Page 11 of 44
Posted: Fri Jun 08, 2018 6:43 pm
by TheHogNL
Version 2.9 of the script is released which supports the fix for the resources file in version 4.16.8
See also the topic about version 4.16.8
Posted: Sat Jun 09, 2018 10:06 am
by newwolf
TheHogNL wrote:Version 2.9 of the script is released which supports the fix for the resources file in version 4.16.8
I used the script to upgrade from the previous version but it was stuck at 25% in the booting sequence.
Then I was looking for the resources-static-base.rcc file and only the backup was there.
So I think you have to check before renaming it if the zip file with fix is there.
If it's not not there Toon will not boot.
Posted: Sun Jun 10, 2018 8:11 am
by TheHogNL
Ok thanks. I will improve that. However it already checks if the download is succesful so I'm a bit confused what happened in your case.
Did you manage to fix your issue?
Posted: Sun Jun 10, 2018 8:24 am
by TheHogNL
Owh I already see what probably has gone wrong.
The file in the zip is already the correct name "resources-static-base.rcc". I a test setup when I was developing the fix with Toonz we had that file in the zip to contain the version number.
So, the script unpacked the zip file already over the original file and then change that name to backup. So, your backup is the modified resource file. And you are missing the original file now (which you don't need anyway).
I fixed that now.
Posted: Sat Jul 07, 2018 9:52 pm
by Smiggel
Did anyone upgrade to version 4.16.8 with the latest version of the script and is it safe to do it?
Posted: Sat Jul 07, 2018 10:14 pm
by TerrorSource
Smiggel wrote:Did anyone upgrade to version 4.16.8 with the latest version of the script and is it safe to do it?
Should be no issue but there's still a very small risk with upgrading.
Also it's recommended to go to 4.10.6 if your current firmware is below 4.10.6 (and higher then 2.9.26)
Posted: Sat Jul 07, 2018 10:22 pm
by Smiggel
TerrorSource wrote:Smiggel wrote:Did anyone upgrade to version 4.16.8 with the latest version of the script and is it safe to do it?
Already on version 4.15.6 so I guess the version will not be a problem. Will give it a try tomorrow. Thanks.
Posted: Sun Jul 08, 2018 12:25 am
by Toonz
I don't know one single reason to update from 4.15.6 to 4.16.8 to be honest on a rooted Toon. Don't fix what ain't broken. The script will work. Don't forget to download the new resource file as well for 4.16.8 in case you can't resist the temptation
Posted: Sun Jul 08, 2018 7:45 am
by TheHogNL
Toonz wrote:I don't know one single reason to update from 4.15.6 to 4.16.8 to be honest on a rooted Toon. Don't fix what ain't broken. The script will work. Don't forget to download the new resource file as well for 4.16.8 in case you can't resist the temptation
The script does that for you. However I do agree with that the fact 4.16.8 doesn't bring anything new. Keep it at 4.15.6 and wait until a firmware is released with features you really want/need/like.
Posted: Sun Jul 08, 2018 8:59 am
by Smiggel
Hmmm, guess you have a point there. Maybe it’s better to wait.
Thanks
Posted: Mon Jul 09, 2018 9:30 pm
by themman78
hi guys, i bumping into a little problem.
I'm trying to run the auto update script from version 4.9.23 to version 4.10.6 (as instructed in the manual), but getting te message that the script updatescript is changed. md5 is different.
Warning: upgrade script from source server is changed. Do you want to continue downloading the files (if not sure, type no and report in the forums)?
i included the upgrade-qb2.sh file. Can I, and should I, upgrade safely the this version and later to the latest version 4.16.8?
Posted: Tue Jul 10, 2018 7:33 pm
by TheHogNL
themman78 wrote:hi guys, i bumping into a little problem.
Ok that means that Eneco changed their script again. I will look at it someday soon and update the script. Better safe then sorry and wait for me to check it.
Posted: Tue Jul 10, 2018 11:17 pm
by themman78
TheHogNL wrote:themman78 wrote:hi guys, i bumping into a little problem.
