Re: Toon app: mySolar (FP4ALL)
Posted: Tue Mar 16, 2021 1:10 am
You can use the solarPanel app in toon instead. That one is able to read the Growatt inverter.Ridder wrote:Just installed my rooted Toon and it has mySolar installed.
I put the IP address of my inverter in (Growatt 3600 MTL) but there are no data on Toon...
When I connect to the inverter with its IP address in a browser, I need to put in my login name and password.....where can I do that on the Toon?
I also have a kWh meter and `i connected it to Toon, but I am not shure if I connected it the right way....on 1 terminal I put the white wire (that should be the left channel/tip of the jack plug) and the others on the other terminal: red and common ground (the metal shielding of the 2 wires).
Should it be visible on the meter adapter if it is receicing pulses?
Now both leds blink every ~10m seconds (flame and lightning)
Gas and electricity consumption via P1 work fine.....
