Enter runlevel problem booting after root
Posted: Wed Sep 12, 2018 10:59 pm
by themman78
I just rooted my second toon. Everything went well, u-boot version is 2010.09-R8, so entering with password was enough enter console.
My toon was booting just fine after the final ssh server installation. I was able to connect ssh through wifi.
Then i decided it was a good idea to run the update-rooted.sh script from hxxps://github.com/IgorYbema/update-rooted.
because i was allready on 4.19.10 i ran the script with -f option. so only improvements were applied.
All went well i think, i did not pay good enough attention to console messages. After all was done i rebooted my toon.
Now this is the message:
rtc-isl1208 1-006f: setting system clock to 2018-09-12 20:43:09 UTC (1536784989)
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: file system size: 117833728 bytes (115072 KiB, 112 MiB, 928 LEBs)
UBIFS: journal size: 9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root: 0 bytes (0 KiB)
VFS: Mounted root (ubifs filesystem) on device 0:13.
Freeing init memory: 104K
usb 2-1: new high speed USB device using mxc-ehci and address 2
INIT: version 2.86 bootingusb 2-1: New USB device found, idVendor=148f, idProduct=5370
usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 2-1: Product: 802.11 n WLAN
usb 2-1: Manufacturer: Ralink
usb 2-1: SerialNumber: 1.0
Enter runlevel:
what can i do to fix it? I am able to see filesystem after booting with "setenv addmisc ...." and "run boot_nand"
I even am able to run the update_rooted.sh script (but without wifi no downloads - so no complete update).
Re: Enter runlevel problem booting after root
Posted: Thu Sep 13, 2018 9:33 am
by TerrorSource
Can you post the content of the /etc/inittab file?
Guess that the runlevel options in that file are not set correctly.
Posted: Thu Sep 13, 2018 1:18 pm
by mAiden
It can be that your inittab is empty now, so he can not find runlevels.
Just for sure, i will post a inittab:
# /etc/inittab: init(8) configuration.
# $Id: inittab,v 1.91 2002/01/25 13:35:21 miquels Exp $
# The default runlevel.
# Boot-time system configuration/initialization script.
# This is run first except when booting in emergency (-b) mode.
si::sysinit:/etc/init.d/rcS
# What to do in single-user mode.
# /etc/init.d executes the S and K scripts upon change
# of runlevel.
# Runlevel 0 is halt.
# Runlevel 1 is single-user.
# Runlevels 2-5 are multi-user.
# Runlevel 6 is reboot.
l0:0:wait:/etc/init.d/rc 0
l1:1:wait:/etc/init.d/rc 1
l2:2:wait:/etc/init.d/rc 2
l3:3:wait:/etc/init.d/rc 3
l4:4:wait:/etc/init.d/rc 4
l5:5:wait:/etc/init.d/rc 5
l6:6:wait:/etc/init.d/rc 6
# Normally not reached, but fallthrough in case of emergency.
z6:6:respawn:/sbin/sulogin
# HCBv2 static stuff
ovpn:235:respawn:/usr/sbin/openvpn --config /etc/openvpn/vpn.conf --verb 0 >/dev/null 2>&1
qtqt:245:respawn:/usr/bin/startqt >/dev/null 2>&1
#Not default stuff
gett:235:respawn:/sbin/getty -L 115200 ttymxc0 vt102
# WARNING: auto-managed by '/etc/init.d/HCBv2 inittabwrap' with '/HCBv2/etc/start.d/*'
# lines containing 'inittabwrap' will be removed automagically.
netc:235:respawn:/etc/init.d/HCBv2 inittabwrap hcb_netcon
comm:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_comm
even:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_eventmgr
kpik:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_kpi
pwru:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_pwrusage
scsy:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_scsync
smar:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_smartplug
ther:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_thermstat
user:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_usermsg
weat:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_weather
bxtp:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_bxtproxy
conf:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_config
logl:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_log
rrdr:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_rrd
watc:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_watchdog
hueh:345:respawn:/etc/init.d/HCBv2 inittabwrap hdrv_hue
p1p1:345:respawn:/etc/init.d/HCBv2 inittabwrap hdrv_p1
zwav:345:respawn:/etc/init.d/HCBv2 inittabwrap hdrv_zwave
ligh:345:respawn:/etc/init.d/HCBv2 inittabwrap lighttpd
# end of 'inittabwrap' section.
Posted: Thu Sep 13, 2018 5:00 pm
by TheHogNL
Don't try to run that script in the failsafe boot (after the run boot_nand thing). That fail safe linux prompt is very tricky and should only be used to fix a few important stuf. Not run that script
However, if you need internet on the Toon1 in that mode just use the ethernet cable interface. That works fine.
