Fully automated rooting script
Re: Fully automated rooting script
Postby Monoposto013 » Wed Oct 02, 2019 11:23 am
Aaah, don't know what happened, but lost my chrony.conf :oops: completely empty..
What to do? Just wanted to make modifications to the timeserver.
Monoposto013
Postby TheHogNL » Wed Oct 02, 2019 11:33 am
Monoposto013 wrote:Aaah, don't know what happened, but lost my chrony.conf :oops: completely empty..
In the chrony.ipk package there is a new fresh conf for you.
Just start the update-rooted.sh script with option -o (to open the VPN and setup the opkg repository for you). Then type:
opkg update
opkg remove --force-depends chrony
opkg install chrony
Postby Monoposto013 » Wed Oct 02, 2019 11:58 am
opkg update
opkg install chrony
Worked like a charm! Thanks!!
I'm still struggling with what to do next?
Rooted the Toon using the automated script, but have seen a lot of modifications in this forum and elsewhere on the internet.
-I would like the Toon not to ping quby
-use a different timeserver
-enable all the Toon/Eneco features including Zon
-install the Toonstore
Where to start? I mean, is this all done through SSH? Are there scripts available to make these adjustments?
Any help is welcome :P
Monoposto013
Postby TheHogNL » Wed Oct 02, 2019 12:29 pm
Monoposto013 wrote:I'm still struggling with what to do next?
That is what the update-rooted.sh -f option is for :-)
Postby Monoposto013 » Wed Oct 02, 2019 1:05 pm
TheHogNL wrote:That is what the update-rooted.sh -f option is for :-)
POWERFUL!! Great work, hats off!! This is even better than I thought :D
Monoposto013
Postby Knol010 » Wed Nov 13, 2019 9:02 am
Ishimaru wrote:Hi,
can someone help me with this issue?
root@raspberrypi:~/ToonRooter# sudo python . --jtag-available
INFO:__main__:Starting up...
CRITICAL:__main__:Cannot autodetect jtag hardware
root@raspberrypi:~/ToonRooter# sudo python . --jtag-hardware rpi3
INFO:__main__:Written private and public key pair to ./id_rsa and ./id_rsa.pub, respectively
INFO:rooter:Waiting for Toon to restart
--- waiting forever :-) --
root@raspberrypi:~/ToonRooter# cat /proc/cpuinfo
processor : 0
model name : ARMv7 Processor rev 4 (v7l)
BogoMIPS : 38.40
Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 1
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 2
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 3
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
Hardware : BCM2835
Revision : 2a02082
Serial : 0000000003d4f64b
I have the same problem and don't no what now.
I checked the wiring 1000 times. When I try to root without the script I can change uboot and get in the root shell. I then get stuck with the internet connection...
Knol010
Postby TheHogNL » Wed Nov 13, 2019 7:53 pm
Most users forget to disable the serial console on the raspberry pi (using raspi_config). That results in the toonrooter and the serial console using the serial port at the same time.
Postby Knol010 » Fri Nov 15, 2019 8:26 am
TheHogNL wrote:Most users forget to disable the serial console on the raspberry pi (using raspi_config). That results in the toonrooter and the serial console using the serial port at the same time.
Now I get this message:
pi@raspberrypi:~/ToonRooter $ sudo python . --jtag-hardware rpi3
INFO:rooter:Toon has U-Boot version 2010.09-R10
ERROR:rooter:Unable to log in using password (need JTAG, but it's disabled)
I have a JTAG and I can flash the boot loader with that, but when I done that and press the reset button in the root shell nothing happens so I can't go on from there neither.
Knol010
Postby TheHogNL » Fri Nov 15, 2019 8:56 am
You need to add "--jtag-available" as commandline option
Postby Knol010 » Fri Nov 15, 2019 10:19 am
When i only use --jtag avaiable i get:
pi@raspberrypi:~/ToonRooter $ sudo python . ---jtag-available
So i have to combine jtag avaiable and jtag hardware?
How do i do that?
Thanks
Knol010
Postby TheHogNL » Fri Nov 15, 2019 11:15 am
How do i do that?
Thanks
I did say you needed to add the option. It is really not that hard...
sudo python . --jtag-hardware rpi3 ---jtag-available
Postby Knol010 » Fri Nov 15, 2019 12:19 pm
How do i do that?
Thanks
For me it is. Thanks it worked nu Toon is rooted now!
Knol010
Postby TheHogNL » Fri Nov 15, 2019 12:54 pm
Knol010 wrote:For me it is. Thanks it worked nu Toon is rooted now!
Welcome to the club ;-)
Previous
Return to Toon Rooting
