Toon firmware - update script
Postby mAiden » Sun Dec 16, 2018 4:38 pm
alcomys wrote:When try to use the update script i got this as output on toon.
what is wrong ?
(first try) eneco-xxx-xxxxxx:~# ./update-rooted.sh -f
sh: ./update-rooted.sh: not found
(second try) eneco-xxx-xxxxxx:~# sh update-rooted.sh -f
sh: can't open 'update-rooted.sh'
thanks
That error message means it can't find the file. Are you sure the file is still there, and you typed the name correct?
mAiden
Postby TheHogNL » Sun Dec 16, 2018 4:44 pm
And this is exactly what I mean in the other posts. mAiden is pointing out exactly what is wrong. Even the command line is telling your that the file isn't found. This should tell you that you probably have forgotten the most crucial thing, download the script first.
The update script requires some knowledge of basic linux skills. If you fail you can easily break your just rooted Toon. You have been warned.
Postby alcomys » Sun Dec 16, 2018 5:03 pm
TheHogNL wrote:And this is exactly what I mean in the other posts. mAiden is pointing out exactly what is wrong. Even the command line is telling your that the file isn't found. This should tell you that you probably have forgotten the most crucial thing, download the script first.
the file is there but never mind, i will not ask things again.
you totally right i need a linux course before i can root toon.
till that time i put my toon back on the wall and leave it there.
all the docs i read there was not the information i needed, the docs are some outdated for toons with the newer firmware and the other information is wide spread but some of them i cant use.
want to thank for all the help
alcomys
Postby marcelr » Sun Dec 16, 2018 6:13 pm
If the file is there, what's the output of
ls -l
Postby maikelvds » Mon Dec 17, 2018 10:18 pm
Just updated Toon with the script, worked perfectly.
Nice updates! Thanks a lot!
maikelvds
Postby Rudi » Wed Jan 02, 2019 11:27 pm
Collected errors.pdf
collected errors
(208.44 KiB) Downloaded 21 times
file-1.pdf
file-1
(222.17 KiB) Downloaded 17 times
I am trying to update my just rooted toom from firmware version 3.2.18 to firmware version 4.10.6.
Unfortunately this does noet work due to several errors.
When executing the script with: ./updated-rooted.sh
i see the following error:
see file 1...
I have attached the errors that were dumped in the file: /HCBv2/tmp/opkg-cache/upgrade-qb2.sh.log
I hope that someone can help me with this issue
Rudi
Postby TerrorSource » Thu Jan 03, 2019 9:36 am
file-1.pdf
see file 1...
Looks like your Toon cannot connect to the repo. Maybe because network issues or did you had your Toon "touched" by Quby before?
TerrorSource
Postby TheHogNL » Thu Jan 03, 2019 10:07 am
Did you try to run it again? Could also just be a temporary issue at the eneco servers.
Postby Rudi » Thu Jan 03, 2019 10:09 am
I have bought this TOON via Marktplaats. After that i have immdiately rooted the TOON.
The only touch after that was that it was able to ping with QUBY.
Rudi
Postby Rudi » Thu Jan 03, 2019 10:11 am
I have tried it several times. Also with different firmware.
Rudi
Postby TheHogNL » Thu Jan 03, 2019 12:01 pm
I could help you using teamviewer if you send me your 06-number in a private message. I will then whatsapp you.
Postby TheHogNL » Thu Jan 03, 2019 8:39 pm
I just finished helping you. Your toon was somewhere in between two old updates (caused by the previous owner during an official eneco update) and it took a bit of a effort to fix that. Now your toon is on 4.22.7 :-)
Postby TheHogNL » Mon Jan 21, 2019 7:31 pm
During some updates to 5.0.4 a issue in an installed Sonos app was causing a failed upgrade.
In the newest update script the sonos app will be automatically removed before starting the upgrade.
So, if you do a upgrade and find out that your sonos app is missing, please don't blame me. This was necesarry to keep your toon working. Just reinstall the sonos app afterwards.
Postby Toonz » Mon Jan 21, 2019 8:28 pm
instead blame me :-)
I made a mistake in the installer file for sonos 1.0.4 which didn't surface earlier.
I just released version 1.0.5 which is clean.
Previous
Return to Toon Firmware