It seems that the file I attached was not included in the post. Here's the code of /mnt/data/update/upgrade-qb2.sh:
export PATH="/sbin:/bin:/usr/sbin:/usr/bin:$PATH"
# NOTE: do not prepend !/bin/sh this script is executed directly via execve()
FEATURES="RTC_WRITE INITTAB_PREPARE EXEC_RESUME SUPPORT_REFLAVOR"
NOREBOOT_FROM=""
# check if these packages are still depended upon and if not remove them if they are installed (should be done automatically)
CHECK_QMF_PACKAGES_REMOVED="hcb-upnp hcb-core hcb-web flash-gui flash-qwidget-diy flash-lite-adobe boot-logos hcb-web happ-telmi"
SCRIPTPATH=`realpath $0`
SCRIPTDIR=`dirname $SCRIPTPATH`
SCRIPTNAME=`basename $SCRIPTPATH`
SCRIPTSTATUS=$0.res
export HCB_ARCH="$1"
export HCB_FLAV="$2"
export HCB_VERS="$3"
export ACTION="$4"
HCB_VERS_MAJOR="`echo $HCB_VERS | sed -n -r -e 's,([0-9]+).([0-9]+).([0-9]+),\1,p'`"
HCB_VERS_MINOR="`echo $HCB_VERS | sed -n -r -e 's,([0-9]+).([0-9]+).([0-9]+),\2,p'`"
featureEnabled()
# test if this feature is enabled
echo "$FEATURES" | grep -q "$1"
dropboxMessage()
SUBJECT="$1"
SUBTITLE="$2"
MESSAGE="$3"
ACTIONS="$4"
TRANSLATION="$5"
echo ">> dropboxMessage $MESSAGE"
time=`date +%s`
Message="
<Config>
<message>
<content>$MESSAGE</content>
<subject>$SUBJECT</subject>
<subtitle>$SUBTITLE</subtitle>
<messageType>critical</messageType>
<received_t>$time</received_t>
<internalAddress>dropboxed_$time</internalAddress>
<read_t></read_t>
<readMsgSend>1</readMsgSend>
<hideOnRemove>0</hideOnRemove>
<package>happ_usermsg</package>
<type>message</type>
<name>upgrade_msg</name>
<visibility>1</visibility>$ACTIONS$TRANSLATION
</message>
</Config>"
echo "$Message" > /tmp/dropbox_msg.xml
mv /tmp/dropbox_msg.xml /HCBv2/config/dropbox/
statusSet()
STATUS="$1"
echo "$STATUS" > $SCRIPTSTATUS
echo ">> `date +'%Y-%m-%d %H:%M:%S %z'` (pid $$) $STATUS"
errorExit()
STATUS="$ACTION-error-$1"
STRING="$2"
echo ">> `date +'%Y-%m-%d %H:%M:%S %z'` (pid $$) $STATUS '$STRING'"
exit 1
okExit()
STATUS="$ACTION-ok-$1"
STRING="$2"
echo ">> `date +'%Y-%m-%d %H:%M:%S %z'` (pid $$) exit-0 $STATUS '$STRING'"
exit 0
fbInitTextMode()
# dim down fast
echo '0:2' > /sys/class/backlight/ed2.0-bl.0/ramp_brightness_sync
# setting mode reinits the console (and with it wipes the background)
cat /sys/class/graphics/fb0/modes > /sys/class/graphics/fb0/mode
# unblank
echo 0 > /sys/class/graphics/fb0/blank
# turn off blanking timeouts for terminal
echo -n -e '\33[9;0]\33[14;0]'> /dev/tty0
# clear screen (also done since boot-logos@46)
echo -n -e '\33[2J'> /dev/tty0
# reshow boot image
/etc/init.d/show-fb-image start start
# start output at line 23
echo -n -e '\33[23;0f'> /dev/tty0
fbLinePrint()
echo ">>> fbLinePrint: $1"
echo " $1" > /dev/tty0
fbLineUpdateStatus()
DOTS=" ..."
while sleep 1
do
PERC="`sed /tmp/update.status.vars -n -r -e 's,^.+item=(.+?)&items=(.+?)&.+$,\1,p' 2>/dev/null`"
PERC="${PERC:-0}%"
# do not append newline, \r to beginning of line after print, append space to overwrite prev-longer-sentences
echo -n -e " Voortgang: $PERC ${DOTS:0:3} \r" > /dev/tty0
# shift right
DOTS="${DOTS:5:1}${DOTS:0:5}"
done
# run after S39hostname.sh, before S41networking
EXEC_RESUME_SCRIPT=/etc/rcS.d/S40upgrade-execute-resume.sh
execResumeInProgress()
if featureEnabled EXEC_RESUME
then
if [ "$ACTION" = "execute-resume" ] #[ -f $EXEC_RESUME_SCRIPT ]
then
return 0 # true
fi
fi
return 1 # false
execSanityChecks()
#* opkg_conf_load: Creating temp dir /tmp/opkg-0uAYDE failed: No such file or directory.