How did you reboot your toon after your -f attempt? Never, never, power cycle direct after disk changes. First use 'sync' to make sure the write buffers are written to the disk.
In a recent version the update script also edits a few default 'how to root a toon' files including /etc/inittab. Probably that went wrong. So, indeed, check the /etc/inittab file.
Posted: Thu Sep 13, 2018 9:16 pm
by themman78
TerrorSource, mAiden and TheHogNL,
Thank you all, you were all spot on. The /etc/inittab was empty. I filled it with the inittab posted by mAiden. Thanks for that.
I checked, it was the almost the same as my /etc/inittab of my other Toon. All but the vpn connection to quby/eneco. This line I commented out.
Now my Toon is booting normally, i still need to repair some things. Most importantly, i cannot click on the Stroom nu tile to see the graph. The graph is not showing the energy consumption history. Is this normal? I do have the graphs on my other Toon.
Posted: Fri Sep 14, 2018 2:00 pm
by Toonz
all your consumption data is still there, but I guess your Toon thinks you have no valid subscription and therefor is not showing the graphs.
Follow the manual here:
viewtopic.php?f=100&t=12100#p86875 to fix this
Posted: Fri Sep 14, 2018 2:17 pm
by TerrorSource
Posted: Fri Sep 14, 2018 4:30 pm
by TheHogNL
themman78 wrote:TerrorSource, mAiden and TheHogNL,
Can you still tell me how you rebooted your toon after using the update script (causing het /etc/inittab to be cleared)? You are the second one (maiden first) to see this happen. I might happen if your power cycle the toon right after the update (changes to /etc/inittab not written correctly)
Posted: Mon Sep 17, 2018 1:00 pm
by themman78
TheHogNL wrote:Can you still tell me how you rebooted your toon after using the update script (causing het /etc/inittab to be cleared)? You are the second one (maiden first) to see this happen. I might happen if your power cycle the toon right after the update (changes to /etc/inittab not written correctly)
I believe I first used command
shutdown -r now. This didn't work, even after a second time. So I unplugged the power cable of the meter adapter to force a reboot. I certainly did not use the
sync command.
In the meantime I managed to install my Toon as I wanted. At first Toonstore didn't show up, after several hours (on and off) of reading post on this forum, i ended up finding a post with the solution. My Toon needed installation of some resourcefiles (!?).
As soon may notice, I still am a novice at Toon rooting.
Posted: Thu Sep 20, 2018 10:22 pm
by Smiggel
mAiden wrote:It can be that your inittab is empty now, so he can not find runlevels.
# of runlevel.
#Not default stuff
Thanks for this post. I had the same issue. My Toon was stuck at boot after the last update and would not start after a reboot. Even though the upgrade to 4.19.10 worked just fine. For some reason it got stuck. My iinittab however was not empty. I could ssh and vnc to it. The startup bar filled till about 3/4 and then it jumped back to about 1/10.
However, replacing the contents of my inittab (after making a backup of course) with your contents, my Toon booted again. Perhaps it's helpful for you guys?!
# of runlevel.
#ovpn:235:respawn:/usr/sbin/openvpn --config /etc/openvpn/vpn.conf --verb 0 >/dev/null 2>&1
# add serial console access:
# added tty for direct serial access
# automatic (re)start of x11vnc:
x11v:5:respawn:/usr/bin/x11vnc
Posted: Thu Sep 20, 2018 10:30 pm
by TheHogNL
Only difference is the x11vnc in your inittab. Maybe it overloaded your toon somehow due to a bad config of the x11vnc.
X11vnc is in anyways a memory heavy daemon, so if you don't need it don't install it.
Posted: Thu Sep 20, 2018 10:33 pm
by Smiggel
TheHogNL wrote:Only difference is the x11vnc in your inittab. Maybe it overloaded your toon somehow due to a bad config of the x11vnc.
Ok, thanks for letting me know. Could have been it indeed.
