TSC settings menu item
Re: TSC settings menu item
Postby TheHogNL » Wed Nov 21, 2018 12:54 pm
Mixpower wrote:Any update on the price setting?
Or is it still not possible to change this?
Nope, this is much more work :-) don't expect it soon. Or help ;)
Postby Mixpower » Thu Nov 22, 2018 1:57 pm
Okay, but where is it stored?
But I gather if you change it nothing happens?
Thanks!
Mixpower
Postby TheHogNL » Thu Nov 22, 2018 7:54 pm
Not sure yet. That's the problem i'm facing now.
Postby atlantica » Sat Dec 01, 2018 8:49 pm
Hi TheHogNL
Thanks for all your good work on the TSC menu!
Is it posible to make a "tiles to display" selector in the Rotate menu setings?
Regards
David
atlantica
Postby TheHogNL » Sun Dec 02, 2018 9:16 am
atlantica wrote:Hi TheHogNL
That would be a lot of work and hard to maintain within different firmware levels as Quby also constantly changes the code.
Currently it works by just rotating all tiles in page 2, 3 etc to the tile(s) in page 1. Is that not good enough?
Postby atlantica » Sun Dec 02, 2018 4:46 pm
Perfect!!, but for now it also shows the tiles form page 1 when mode 1 is on....
Regards
David
atlantica
Postby edwin999 » Sat Dec 29, 2018 3:51 pm
Would it be an idea to add an option to enable experimental features?
I.e. enabling Smart Radiator Valves like described in https://www.domoticaforum.eu/viewtopic.php?f=97&t=12222 ?
I thought about this but it would enable inexperencied rooted-toon users to completly destroy the toon. Everything clickable in a GUI should be more or less user friendly :-)
But if you want to test with radiator valves in a toon2 I can tell you how to enable them. Just ask for it in that topic.
edwin999
Postby TerrorSource » Mon Jan 07, 2019 12:39 pm
edwin999 wrote:Would it be an idea to add an option to enable experimental features?
The STRV feature is not yet fully implemented and/or tested. Has too much dependancies as marcelr mentioned in that topic. STRV's from different brands react differently while it should be all the same. Maybe that the Toon2 has only the z-wave libraries for a couple of brands but as there is no official announcement from Eneco/Quby it can only tested by trial-and-error which is not very user-friendly :)
TerrorSource
Postby edwin999 » Tue Jan 15, 2019 9:56 pm
Question: in "Toggle Native Toon Features" I disabled (Toon) Boiler Monitor App, however after a reboot "CV-ketel" is still showing in the app list.
Do you have any idea why this app is still there?
edwin999
Previous
Return to Toon software development