if [ ! -w /tmp/ ]
then
fbLinePrint "> Repareren /tmp/"
mount /proc 2>/dev/null
grep -q /var/volatile /proc/mounts || mount /var/volatile
mkdir -p /var/volatile/tmp
[ ! -w /tmp/ ] && fbLinePrint "> Repareren /tmp/ [mislukt]"
fi
# create a file that will resume the upgrade-execute at next boot
execResumeScheduleCheckForNextBoot()
then
if execResumeInProgress
then
# show progress on console
tail -f $SCRIPTPATH.log </dev/null >/dev/console 2>&1 &
echo ">> Detected execute-resume, notifying the user via framebuffer."
fbInitTextMode
fbLinePrint "Aborted software update to version ${HCB_VERS} detected."
fbLinePrint "Resuming update, please wait... do NOT turn off your display during the update."
execSanityChecks
# this means that the file is still here since the last (aborted) upgrade,
# so we actually remove it to prevent an endless upgrade-loop!
#echo ">> Detected execute-resume script from previous run, removing it."
rm -f $EXEC_RESUME_SCRIPT
# start a process that watches /tmp/update.status.vars
fbLineUpdateStatus &
STATUS_UPDATE_PID=$!
echo ">> Spawned /tmp/update.status.vars watcher with PID $STATUS_UPDATE_PID"
# we are running during early boot, HCBv2 apps are not running yet
STOPSTARTAPPS=0
else
echo ">> Creating $EXEC_RESUME_SCRIPT with args '${HCB_ARCH} ${HCB_FLAV} ${HCB_VERS} execute-resume'"
echo "#!/bin/sh" > $EXEC_RESUME_SCRIPT
echo "echo '$0: Aborted upgrade-execute for ${HCB_ARCH}/${HCB_FLAV}/${HCB_VERS} detected,'" >> $EXEC_RESUME_SCRIPT
echo "echo '$0: executing $SCRIPTPATH execute-resume'" >> $EXEC_RESUME_SCRIPT
echo "$SCRIPTPATH ${HCB_ARCH} ${HCB_FLAV} ${HCB_VERS} execute-resume" >> $EXEC_RESUME_SCRIPT
echo "echo '$0: done.'" >> $EXEC_RESUME_SCRIPT
chmod a+x $EXEC_RESUME_SCRIPT
fi
sync
fi
execResumeRemoveCheckForNextBoot()
then
then
# stop the process that watches /tmp/update.status.vars
echo ">> Killing /tmp/update.status.vars watcher with PID $STATUS_UPDATE_PID"
kill -9 $STATUS_UPDATE_PID
if [ "$REBOOT" = "1" ]
then
fbLinePrint "Software update completed, the display is rebooting..."
else
fbLinePrint "Software update completed, the display is starting..."
fi
# give people time to read the message
sleep 3
fi
echo ">> Removing $EXEC_RESUME_SCRIPT"
fi
# migrate the files in /HCBv2/tmp/opkg-cache to /mnt/data/update if this update is running from the new location
migratePkgCacheDirectory()
OLD_PKGCACHE='/HCBv2/tmp/opkg-cache'
NEW_PKGCACHE='/mnt/data/update'
# only migrate if this script is running from the new location
# otherwise, this could be a execute-resume run (new hcb_config, old script location)
if [ -d "$OLD_PKGCACHE" -a $SCRIPTDIR = $NEW_PKGCACHE ]
then
echo ">> migrating files to '${NEW_PKGCACHE}' ..."
if [ ! -d "$NEW_PKGCACHE" ]
then
# Normally that should not happen since the directory should be created by /etc/init.d/populate-volatile.sh
echo "the directory '$NEW_PKGCACHE' is missing."
mkdir -p "$NEW_PKGCACHE" || errorExit "opkg-migrate" "Failed to create the directory '$NEW_PKGCACHE'"
echo "the directory '$NEW_PKGCACHE' was created."
