Toon not booting after failed update
Postby MadDemonoide » Mon Sep 03, 2018 6:38 pm
Hey.
I tried doing a software update, and the power fell out during the update.
I can access SSH, and the screen is stuck at the T logo.
I tried using the update script, but it cannot seem to connect to the vpn. The keys are in the vpn folder.
What can i do?
Thanks
MadDemonoide
Re: Toon not booting after failed update
Postby TerrorSource » Mon Sep 03, 2018 7:27 pm
can you try the update script as followed:
sh update-rooted.sh -v 4.19.10
and tell us wat happens :)
TerrorSource
Postby marcelr » Mon Sep 03, 2018 7:30 pm
So it is booting.
You can test whether vpn is started by typing
ps | grep vpn
If that gives no output (or nothing useful) you can start vpn manually by copying the command part of the openvpn line from /etc/inittab into the ssh console and run it.
Postby MadDemonoide » Mon Sep 03, 2018 7:36 pm
Hey. With the forcing it is still waiting for VPN to be alive. See the screenshot.
Thank you :)
MadDemonoide
Postby MadDemonoide » Mon Sep 03, 2018 7:41 pm
As far as I can see it is running.
I see the line and the conf file defined there.
marcelr wrote:So it is booting.
ps | grep vpn
MadDemonoide
Postby TerrorSource » Mon Sep 03, 2018 7:42 pm
MadDemonoide wrote:Hey. With the forcing it is still waiting for VPN to be alive. See the screenshot.
Thank you :)
Just keep trying a few times. had that once before too.
Also, check the /etc/inittab if it's not empty.
TerrorSource
Postby MadDemonoide » Mon Sep 03, 2018 7:45 pm
I tried a few times now. Nothing changes.
The inittab is not empty. The openvpn item is there. Uncommented.
Thank you :)
MadDemonoide
Postby marcelr » Mon Sep 03, 2018 7:49 pm
In that case, you should be able to ping feed.hae.int, and get a response.
Postby MadDemonoide » Mon Sep 03, 2018 7:51 pm
marcelr wrote:In that case, you should be able to ping feed.hae.int, and get a response.
I’m not getting a response from that URL.
MadDemonoide
Postby marcelr » Mon Sep 03, 2018 7:56 pm
try
ping 8.8.8.8
(google) then.
If that doesn't give a response, you don't have a working connection to the outside world.
Postby MadDemonoide » Mon Sep 03, 2018 7:57 pm
When I try to manually start the VPN, I get the following:
Socket bind failed on local address. [AF_ INET]127.0.0.1:8000 Address already in use.
MadDemonoide
marcelr wrote:try
ping 8.8.8.8
(google) then.
I tried google. I get a nice ping back.
MadDemonoide
Postby marcelr » Mon Sep 03, 2018 8:12 pm
Maybe you should edit inittab to not start openvpn, then kill it, and let the script do it for you.
Postby TheHogNL » Mon Sep 03, 2018 9:06 pm
I think you have a very old version of Toon firmware which doesn't update the /etc/hosts file properly (your feed.hae.int entry in your hosts file doesn't match with the routing table)
Try to remove the "feed.hae.int" line from the /etc/hosts file and restart the Toon and the script again.
Postby MadDemonoide » Tue Sep 04, 2018 1:37 pm
marcelr wrote:Maybe you should edit inittab to not start openvpn, then kill it, and let the script do it for you.
I can start the VPN manually, but it still does not update.
It also shows up @ the top command as a process.
MadDemonoide
Next
