Toon app: Home Assistant controller
Re: Toon app: Home Assistant controller
Postby timkoers » Mon Jul 30, 2018 2:09 pm
Since there is another HomeAssistant app available for the Toon (https://www.domoticaforum.eu/viewtopic.php?f=87&t=12089), which has dynamic objects so you can add virtually unlimited switches etc.
My suggestion, just like marcelr's and Luc_S' is to combine forces and greate a good stable app.
Which layout do you preffer if I may ask?
The one of this thread or the one posted in the link above?
timkoers
Postby Hypermobile » Mon Jul 30, 2018 4:46 pm
you need to type a Password....
But where to put Username of Domoticz??
it does not work right now
Hypermobile
Postby michel30 » Thu Aug 02, 2018 8:29 am
This is build for Home Assistant controller not for Domoticz.
You need to build Home Assistant center.
michel30
Postby Sundown89 » Mon Aug 20, 2018 9:19 am
timkoers wrote:Which layout do you preffer if I may ask?
I prefer your layout. I think it is a great idea to combine the two apps into one, and both work on it. Maybe with some settings so users can choose between some parts that are different.
Keep up the good work! I was thinking about buying a wall mounted tablet, but now I'll wait and see how whether this app is going to satisfy my needs.
Sundown89
Postby TheRedBull » Sun Sep 02, 2018 12:54 pm
@marcelr can you update the current application on the toon store?
The current version doesnt support SSL, but the new version does: https://github.com/Luc-S/Toon-HASS
Would really like to see this app updated! Would help a lot in my home automation :)
TheRedBull
Postby legalr » Tue Sep 04, 2018 9:46 am
Are there issues withe the Home Assistant from the Toon Store in combination with the latest firware?
I fill out the required fields, User, PW. Port, but no connection to my Home Assistant.
something else to check/do?
legalr
Postby dennis071nl » Mon Sep 17, 2018 7:43 pm
Ok guys, i actually don't wanna wait until this release it placed in the toon store, is it just a matter of replacing the files on my toon to install this version??
TheRedBull wrote:@marcelr can you update the current application on the toon store?
dennis071nl
Postby Toonz » Mon Sep 17, 2018 8:01 pm
Yes, it is...
Postby Toonz » Mon Sep 17, 2018 8:03 pm
just that updating later via the ToonStore might be an issue. In that case remove the app manually and install again via the ToonStore
Postby Toonz » Mon Sep 17, 2018 9:42 pm
Homescreenassistent version 1.0.1 is available in the ToonStore.
Changelog:
- implemented SSL
Note for the author: Your screens are not scaled properly on a Toon 2 :-).
You need to use the isNxt variable to set different value for the screen element sizes and positions.
(see any other app for examples)
Postby Luc_S » Tue Sep 18, 2018 10:08 am
Hi all, thanks for the feedback. Just came back from holiday so I’ll try to look into it ASAP. Appearantly there’s also a new user system implemented in the latest HA update? Got some work to do :)
Cheers!
Luc_S
Postby Luc_S » Sun Sep 23, 2018 10:12 am
As of Home Assistant version 0.73.0 it's needed to have 'ssl_profile: intermediate' set in your http section of the Home Assistant configuration if you use SSL. If this is not added the Home Assistant api will not be available anymore for this app on your Toon.
http:
  <other http settings>
More info can be found on https://www.home-assistant.io/components/http/
Luc_S
Postby kurniawan77 » Thu Oct 25, 2018 2:35 pm
I can't seem to connect to HA with ssl. Updated to the latest HA and have set "intermediate" too.
Only thing i get is: Settings not saved, got response "".
I tried it both ways with internal ip and port 8123 and with my ha.myurl.nl with port 443 but no go. I am able to get response from rest api...
Any help from here? I am willing to assist
Regards
kurniawan77
Postby rickvnl » Sun Oct 28, 2018 9:30 pm
kurniawan77 wrote:Hi,
Regards
Hey, does it work for you now? I have the same problem.
rickvnl
Postby kurniawan77 » Thu Nov 01, 2018 8:19 pm
Regards
Nothing changed actually
kurniawan77
PreviousNext
Return to Toon Apps
