FSK Caller ID solution for UPC cable
Posted: Sun Jun 15, 2008 7:11 pm
by Mhwlng
I recently switched from ISDN to UPC/Chello cable telephone (using FSK, not DTMF), which meant that I needed a new solution to handle caller id (before, I used a dynalink ISDN modem) :
I got one of these devices working :
http://www.crucible-technologies.co.uk/ ... &did=43864
connected to girder via a Sollae RS232->ethernet converter
(girder/netremote then displays the caller name on various displays in my living room and office and mutes the amplifier at an incoming call)
p.s. I tried one of these EX700 devices to convert FSK to DTMF, so that I could see the caller ID on my DECT phone's display :
http://www.limacom.nl/contents/nl/p143.html
but that doesn't work for me...
I don't know yet, if the problem is the EX700 or my new PABX...
Marcel
Posted: Sun Jun 15, 2008 10:33 pm
by Bastiaan
Before you pull apart your system: UPC had/has a big problem with the callerID system. I got a special letter about it.
Did you also asked the customer service to switch it on? It's off by default so they can get more money from you
I've got a very cheap converter (about 25 euro) that is working wel.
(Just behind the UPC modem)
Posted: Sun Jun 15, 2008 10:40 pm
by Mhwlng
the CTI meteor is working ok, so the callerid is definitely on [:)]
I did have to call UPC to switch it on...
the EX700 was also EUR 25,-
I assume that you are using the same device ?
Marcel
Posted: Mon Jun 16, 2008 7:53 am
by Jfn
Where did you buy the CTI meteor? I quit using telephone modems a long time ago and the old one I have lying around somewhere does not support caller-id.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">
Posted: Mon Jun 16, 2008 8:42 am
by Mhwlng
at the link above, in the u.k. (GBP 100,-)
note that it only supports fsk, NOT dtmf (as used by KPN/ADSL etc.)!
Marcel
Posted: Mon Jun 16, 2008 7:56 pm
by Edwin
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by zebrafilm</i>
<br />Before you pull apart your system: UPC had/has a big problem with the callerID system. I got a special letter about it.
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Hi,where did u get youre converter and how u get it in homeseer,i have upc also.
thanks edwin
Posted: Sun Jul 06, 2008 3:15 pm
by Mhwlng
UPC caller ID only just started working, with my DECT phones
(Siemens gigaset SL370, with various handsets e.g SL37H)
I'm NOT using the EX700 to convert FSK to DTMF, so I don't know if that device works ok now...
I read somewhere, that UPC updated some settings in the cable-modem recently... I didn't reset the cable-modem manually.
(p.s. the cti meteor device was working ok, all the time)
Marcel