fi
# If the dir is empty, don't do anything otherwise 'mv' will fail
if [ "$(ls -A "$OLD_PKGCACHE")" ]
then
mv "$OLD_PKGCACHE"/* "$NEW_PKGCACHE"/ || echo "failed to move files to '$NEW_PKGCACHE'"
else
echo 'nothing to migrate'
fi
rmdir "$OLD_PKGCACHE" || echo "failed to remove the old directory '$OLD_PKGCACHE'."
sync
echo ">> migrating files to '${NEW_PKGCACHE}': finished"
fi
checkForUniFlavorVersion()
if featureEnabled SUPPORT_REFLAVOR
then
if ([ "$HCB_FLAV" = "qby" -o "$HCB_FLAV" = "ene" -o "$HCB_FLAV" = "ves" -o "$HCB_FLAV" = "euk" ] && \
([ $HCB_VERS_MAJOR -gt 4 ] || [ $HCB_VERS_MAJOR -eq 4 -a $HCB_VERS_MINOR -ge 11 ])) || \
([ "$HCB_FLAV" = "ebl" ] && ([ $HCB_VERS_MAJOR -gt 4 ] || [ $HCB_VERS_MAJOR -eq 4 -a $HCB_VERS_MINOR -ge 16 ]))
then
echo ">> Overriding HCB_FLAV to uni!"
HCB_FLAV="uni"
fi
fi
getInstalledFlavor()
OLDFLAV=`opkg list-installed base-$HCB_ARCH-\* | sed -r -e "s/base-$HCB_ARCH-([a-z]{3})\s.*/\1/"`
reflavorRequired()
[ "$OLDFLAV" != "$HCB_FLAV" ]
getTenantPackage()
case $OLDFLAV in
qby)
TENANT_PKG=tenant-qutility
ene)
TENANT_PKG=tenant-eneco-nl
ves)
TENANT_PKG=tenant-viesgo-es
euk)
TENANT_PKG=tenant-engie-uk
ebl)
TENANT_PKG=tenant-engie-be
echo ">> Unknown old flavor! Aborting."
errorExit "unknown-old-flavor" "Unknown old flavor $OLDFLAV! Aborting."
esac
echo ""
echo ">> `date +'%Y-%m-%d %H:%M:%S %z'` (pid $$) $SCRIPTNAME $@"
echo ""
#echo "$$" > $SCRIPTPATH.pid
statusSet "$ACTION"
cd $SCRIPTDIR
PKGCACHE=$SCRIPTDIR
BASE_FEED_URL="http://feed.hae.orig/feeds"
CN="`hostname`"
REBOOT=1
STOPSTARTAPPS=1
CLEANUP="`grep -q '^root:DISABLED' /etc/passwd 2>/dev/null && echo 1`"
# allow for :1337 on localhost and on any (see hcb_comm.CommIfaces=any)
HCBV2_UP="`netstat -ltn 2>&1 | grep -q ':1337 ' && echo 1`"
# expose our life story so support can access it - Part I
if [ -w /qmf/log/ ]
then
ln -f -s $SCRIPTPATH.log /qmf/log/last-update.log
elif [ -w /HCBv2/log/ ]
then
ln -f -s $SCRIPTPATH.log /HCBv2/log/last-update.log
fi
# Migration of files from the old to new location is performed the very first time
# after the hcb_config supports the new location.
# See if this version is replaced by the uni version
HCB_AFV="${HCB_ARCH}/${HCB_FLAV}/${HCB_VERS}"
case $ACTION in
prepare)
statusSet "preparing"
# clean up some space for downloading new packages
rm -f $PKGCACHE/*.ipk
# Hotfix for writing System Time to RTC (ET-794)
if featureEnabled RTC_WRITE
then
echo ">> Hotfix for writing System Time to RTC"
echo "Hardware Clock before: `hwclock --show`"
# here we know the system time is ok: script downloaded -> internet -> hae-timesync
hwclock --systohc --utc
echo "Hardware Clock after : `hwclock --show`"
fi
# set extra pkg system feeds
EXTRA_FEEDS="`wget -q "${BASE_FEED_URL}/${HCB_ARCH}/${HCB_FLAV}/${HCB_VERS}/SystemFeed" -O -`"
if [ "$EXTRA_FEEDS" = "" ]
then
echo "Failed retrieving '${BASE_FEED_URL}/${HCB_ARCH}/${HCB_FLAV}/${HCB_VERS}/SystemFeed', trying again verbosely:"
wget "${BASE_FEED_URL}/${HCB_ARCH}/${HCB_FLAV}/${HCB_VERS}/SystemFeed" -O - 2>&1
errorExit "dl-afv" "AFV download failed Maybe sync or non-existing?"
