Page 1 of 7
Toon app: Dashticz (no longer working)
Posted: Sat Dec 02, 2017 12:04 am
by robgeerts
Here is the first basic version of Dashticz (for Toon).
As some of you may know, Dashticz is another frontend for
Domoticz, more info:
http://www.domoticz.com/forum/viewforum.php?f=67
Remember, this is still a beta version wich is only tested on version 4.8.25 of Toon! It only shows favorite (!) devices and currently only regular light switches, scene switches, fans and percentage-devices (with a computer-image) are supported. I'm planning on adding more device types and buttons (next to 'Instellingen') to add more functionality like in the original Dashticz.
Edit mod: app does not work with latest Toon firmware. Use at own risk, no support.
Manual installation:
1.) Download zip from this
https://github.com/robgeerts/dashticz_toon, unzip contents to a folder named 'dashticz' and upload this folder to: '/HCBv2/qml/apps/'
2.) Add 'dashticz' to the array of 'appsToLoad' in '/HCBv2/qml/qb/base/Globals.qml'
3.) Reboot
4.) Click on the new (bulb) icon in the notification-bar
5.) Click on 'Instellingen' to enter ip, port, username and password (enter base64 encoded username & password)
OV-tab
1.) First get the station id from
http://api.9292.nl/0.1/locations?lang=nl-NL&q=eindhoven (Change eindhoven to your own search parameter).
2.) Copy the ID and enter this value in the 'Station / Halte' field
Re: Toon app: Dashticz (for Toon)
Posted: Sat Dec 02, 2017 12:09 am
by lsiepel
Maybe good to mention dashticz is a frontend for domoticz. Do you mind if i copy cat parts of your app to try get a frontend for openHAB working?
Posted: Sat Dec 02, 2017 12:11 am
by robgeerts
No problem!
We all have to learn from each other to make things better!
Posted: Sat Dec 02, 2017 11:31 am
by Toonz
Nice, good start. When leaving the beta stage we can publish it via the ToonStore as well later on if you want.
Regardz,
Posted: Sat Dec 02, 2017 11:43 am
by jozg
Hello Rob,
Nice work, looks good.
Did everything in the manual, but it keeps saying "bezig met laden"
I filled in the host 192.168.1.11 the port 8080 and i have converted the username and password on
https://www.base64encode.org/
Am i'm doing something wrong?
Thanks for helping.
Posted: Sat Dec 02, 2017 1:04 pm
by marcelr
Nice job,
robgeerts,
As
Toonz already said, just yell when it's ready for prime time.
In the meantime, I'll cease my efforts to get netsurf working on toon. Switching /dev/fb0 owners every now and then was not such a good idea anyway
Posted: Sat Dec 02, 2017 2:19 pm
by robgeerts
Netsurf browser?
So it would maybe possible to run the normal Dashticz on Toon?
Posted: Sat Dec 02, 2017 3:53 pm
by marcelr
Netsurf is one of the few browsers capable of running on a framebuffer device. It does not require a window manager.
However, when toon boots, qt-gui grabs hold of the screen framebuffer (/dev/fb0) and will only release it when it stops. Only then the browser can start. This is what I meant by switching /dev/fd0 ownership.
Posted: Sat Dec 02, 2017 4:10 pm
by michel30
@robgeerts
Can this also work with MQTT?
I installed domoticz on my NAS, but I never get my toon or lights working on it.
I also used node red and there My toon and the lights are working okay.
Posted: Sat Dec 02, 2017 4:19 pm
by Toonz
jozg wrote:Hello Rob,
Thanks for helping.
Is your Domoticz accessible via http? Toon is not supporting http
s
Posted: Sat Dec 02, 2017 5:02 pm
by jozg
Toonz wrote:jozg wrote:Hello Rob,
Thanks for helping.
s
Yes, and domoticzboard is working fine.
Any other suggestions, i'm on 4.9.23 firmware.
Thanks.
Posted: Sat Dec 02, 2017 5:23 pm
by jozg
Thanks for helping.
s
By the way, i noticed that the dashticz.settings file is empty, showing []
Should the file contains the settings i made via the user interface?.
Regards
Posted: Sat Dec 02, 2017 7:03 pm
by Toonz
@Rob,
When you use the 'instellingen'' screen you get a run-time error in the OnShown function at line
domoticzHostLabel.inputText = app.settings.domoticzHost;
Error:
file:///qmf/qml/apps/dashticz/DashticzSettings.qml:16: Error: Cannot assign [undefined] to QString
The settings variables are never properly populated apparently. No values are saved in dashticz.settings therefore.
Posted: Sat Dec 02, 2017 11:28 pm
by robgeerts
Ah, I guess I miss the next line of code (before OnShown{}) in DashticzSettings.qml
Posted: Sun Dec 03, 2017 1:33 pm
by robgeerts
jozg wrote:Toonz wrote:jozg wrote:Hello Rob,
Thanks for helping.
s
Regards
Untill this is fixed, you can fill the settings file with:
{"domoticzHost":"192.168.1.3","domoticzPassword":"U21hcnQy0cg==","domoticzPort":"8084","domoticzUsername":"YWW4="}
