VNC acces on latest firmware
Forum about the tweaking of the Eneco Toon.
Moderator: marcelr
Re: VNC acces on latest firmware
Postby Smiggel » Fri May 11, 2018 7:59 pm
michel30 wrote:Hello,
I run on my OSX realvnc and that works super also with the latest firmware.
I run on my Iphone and Ipad RealVNC and that works also fine.
The version that runs on my Toon is x11vnc_0.9.13-r0.
Hmmm ok. I run version x11vnc_0.9.13-r3_qb2 here. That does not work with RealVNC. I’ll see if I can find your version instead.
Smiggel
Postby Smiggel » Fri May 11, 2018 8:27 pm
Did you do anything special? I installed x11vnc_0.9.13-r0 now and still can’t connect using RealVNC. I get the error: The authentication mechanism requested cannot by provided by the computer.
Smiggel
Postby michel30 » Sat May 12, 2018 9:48 pm
The only thing that I removed was the encryption:
vi /usr/bin/x11vnc
if you take out this line:
CODE: SELECT ALL
       -ssl SAVE -vencrypt nodh:plain:support -usepw  \
Than you will have no encryption.
michel30
Postby Smiggel » Sat May 12, 2018 10:37 pm
vi /usr/bin/x11vnc
CODE: SELECT ALL
Ah check. That explains why it works on Real VNC. With the encryption enabled it doesn’t work. With the encryption disabled RealVNC works indeed.
Smiggel
Previous
Return to Eneco Toon as Domotica controller
