Set toon back to factory settings while retaining SSH?
Postby michaelology » Thu Jan 03, 2019 6:22 pm
Is it possible to reset the toon back to factory settings and keep SSH access? I don't want to have to root it again to get SSH access back.
michaelology
Re: Set toon back to factory settings while retaining SSH?
Postby TheHogNL » Thu Jan 03, 2019 7:45 pm
Factory settings will always retain root access as this will only reset the user data (like wifi settings, graphs, installed apps etc).
Recovery (only available on a toon2) will lose root access.
Postby TerrorSource » Fri Jan 04, 2019 10:03 am
michaelology wrote:Is it possible to reset the toon back to factory settings and keep SSH access? I don't want to have to root it again to get SSH access back.
Press the "Herstel" in the "Software" tab in the "Instellingen" menu.
It will remove all data and reset the Toon to factory defaults, meaning that there is no activation.
Activation can be set by editing the scsync.xml file via SSH. Save file first, check it and reboot afterwards.
See the settings which needs to be edited: https://www.domoticaforum.eu/viewtopic. ... 235#p83254
TerrorSource
Postby Toonz » Fri Jan 04, 2019 10:14 am
Doesn't a factory reset also force a firmware upgrade when connected to the Eneco VPN? That's not what you want to happen obviously....
Postby TerrorSource » Fri Jan 04, 2019 10:30 am
Toonz wrote:Doesn't a factory reset also force a firmware upgrade when connected to the Eneco VPN? That's not what you want to happen obviously....
Not that i've seen so far but i'm not 100% sure.
Then the OP needs to check if the VPN is closed before rebooting :)
TerrorSource
Postby mAiden » Fri Jan 04, 2019 8:37 pm
Yes, for sure, Toon will check if there is a newer version if you do a factory reset. Disable you're VPN before you do it.
mAiden
Return to Toon Firmware
