I am a happy user of a rooted Toon thanx to this forum.
I noticed that my meter-unit is a bit to far from the Toon unit as Toon does not allway's get new energie-readings.
I know there is a official Toon extender, but i can't find it in e.g. a store on-line.. does anybody know where to get one (when using a rooted Toon, so i probably can't get one from Eneco) or create a DIY solution?
Thanx in advance and keep up the great work!
WBMK
Toon extender?
Re: Toon extender?
I think any Toon compatible z-wave plug will be able to extend your network.
Since z-wave is a mesh network, the message should find their destination using other connected devices.
I believe the Toon repeater is from a brand called everspring, see here: https://forum.toon.nl/storingen-problem ... #post10427
I can't find the repeaters online, but the plugs should repeat just fine... https://www.robbshop.nl/manufacturers/everspring
Re: Toon extender?
Thanx Rudolf!
I'll have a look.
I'll have a look.
- Administrator
Re: Toon extender?
The "Everspring an157-2" was the repeater/z-wave plug Eneco supplied for a while, i guess that every Z-wave wall plug should repeat the signal as the Meteradapter is a z-wave device too.
Other Z-wave wall plugs that i know of:
Fibaro Wall Plug - 55e - Robbshop
Neo CoolCam Wall Plug - 27,50 - marktplaats.
Re: Toon extender?
Thanx TerrorSource, i am looking into buying one!
