : 28920K
Hardware Clock before: Thu Nov 21 03:18:27 2019  0.000000 seconds
Hardware Clock after : Thu Nov 21 03:18:28 2019  0.000000 seconds
>> opkg update
Collected errors:
>> 2019-11-21 04:18:29 +0100 (pid 3253) prepare-error-opkg-update 'Exit code 1 for: opkg update'
>> 2019-11-21 04:20:29 +0100 (pid 3514), status = prepare
>> 2019-11-21 04:20:29 +0100 (pid 3514) _opkg.qb2-uni-9.9.99.script.sh qb2 uni 9.9.99 prepare
>> 2019-11-21 04:20:29 +0100 (pid 3514), status = preparing
>> System load     :
>> Free RAM        : 25040K
>> Free RAM now    : 28064K
Hardware Clock before: Thu Nov 21 03:20:32 2019  0.000000 seconds
Hardware Clock after : Thu Nov 21 03:20:32 2019  0.000000 seconds
>> opkg update
Collected errors:
>> 2019-11-21 04:20:35 +0100 (pid 3514) prepare-error-opkg-update 'Exit code 1 for: opkg update'
>> 2019-11-21 04:22:30 +0100 (pid 3779), status = prepare
>> 2019-11-21 04:22:30 +0100 (pid 3779) _opkg.qb2-uni-9.9.99.script.sh qb2 uni 9.9.99 prepare
>> 2019-11-21 04:22:30 +0100 (pid 3779), status = preparing
>> System load     :
>> Free RAM        : 24792K
>> Free RAM now    : 27556K
Hardware Clock before: Thu Nov 21 03:22:31 2019  0.000000 seconds
Hardware Clock after : Thu Nov 21 03:22:32 2019  0.000000 seconds
>> Installing webcam-1.0.5
src/gz tsc1 http://files.domoticaforum.eu/uploads/Toon/apps/webcam-1.0.5
>> opkg update
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/webcam-1.0.5/Packages.gz.
Inflating http://files.domoticaforum.eu/uploads/Toon/apps/webcam-1.0.5/Packages.gz.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/webcam-1.0.5/Packages.sig.
Collected errors:
* opkg_download: Failed to download http://files.domoticaforum.eu/uploads/Toon/apps/webcam-1.0.5/Packages.sig: HTTP response code said error.
>> 2019-11-21 04:22:34 +0100 (pid 3779) prepare-error-opkg-update 'Exit code 1 for: opkg update'
>> 2019-11-21 04:30:55 +0100 (pid 1931), status = prepare
>> 2019-11-21 04:30:55 +0100 (pid 1931) _opkg.qb2-uni-9.9.99.script.sh qb2 uni 9.9.99 prepare
>> 2019-11-21 04:30:55 +0100 (pid 1931), status = preparing
>> System load     :
>> Free RAM        : 18724K
>> Free RAM now    : 30812K
Hardware Clock before: Thu Nov 21 03:30:57 2019  0.000000 seconds
Hardware Clock after : Thu Nov 21 03:30:57 2019  0.000000 seconds
>> opkg update
Collected errors:
>> 2019-11-21 04:30:59 +0100 (pid 1931) prepare-error-opkg-update 'Exit code 1 for: opkg update'
so the error is: Signature check failed. Remove wrong Signature file.
if I delete the content of "/mnt/data/update" this has no effect.
how to fix this?
UPDATE: since the more then 10 hours of orwellian check to get this message posted manged to already solve this paradox.. installing toonstore 4.0.0 fixed this. but you cannot install it, so installed it manually by downloading the zip from github and placing the unzipped folder in the correct folder on the toon and making a simlink to the folder. and deleting the old simlink and folder of the previous version.
redcell
Postby TheHogNL » Thu Nov 21, 2019 5:10 pm
Did you follow the manual? https://www.domoticaforum.eu/viewtopic. ... 235#p82533
I think you didn't run the update-rooted.sh script with option -f to finish/finalize your rooting.
Else, just remove the very old toonstore (remove the whole /qmf/qml/apps/toonstore dir) and just install the new onze.
Postby TheHogNL » Thu Nov 21, 2019 6:12 pm
redcell wrote: so installed it manually by downloading the zip from github and placing the unzipped folder in the correct folder on the toon and making a simlink to the folder. and deleting the old simlink and folder of the previous version.
This is how you should have done it indeed. You went wrong installing a very old toonstore but you managed to fix it yourself. Within a few days the github will be the main location where toonstore will install the apps from. Need to change some scripts for that.
Postby TheHogNL » Sun Nov 24, 2019 7:09 pm
Important UPDATE!
From now on toonstore apps will be installed from https://github.com/ToonSoftwareCollective and not from the forum fileserver anymore. This also means that we don't publish new versions of apps anymore on the forum fileserver. Every new version is now maintained within github which allows everyone to contribute and see what is changed by reviewing the commits.
Postby hayman » Tue Nov 26, 2019 9:03 pm
thanks for all the work after updaing the toonstore to V4 i don't get the icon on the front page ...?
i see it only when i click on setings.
thanks
hayman
Postby Ron_nl » Tue Nov 26, 2019 10:42 pm
@hayman scroll up a bit and you will see this:
Toonz wrote:version 4.0.0 is available again.
Ron.
Ron_nl
Postby hayman » Wed Nov 27, 2019 12:46 pm
Thanks and sorry for not noticing that :)
hayman
Postby Toonz » Thu Nov 28, 2019 12:16 am
a new version of ToonStore is available in the ToonStore :-).
This version 5.0.0 will install via github for the first time. Also all future installations of the apps will come from github.
The use of github allows easier collaboration and contribution to the development of all apps (looking forward to your pull requests :) ).
Note that the apps on the domoticforum.eu fileserver will not be updated anymore, installation ipk files will not be created anymore.
New updates of the apps will be available via ToonStore 5.0.0 only which require firmware 5 on your Toon with our latest resourcefiles.
If you are on a pre-5 firmware you can of course continue using that but you cannot install any app update anymore.
Our github location: https://github.com/ToonSoftwareCollective
Changelog ToonStore version 5.0.0:
- change location of app repo to github (including all apps available in the toonstore, screenshots and changelogs)
- all apps will be installed via the github repositories
Postby michel30 » Thu Nov 28, 2019 7:39 pm
Do we need first uninstall the old apps?
Than upgrade the new ToonStore and reinstall all the apps?
Michel
michel30
PreviousNext
Return to Toon Apps
cron