fi
# set correct feed location for initial install
rm -f /etc/opkg/*-feed.conf /usr/lib/opkg/lists/*
echo "src/gz base ${BASE_FEED_URL}/${HCB_ARCH}/${HCB_FLAV}/${HCB_VERS}" > /etc/opkg/base-feed.conf
echo "$EXTRA_FEEDS" | {
while read EF
do
EF_NAME="`echo "$EF" | cut -d ' ' -f1`"
EF_PATH="`echo "$EF" | cut -d ' ' -f2`"
echo "src/gz ${EF_NAME} ${BASE_FEED_URL}/${HCB_ARCH}/${EF_PATH}" > /etc/opkg/${EF_NAME}-feed.conf
done;
echo ">> configured opkg feeds:"
cat /etc/opkg/*-feed.conf
# convenience helper to download packages to cache while capturing output into $OPKG_OUTPUT
_opkg_download()
local step="$1"
shift
local cmd="opkg --cache $PKGCACHE --download-only $@"
echo ">> ${cmd}"
# prefix output with command, note that trailing newline(s) are eaten by $( )
OPKG_OUTPUT="$(echo -e "\n> ${cmd}\n\n ")"
# open extra fd pointing to stdout
exec 9>&1
#ls -la /proc/self/fd/
# exec cmd and capture stdout+stderr output, duplicate output to stdout-at-fd9, append output to OPKG_OUTPUT
{ OPKG_OUTPUT="${OPKG_OUTPUT}`{ ${cmd} 2>&1; echo "> Exit code: \$?"; } | tee -a /proc/self/fd/9`"; } 2>&1
# close it again
exec 9>&-
# parse + store exit code of $cmd
OPKG_EXITCODE="$(echo "${OPKG_OUTPUT}" | tail -n1 | sed -r -e 's,> Exit code: (.+),\1,')"
# * opkg_install_pkg: Package xxx md5sum mismatch. Either the opkg or the package index are corrupt.
if echo "$OPKG_OUTPUT" | grep -q 'md5sum mismatch'
then
errorExit "opkg-${step}-md5sum" "opkg found an md5sum mismatch: removed *.ipk!"
fi
# Test HTTP errors before signature errors
# * opkg_download: Failed to download http://...ipk: Timeout was reached.
# * opkg_download: Failed to download http://...ipk: Couldn't connect to server.
# * opkg_download: Failed to download http://.../Packages.sig: HTTP response code said error.
if echo "$OPKG_OUTPUT" | grep -q 'Failed to download'
then
errorExit "opkg-${step}-download" "opkg failed to download"
fi
_opkg_download "update" update
# Signature check failed.
# Remove wrong Signature file.
if echo "$OPKG_OUTPUT" | grep -q 'Signature check failed.'
then
errorExit "opkg-update-sig-failed" "opkg update Signature check failed"
fi
# Collected errors:
if [ "$OPKG_EXITCODE" != "0" ]
then
# generic error
errorExit "opkg-update" "Exit code $OPKG_EXITCODE for: opkg update"
fi
getInstalledFlavor
if featureEnabled SUPPORT_REFLAVOR && reflavorRequired
then
getTenantPackage
_opkg_download "download-flav" install base-$HCB_ARCH-$HCB_FLAV $TENANT_PKG
then
errorExit "opkg-upgrade-flav-download" "Exit code $OPKG_EXITCODE for opkg flav download"
fi
fi
# time to do the big one :)
_opkg_download "download" upgrade
# intermediate cleanup
rm -rf /tmp/opkg-*
# ensure the log greps below always work
sync
# generic error, most of which we do not want to break the upgrade
# * resolve_conffiles: Existing conffile /etc/ca-certificates.conf is different from the conffile in the new package. The new conffile will be placed at /etc/ca-certificates.conf-opkg.
