by TheHogNL » Thu Sep 06, 2018 2:37 pm
MyZ wrote:How do I restart chrony?
/etc/init.d/chronyd restart
- Forum Moderator
by MyZ » Thu Sep 06, 2018 5:31 pm
Thnx. Did some restarts, but didn't had any effect. I'm getting these messages after rebooting:
- Code: Select all
ep 6 17:58:44 eneco-001-209949 daemon.info chronyd[1299]: chronyd version 1.27 starting
Sep 6 17:58:45 eneco-001-209949 daemon.info chronyd[1299]: Linux kernel major=2 minor=6 patch=36
Sep 6 17:58:45 eneco-001-209949 daemon.info chronyd[1299]: hz=100 shift_hz=7 freq_scale=1.00000000 nominal_tick=10000 slew_delta_tick=833 max_tick_bias=1000 shift_pll=2
Sep 6 17:58:45 eneco-001-209949 daemon.err chronyd[1299]: Could not open IPv6 NTP socket : Address family not supported by protocol
Sep 6 17:58:45 eneco-001-209949 daemon.err chronyd[1299]: Could not open IPv6 command socket : Address family not supported by protocol
Sep 6 17:58:45 eneco-001-209949 daemon.info chronyd[1299]: Frequency 6.556 +/- 1.712 ppm read from /var/lib/chrony/chrony.drift
Sep 6 17:58:49 eneco-001-209949 daemon.warn chronyd[1299]: No intersecting endpoints found
MyZ
- Starting Member
by TheHogNL » Thu Sep 06, 2018 5:47 pm
You are not describing your issue
only posting a good logfile
- Forum Moderator
by MyZ » Thu Sep 06, 2018 5:48 pm
problem = topicname
To be more exact, it's 3 minutes behind
MyZ
- Starting Member
by TheHogNL » Thu Sep 06, 2018 6:20 pm
And did you also modify your chrony config as said earlier?
- Forum Moderator
by MyZ » Thu Sep 06, 2018 6:33 pm
Not yet, first I went the "easy way" as you described:
Just restart chrony a few times and it will create the necessary files for it to sync properly
Will modify the file with the other time server.
MyZ
- Starting Member
by MyZ » Thu Sep 06, 2018 6:43 pm
Changed the server to:
- Code: Select all
server 0.nl.pool.ntp.org 8
In sync now!
MyZ
- Starting Member
by TheHogNL » Thu Sep 06, 2018 6:48 pm
That restart was necessary to fix the errors shown in the log (after the change to the pool.ntp.org servers)
- Forum Moderator
by MyZ » Thu Sep 06, 2018 7:03 pm
Ah! It makes all sense now
MyZ
- Starting Member
