OTGW and Orange Pi Zero one device.
Re: OTGW and Orange Pi Zero one device.
Postby cyril » Wed May 02, 2018 7:17 am
Links to OS images with OTmonitor in first post of this topic.
cyril
Postby texnic » Wed May 02, 2018 8:24 pm
bruce_miranda wrote:Once you load the OS image and get the Orange Pi connected to your network, how do you interact with the OT gateway? I'm guessing the OS on the Orange Pi is headless, so where is the OT Monitor loaded? I.e. how do view the data?
I've tried one method so far. Let's say your OPi IP is 192.168.1.9. Then, while on the same network, you can simply browse to http://192.168.1.9:8080 and should see the monitor web-pages.
Tried with Armbian image from Cyril (links in the first post of this thread).
texnic
Postby bruce_miranda » Wed May 02, 2018 9:47 pm
Ah right so it's using the web version of the otmonitor, rather than the client GUI. That's fine. What about SSH access into the armbian. What's the root user and password?
bruce_miranda
Postby bruce_miranda » Thu May 03, 2018 7:38 pm
Received mine today. It's super neat and clearly a lot of time has gone into thinking about the layout and researching the BOM. Finding and designing a terminal block that would fit through the dual USB hole on the enclosure was just genius. I was going to fire it up today. But I need to find some thinner gauge wire, oh and time!
bruce_miranda
Postby cyril » Thu May 03, 2018 7:50 pm
Tnank you!
cyril
Postby texnic » Sun May 13, 2018 12:05 pm
bruce_miranda wrote:What about SSH access into the armbian. What's the root user and password?
It is root/orangepi, as also briefly mentioned by Cyril at the top of this thread :)
SSH works just fine. I've set up SSH keys and disabled password login, as usual.
texnic
Postby bruce_miranda » Sun May 13, 2018 12:07 pm
Yes, I did spot that in the thread earlier.
bruce_miranda
Previous
cron