then
echo errorExit "opkg-upgrade" "Exit code $OPKG_EXITCODE for: opkg upgrade" "IGNORED: continuing..."
fi
echo ">> downloaded:"
du -ch $PKGCACHE/*.ipk | grep total
statusSet "prepared"
if featureEnabled FORCE_EXECUTE
then
echo "FORCE_EXECUTE enabled, sending DoFirmwareUpdate"
/HCBv2/bin/bxt -u `hostname`:swf-gui -d :hcb_config -s specific1 -n DoFirmwareUpdate -a version -v $HCB_VERS -w 0
fi
execute|execute-resume)
statusSet "executing"
#OLD_VERSION="`cat /etc/opkg/base-feed.conf | cut -d'/' -f 8 | cut -d'.' -f1-2`"
# note base-feed.conf is already overwritten here!
OLD_MAJOR_MINOR="`opkg list_installed 'base-*-*' | sed -r -e 's,^.+ - ([0-9]+\.[0-9]+)\.[0-9]+-.+$,\\1,'`"
OLD_MAJOR_MINOR_MICRO="`opkg list_installed 'base-*-*' | sed -r -e 's,^.+ - ([0-9]+\.[0-9]+\.[0-9]+)-.+$,\\1,'`"
# check if we can suffice with a "soft reboot"
if featureEnabled NOREBOOT_FROM
then
# (grep --word-regexp: Select only those lines containing matches that form whole words.)
# check for word-match in list of versions
if echo "$NOREBOOT_FROM" | grep -q -w "$OLD_MAJOR_MINOR_MICRO"
then
echo ">> Current version $OLD_MAJOR_MINOR_MICRO in ($NOREBOOT_FROM), doing soft reboot."
REBOOT=0
else
echo ">> Current version $OLD_MAJOR_MINOR_MICRO not in ($NOREBOOT_FROM), doing regular reboot."
fi
fi
if [ "$HCBV2_UP" ]
then
MSG="Upgrading application software from version '$OLD_MAJOR_MINOR_MICRO' to '$HCB_AFV'."
echo ">> Logging \"$MSG\" to 99_DEBUG.log.json"
/HCBv2/bin/bxt \
-d $CN:hcb_log \
-s Logger \
-n LogMessage \
-a facility -v 1 \
-a categoryId -v 99 \
-a timestampGenerated -v "`date +'%Y-%m-%d %H:%M:%S %z'`" \
-a logText -v "$MSG" \
-w 0 >/dev/null 2>/dev/null &
sleep 1
echo ">> Sending InitiatePreExit to hcb_config."
/HCBv2/bin/bxt \
-d $CN:hcb_config \
-n InitiatePreExit \
fi
if [ "$STOPSTARTAPPS" = "1" ]
then
echo ">> Sleep 2, give time to return 'upgrade started' messages to UI"
sleep 2
echo ">> Stopping HCBv2 apps + prevent restart..."
/etc/init.d/HCBv2 stop
fi
# prevent restarting during upgrade
echo 'exit' > /tmp/etc-default-HCBv2
chmod a+x /tmp/etc-default-HCBv2
then
# kill this one especially, left running in inittab by design.
killall -9 hcb_netcon
# NOTE: flash keeps running during upgrade, restart by inittab would fail because of /tmp/etc-default-HCBv2
echo ">> Disabling watchdog /dev/watchdog"
rm -f /dev/watchdog
mknod /dev/watchdog c 10 130
# make sure we don't reboot:
echo V > /dev/watchdog
rm -f /dev/watchdog
fi
# These packages will be installed before the kernel updates
if [ "`opkg list kernel-image-\* | grep -c -e '^kernel-image-'`" != "1" ]
then
# Install firmware-zwave-ctrlr with --nodeps
# Otherwise kernel upgrades are already installed at this point, because of dependencies
# We assume the kernel-module-zwave300 to already have been installed at this point
echo ">> opkg --cache $PKGCACHE install firmware-zwave-ctrlr --nodeps"
opkg --cache $PKGCACHE install firmware-zwave-ctrlr --nodeps 2>&1;
fi
getInstalledFlavor
then
getTenantPackage
echo ">> opkg remove base-$HCB_ARCH-$OLDFLAV"
opkg remove base-$HCB_ARCH-$OLDFLAV 2>&1
for RETRY_ON_EXITCODE in 1 2 3
do
echo ">> opkg --cache $PKGCACHE install base-$HCB_ARCH-$HCB_FLAV $TENANT_PKG # attempt $RETRY_ON_EXITCODE"
opkg --cache $PKGCACHE install base-$HCB_ARCH-$HCB_FLAV $TENANT_PKG 2>&1; EXITCODE=$?
