Toon firmware - update script
HansS
Post by HansS »
My etc/resolv.conf pointed to my local DNS first, then to 8.8.8.8. I checked both from Toon with nslookup (by explicitly stating the DNS server it should use as a command line param), and they were both slow. Because of that, and the fact that I do not have slow DNS on any other device as far as I can tell, I didn't think it would matter that my local DNS was in there. However, commenting the local DNS seems to indeed fix the issue. An nslookup specifying local DNS is still slow, so somehow when it's the first entry it will impact direct queries on 8.8.8.8. Still don't know why Toon would have issues with my local DNS, but changing to 8.8.8. only 'resolves' the update issue, thanks.
Return to “Toon Firmware”
