marmitek gigacam 4 (help)
Moderator: Esteban
Katsie
Post by Katsie »
received an package today from my work for some testing @ home.
it contains an Marmitek wireless receiver,3 Marmitek color camera's and 1 day/night b/w with some IR leds, all wireless.
but now its setup and working, i am scared by the results...
the whole signal is crap, i see the whole time stripes and noise in the picture.
the manual says, if you work with wireless network the channels can be the same, but that means for a good signal i need to turn off all wire less networks in the neigbourhood?
anyone, tips or tricks?, this because ill go on vacantion tomorrow and i want to get the set working on my Webeye b101 ( this combo works, but because the image is just crap )
i hope some one can help me out.
kindly regards ,erwin
deze set
http://www.domotica-shop.be/catalog/gig ... p-102.html
MindBender
Post by MindBender »
Does the set allow you to switch channels to see if you have a better result? Does the picture improve if you bring the receiver closer to the camera? Is the picture quality just as bad when you connect the receiver to a TV? For an emergency you can use a longer network cable to put the receiver closer to the camera...
Katsie
Post by Katsie »
yesterday ive put the set on the 2nd floor ( receiver only ), then the views from the camera's was amazing !.
so got 3 cams on it now, but the horizontal and vertical sync are pretty nasty now, but got clear vision for going on holiday ;)
( so i think it was my wireless network messing up the quality )
next to that i can switch only in 4 channels ( for 4 camera's but it doens't make the quality MUCH better :(
kindly regards, erwin
