Toon mobile access
Re: Toon mobile access
Postby mAiden » Thu Apr 04, 2019 12:07 pm
RoelToonz wrote:Hello i am new with all of this !! i want to have toon mobile ! when i enter adres https://toon-ip/moblite ..... nothing happens :( :( :( :( so what do i have to do ?????? please help ! :P :P :P :P
complement to TheHogNL. http://toon-ip will also not work, you need to change toon-ip to real ip of Toon :)
mAiden
Postby RoelToonz » Thu Apr 04, 2019 9:31 pm
I can not open page ! it says cannot open page !!!
RoelToonz
Postby yjb » Thu Apr 04, 2019 11:08 pm
Hmm, just checking:
- is your Toon rooted?
- Did you install the mobile app using the toonstore?
yjb
Postby RoelToonz » Fri Apr 05, 2019 12:03 pm
Yes toon is rooted and the app is installed on toon !! Doninhave to install something on my mobile phone ??
RoelToonz
Postby TheHogNL » Fri Apr 05, 2019 12:22 pm
Did you open the webserver properly on the toon? You probably missed some rooting steps. Try to run the update-rooted.sh script with option -f to fix everything for you.
(btw: using a lot of !! and ?? isn't very nice on the forum)
Postby mAiden » Fri Apr 05, 2019 12:55 pm
If it cannot find the webpage, then you will have to update your iptables. It is also useful to include the following line in it
-A HCB-INPUT -p tcp -m tcp --dport 22 --tcp-flags SYN,RST,ACK SYN -j ACCEPT
-A HCB-INPUT -p tcp -m tcp --dport 10080 --tcp-flags SYN,RST,ACK SYN -j ACCEPT
-A HCB-INPUT -p tcp -m tcp --dport 80 --tcp-flags SYN,RST,ACK SYN -j ACCEPT
Don't forget to restart you're iptables with:
/etc/init.d/iptables restart
mAiden
Postby mAiden » Fri Jul 05, 2019 9:15 am
In recent days I have been busy giving the Toon Mobile a fresh appearance. The intention is that it will be expanded.
Toon mobile.png (33.27 KiB) Viewed 2236 times
For the basis I have to thank someone .. Thanks Jankootje for the layout.
Not much has changed so far. Layout is the biggest change you will notice.
The following things are also coming:
- Current gas and current display.
- smart lamps / plugs
- CV boiler (So you can see the Water pressure, etc.. Keep in mind that this one will only work if Toon is OpenTherm on you're CV boiler!!)
- Other things that you like to see
When comes this one in ToonStore?
As quickly as possible.
mAiden
Postby estate » Wed Oct 23, 2019 7:00 pm
Hi :)
After long search and reading various posts I keep having questions about this mobile app.
When I want to connect from the inside of my home network Ip range (192.168....) and I switch on local acces in Toon I can see and control the Toon through this app.
But when I try to acces it from the outside world www through the IP from my provider I can not connect.
Now someone told me to make a port forwarding from the inside adres on port 10800, as I tried but this did not work, I also tried a port forwarding on port 10080 but this does not work either, why ??
Port forwarding should not be that difficult huh ? or do I make a mistake ?
I've forwarded protocol TCP and UDP on 198.168.1.xxx port xxxx on a ziggo connectbox
please help me out ?
estate
Postby Toonz » Wed Oct 23, 2019 7:09 pm
try port 80 instead of 10080
Postby estate » Wed Oct 23, 2019 7:28 pm
Sorry for posting again the solution to my own question :)
After thurough searching in my modem I discovered that some option were blocking acces from the outside.
I now have a working port forwarding to the inside adress on port 80 from the outside address on port 10800, if it keeps working I will find out in the upcoming days, when I tested it just minutes ago through the phone network with disabled wifi it worked fine.
estate
Postby Ron_nl » Tue Dec 10, 2019 12:07 pm
Is it possible to remove the login?
I know why there is a login, but for me personally I think it is a bit annoying. :wink:
And I made a quicklink on my Iphone to the startscreen of the Toon mobile page, but it takes a long time before it starts Safari when I click the link.
Ron.
Ron_nl
Postby Toonz » Tue Dec 24, 2019 5:12 pm
Ron_nl wrote:Is it possible to remove the login?
Ron.
a bit late reply, but can't you simply access your site via a shortcut like this:
http://username:password@your-toon-ip/mobile ?
Postby Ron_nl » Tue Dec 24, 2019 7:40 pm
Yes that works, but you can't make a favorite of it on your phone.
Because you have to visit the site first and then the username:password@ part is cut off from the URL.
So you're back to the basic URL again where you have to login.
The luxury problem I have is, I made a quick-link from the mobile URL in Safari to my start-screen, so it would look like an app you start.
I thought maybe it is placing a few "#" for some lines to disable the login?
Ron.
Ron_nl
Postby Toonz » Tue Dec 24, 2019 7:50 pm
simply edit the favourites bookmark manually.
Go to the favourites list, press edit and change the url for Toon to include the logon credentials.
Postby Ron_nl » Tue Dec 24, 2019 8:21 pm
Safari does not like that :D
I can change the URL but it still asks for the login.
Will try again tomorrow, I've noticed some changes take a while. (changed the login on my Toon)
Thanks,
Ron.
Ron_nl
PreviousNext
Return to Toon Apps
cron
