toon activation problem
Posted: Wed Apr 18, 2018 8:15 am
by patricx
Hello
i have changed config_happ_scsync.xml in the folder /HCBv2/config
but every time i reboot the toon, toon overwrite that file and come back in the wizard menu.
please can someone help me ?
patrick
Re: toon activation problem
Posted: Wed Apr 18, 2018 11:06 am
by flamingbob
Simple questions first. Have you disabled the ipsec tunnel? If you still talk to the mothership it always override that exact file.
Posted: Wed Apr 18, 2018 7:36 pm
by patricx
i have change the line
ovpn:235:respawn:/usr/sbin/openvpn --config /etc/openvpn/vpn.conf --verb 0 >/dev/null 2>&1
in
#ovpn:235:respawn:/usr/sbin/openvpn --config /etc/openvpn/vpn.conf --verb 0 >/dev/null 2>&1
but the same problem
Posted: Thu Apr 19, 2018 8:01 am
by TheHogNL
patricx wrote:i have change the line
in
That is impossible. The scsync file is only overwritten if the openvpn is running. Did you reboot after editing the line (add the # in front)?
After the reboot, change the scsync file (look in the forum for the exact changes you need to make, this is answered over and over again), reboot again, and it would be fine then.
Posted: Thu Apr 19, 2018 12:11 pm
by EJanus
Or (but this is perhaps to simple
) it could be that saving the file goes wrong.
So open config_happ_scsync.xml
edit the file
save
close
open config_happ_scsync.xml again
Check if your changes were in fact saved.
Posted: Thu Apr 19, 2018 12:37 pm
by patricx
when i check the file config_happ_scsync.xml that's i write to the toon it's ok.
when i go to the activation center it's tell that er is no conection to the activation center.
I have follow al instructions but i do not see what's wrong.
is the a other way to see if the openvpn is running ?
Posted: Thu Apr 19, 2018 4:01 pm
by EJanus
But what is your problem exactly?
If you want to change the VPN status, you can do that in the file /etc/inittab and put a # in front of the line ovpn
respawn:/usr/sbin/openvpn --config /etc/openvpn/vpn.conf --verb 0 >/dev/null 2>&1 as stated in the root manual.
If you want to disable the wizard menu, you can try to do that in de file config_happ_scsync.xml and check if this is there: <activated>1</activated><wizardDone>1</wizardDone> (in line 11).
Posted: Thu Apr 19, 2018 4:23 pm
by patricx
Ejanus,
I have do everythink follow the root manual .
i have put # for the openvpn row and i have change config_happ_scsync.xml as you write.
I have root the toon by a rapberry pi with that script without problems or errors.
and all other thinks in the manual i have do it also.
but every time i reboot te toon it overwrite the config_happ_scsync.xml file that's te problem and i can not find the solution.
Posted: Thu Apr 19, 2018 7:45 pm
by patricx
in /etc/inittab
i have change flas:245:respawn:/usr/bin/startflash >/dev/null 2>&1 to #flas:245:respawn:/usr/bin/startflash >/dev/null 2>&1
and reboot the toon but then it's do not start to the home screen.
remove the # and reboot again and now the toon work
Posted: Fri Apr 20, 2018 12:08 am
by EJanus
So you put the # in front of: flas:245:respawn:/usr/bin/startflash >/dev/null 2>&1
That is not going to work and Toon will not boot correctly.
You should put the # in front of: ovpn
So it looks like:
# ovpn
The # tells Toon to ignore the line after the #. So Toon can not connect to the Eneco server using vpn.
Good luck!
Posted: Thu Mar 14, 2019 7:09 pm
by DAP61
I bought myself a rooted Toon 43 weeks ago.
I updated it to 5.0.4.
But i can't get past the activation code.
And i'm not allowed to change the config file.
Who can tell me what to do so I can get more use out of TOON then yust a thermostat?
Posted: Fri Mar 15, 2019 12:07 am
by TerrorSource
DAP61 wrote:Hello,
What did you already read on this forum? Solution and additional possibilities are mentioned everywhere!
Posted: Fri Mar 15, 2019 12:18 am
by TheHogNL
Why? You are root. You can do everything you want.