if [ "$EXITCODE" = "0" ]
then
break
fi
done
[ "$EXITCODE" != "0" ] && errorExit "opkg-upgrade-flav-install" "Exit code $EXITCODE for opkg flav install"
fi
# opkg sometimes (incorrectly?) returns 255, therefore do 3 retries
do
echo ">> opkg --cache $PKGCACHE upgrade - attempt $RETRY_ON_EXITCODE"
opkg --cache $PKGCACHE upgrade 2>&1; EXITCODE=$?
echo ">> exitcode for opkg --cache $PKGCACHE upgrade was $EXITCODE"
then
break
fi
done
# did any of the packages just installed request a reboot?
if [ -f /tmp/opkg_reboot ]
then
echo ">> Detected /tmp/opkg_reboot, will reboot when done."
REBOOT=1
fi
rm -rf /tmp/opkg-*
[ "$CLEANUP" = "1" ] && rm -rf /var/lib/opkg/*
sync
if [ "$EXITCODE" != "0" ]
then
# TODO: check if we can use /tmp/update.status.vars to communicate error
# to user in a more verbose manner instead of fb img "upfail"?
# stop flash/qt anim
killall -9 flash qt-gui
# show upgrade error msg
/etc/init.d/show-fb-image upfail
# and bail out...
errorExit "opkg-upgrade" "Exit code $EXITCODE for: opkg upgrade"
fi
echo ">> Checking if these packages are not installed: $CHECK_QMF_PACKAGES_REMOVED"
for a in $CHECK_QMF_PACKAGES_REMOVED
do
echo "checking $a"
if ! opkg depends base-$HCB_ARCH-$HCB_FLAV | grep -q $a && [ "`opkg list_installed $a`" != "" ]
then
echo "removing $a as it is no longer depended upon by base package and it is not removed."
opkg remove --force-depends $a
fi
done
# upgrade OK: remove tmpfiles
echo ">> upgrade OK: removing cached package files..."
if [ "$CLEANUP" = "1" ]
then
# expose our life story so support can access it - Part II
# Remove everything but our current log file
find $PKGCACHE -name _opkg.\*.script.\* ! -name $SCRIPTNAME.log | xargs rm -f
fi
sync
then
# prepare the contents of inittab for next boot, only writes if changed
if featureEnabled INITTAB_PREPARE
then
rm -f /tmp/etc-default-HCBv2
/etc/init.d/HCBv2 prepare-start
sync
fi
# TODO: trigger watchdog here?
echo ">> Done, scheduling reboot in 2 secs..."
#removed shutdown
else # no reboot
# remove the "exit" in this file, so flash+HCBv2 apps can start:
# now we restart them?
then
echo ">> Restarting flash..."
# dims down, give time to quickly load flash + dim up
sleep 3
echo ">> Starting HCBv2 apps..."
/etc/init.d/HCBv2 start
fi
echo ">> Done."
fi
# prevent last _opkg.*.script.sh.res file from being left behind
if [ "$CLEANUP" != "1" ]
then
statusSet "executed"
fi
echo ">> Unknown ACTION arg! Aborting."
errorExit "unknown-action" "Unknown ACTION arg! Aborting."
esac
echo ">> `date +'%Y-%m-%d %H:%M:%S %z'` (pid $$) exit-0 $SCRIPTNAME $@"
) </dev/null >>$SCRIPTPATH.log 2>&1
I will be waiting for your verdict if it's safe to proceed.
Posted: Fri Jul 13, 2018 10:05 pm
by TheHogNL
It's ok. They added some disk space usage/free space so the update doesn't fail if disk free space is critically low. I have updated the script to containt a new md5 hash.
Posted: Mon Jul 23, 2018 9:13 pm
by mAiden
Can your script also downgrade @TheHogNL ?
Get the following notification to a forced update to 4.18.8..
INIT: Id "qtqt" respawning too fast: disabled for 5 minutes
