Toon app: ToonStore
Re: Toon app: ToonStore
Postby Toonz » Thu Nov 28, 2019 8:16 pm
no, that is done fully automatic when the first update is coming from github for that app
"makkelijker kunnen we het niet maken"
Postby pbtinus » Sun Dec 01, 2019 10:01 pm
hello,
I'm a new Toon user and justed rooted my Toon 1 today, everything went well except the toonstore, it stays empty.
If I manually install the 4.0 version through opkg ( opkg install http://files.domoticaforum.eu/uploads/T ... r0_qb2.ipk ) then the toonstore is filled but I can't install any apps ( only manually when downloading the IPK files )
if I install the 5.0 version :
curl -Nks https://raw.githubusercontent.com/IgorY ... -rooted.sh -o /root/update-rooted.sh
and then
sh /root/update-rooted.sh
no errors and after a reboot an empty toonstore.... what am I doing wrong?
thanks in advance
Oh, my Toon has the latest firmware 5.15.6 installed
pbtinus
Postby Toonz » Mon Dec 02, 2019 12:05 am
what firmware is your Toon running?
Only firmware 5.x.x is supported with ToonStore version 5.
Recent versions of most apps are only fw5 compatible.
So my guess is that you are running on an older firmware.
If so, you have two choices :upgrade the Toon firmware or manually install the last versions of the apps which were compatible with older firmwares (see the Changelogs for that).
Postby TheHogNL » Mon Dec 02, 2019 5:10 pm
pbtinus wrote:sh /root/update-rooted.sh
Did you run that with -f option? That is the first thing you need to do after rooting a Toon. You probably are missing some key rooted toon patches.
Postby Toonz » Tue Jan 14, 2020 9:24 pm
a small update (bugfix) of ToonStore is released in ToonStore. The auto update functionality for installed apps didn't work after a qui restart, only after going to the settings screen and enter an update time.
Changelog version 5.0.1:
- bugfix for the auto update timer, now working as expected
No need to update if you don't use the auto update functionality.
Kind regards,
Previous
Return to Toon Apps
cron
