Use an Arduino as USB to TTL converter for rooting Toon
Postby bartch » Sat Mar 24, 2018 9:36 am
this week I received my cheap aliexpress usb to ttl converter..it did not work..
Then i found this video about using a arduino as usb to ttl converter.
https://www.youtube.com/watch?v=qqSLwK1DP8Q
Fortunately i had an old Arduino laying around :)
It works perfectly!
Notice that you have to connect the TXD>1 from the arduino to the TXD on your Toon
and the RXD<0 from the arduino to the RXD on your Toon.
(Arduino has a strange way to show where it's TXD and RXD sits on the board..)
Rooting my Toon went perfectly this way!
Thank you all for the great and usefull information on this forum.
Bart
bartch
Re: Use an Arduino as USB to TTL converter for rooting Toon
Postby TheHogNL » Sat Mar 24, 2018 2:08 pm
That's indeed a nice working solution.
Another user connected a (5 euro) wemos to the TTL interface of Toon using ESP-link to connect to the console over wifi: https://www.domoticaforum.eu/viewtopic. ... mos#p83233
Postby rbak » Tue Jan 01, 2019 11:33 pm
I am new to rooting a Toon and I am gathering information to make a clear step by step plan how to root my own Toon.
Sofar I have noticed several extremely long threads about this topic and I also came across some videos of Youtube. All seem to indicate you need to use a USB to TTL adapter that needs to be set to 3.3V. Yet the example with using an Arduino (Uno) seems to work as well. I believe that when you use an Arduino it will be using 5V instead of the 3.3V mentioned. Am I overlooking something here?
So the key question is whether or not it is safe to use a Arduino (Uno) with the RESET connected to GND or whether it is better to use an USB to TTL adapter with the option to set it to 3.3V instead. I do not want to risk damaging my Toon but on the other hand would like to use my Arduino (Uno) if it is safe to do so. I alreday ordered an USB to TTL FTDI adapter that can be set to 3.3V but as it can take some time to arrive I am intersted to consider the Arduino option as well.
Any thoughts?
rbak
Postby marcelr » Wed Jan 02, 2019 12:57 pm
rbak wrote:Sofar I have noticed several extremely long threads about this topic and I also came across some videos of Youtube. All seem to indicate you need to use a USB to TTL adapter that needs to be set to 3.3V. Yet the example with using an Arduino (Uno) seems to work as well. I believe that when you use an Arduino it will be using 5V instead of the 3.3V mentioned. Am I overlooking something here?
We also have a manuals/tutorials section.
You may find this topic useful:
https://www.domoticaforum.eu/viewtopic. ... 235#p82533
Postby TheHogNL » Wed Jan 02, 2019 1:19 pm
rbak wrote:I am new to rooting a Toon and I am gathering information to make a clear step by step plan how to root my own Toon.
Any thoughts?
Arduino is mostly 5v indeed (only some specific boards have 3.3v). So connecting that to the Toon could fry the TTL port of the Toon. But the topic starter did this succesfully. So or he got lucky or has a 3.3v arduino board.
Better safe than sorry and wait for your 3.3v TTL adapter.
Postby rbak » Wed Jan 02, 2019 8:16 pm
marcelr wrote:We also have a manuals/tutorials section.
Yes I have noticed and this will indeed be the basis I will use for rooting my Toon. Thanks for the great job on this!
TheHogNL wrote:Arduino is mostly 5v indeed (only some specific boards have 3.3v). So connecting that to the Toon could fry the TTL port of the Toon. But the topic starter did this succesfully. So or he got lucky or has a 3.3v arduino board.
That was exactly the reason why I responded to this thread. If the 3.3V is mandatory, the use of the Arduino Uno as shown in the video of the topic starter could indeed fry the TTL port of the Toon. So a warning in this thread might be in place. I will wait for my 3.3V USB to TTL adapter to arrive. Unfortunately that probably means a few more weeks patience as I ordered it only recently from China. On a positive note that also means a few more weeks to prepare :D
rbak
Postby TheHogNL » Wed Jan 02, 2019 9:40 pm
Just hoping it will arrive before the winter period ends :-)
But then again, if you fail and it is already spring your house doesn't need the thermostat anymore to heat up :-)
Maybe you have already read this but you can also use a Rasberry PI or a ESP8266 (Wemos for example) if you happen to have it.
Postby rbak » Wed Jan 02, 2019 10:55 pm
TheHogNL wrote:Maybe you have already read this but you can also use a Rasberry PI or a ESP8266 (Wemos for example) if you happen to have it.
Yes I have noticed and I do have an Rasberry Pi as well. However it is currently still in use as an Astrerisk SIP switch so I prefer not to use it for rooting my Toon. In that case I rather wait for the 3.3V USB to TTL adapter to arrive. Also to be honest I am not very familiar with Linux so I feel less confident using the Rasberry Pi for the purpose of rooting my Toon.
rbak
Postby TheHogNL » Thu Jan 03, 2019 7:49 am
Using the RaspPi rooter is so much easier than using the ttl cables. And is even mandatory if your Toon is too new (have a uboot with unknown password). The guide for that on https://github.com/martenjacobs/ToonRooter is easy to follow.
And if your are lucky and have the older Toon uboot version then you can still use the Pi to connect to the toon using TTL. Only connect the tx, rx and gnd from that manual.
And, better start a bit with Linux as a rooted Toon also requires at least the same knowledge :-)
You can easily use the same Pi which is running your Asterisk. I will not interfere.
Return to Toon Rooting
