Baxi Slim, does not work without a thermostat
Posted: Sat May 12, 2018 6:50 pm
With a thermostat, everything works well.
With a jumper instead of a thermostat when sending the command CS=XX a flag is set central heating enable (CH=1)
but the burner does not turn on, experienced to find out that the burner is activated only if the flag is activated central heating mode
When operating from a thermostat, the flag central heating mode active.
The question is how to activate central heating mode forcibly?
Thank you
Thank you
