I rooted a toon and updated to the newest version.
Then i had 0 installed apps in the toon store so i ran the update -f script
now it hangs on the splash screen.
I made a connection with toonrecovery and it says its started so i need to connect by serial for the menu.
But i get this respond:
Cannot exec '/dev/ttyS0': Bestand of map bestaat niet
Toon Recovery
Re: Toon Recovery
/dev/ttyS0 is not a command. You need screen or minicom or something similar to connect to your serial port (can be /dev/serial, /dev/ttyS0 or /dev/ttyUSB0 or similar).Peter1612 wrote:I rooted a toon and updated to the newest version.
Re: Toon Recovery
Can someone help me please?
I did follow all the manuals over the internet because none of them are complete to Recover my Toon.
after 2 days of testing and trying i have my setup ready.
and now i don't get the recovery menu as described in the manual.
my ssh connection to execute the commands on my PI give me only this message: INFO:recovery:Waiting for Toon to restart
I did used the reset button on my toon but it stay on this message and don't got the recovery menu.
I started a serial terminal on my pi also to view the traffic between the pi and the toon. but it looks toon starts normal and does not start from NFS.
What the hack is wrong with my setup?
Re: Toon Recovery
I did got it to work now.
The problem was that the shared folders was not accessible from external client.
the reason was that you have to do some more steps to got it to work than explained in the manual.
If you like i can, when i have time write an manual for these steps to got things work.
Best regards,
Best regards,
Toon Recovery help please
Hello The Hogh & All,
I have a non booting Toon1 on which I performed the ToonReovery procedure with Rasperry3. This worked well without errors.
After the process I connected a TTL to USB converter to the Toon pins 11/13/14 and a PC with terminal program.
I don't see the Toon Recovery Environment menu but a rolling list of linux boot messages.
Can you advice what is happening and how to get into the Toon Recovery Environment menu?
Thanks in advance, Ko
U-Boot 2010.09-R8 (Dec 03 2012 - 12:50:30)
CPU: Freescale i.MX27 at 400.168 MHz
Prodrive B.V. ED2.0
DRAM: 128 MiB
NAND: 128 MiB
LCD: Initializing LCD frambuffer at a1400000
LCD: 800x480, pbb 4
LCD: Drawing the logo...
In: serial
Out: serial
Err: serial
Display-bmp: 800 x 480 with 16777216 colors
Net: FEC
Address in SROM is 00:00:20:03:00:00
Address in environment is 00:0f:11:04:ff:35
Enter password - autoboot in 2 sec...
NAND read: device 0 offset 0x300000, size 0x300000
3145728 bytes read: OK
## Booting kernel from Legacy Image at a1000000 ...
Image Name: Linux-2.6.36-R10-h28
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 1944236 Bytes = 1.9 MiB
Load Address: a0008000
Entry Point: a0008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.36-R10-h28 (jbraam@dvl) (gcc version 4.5.3 20110223 (prerelease) (GCC) ) #1 PREEMPT Fri Sep 28 15:51:09 CEST 2018
CPU: ARM926EJ-S [41069264] revision 4 (ARMv5TEJ), cr=00053177
CPU: VIVT data cache, VIVT instruction cache
Machine: Prodrive B.V ED2.0
Memory policy: ECC disabled, Data cache writeback
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Kernel command line: ubi.mtd=4 root=ubi0:rootfs rw rootfstype=ubifs mtdparts=mxc_nand:512K@0x00100000(u-boot-env)ro,1536K(splash-image),3M(kernel),3M(kernel-backup),119M(rootfs) console=ttymxc0,115200 mem=128M lpj=999424
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB = 128MB total
Memory: 126092k/126092k available, 4980k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xffa00000 - 0xffe00000 ( 4 MB)
vmalloc : 0xc8800000 - 0xf4000000 ( 696 MB)
lowmem : 0xc0000000 - 0xc8000000 ( 128 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.init : 0xc0008000 - 0xc0022000 ( 104 kB)
.text : 0xc0022000 - 0xc0367000 (3348 kB)
.data : 0xc037e000 - 0xc03a17a0 ( 142 kB)
Hierarchical RCU implementation.
RCU-based detection of stalled CPUs is disabled.
Verbose stalled-CPUs detection is disabled.
NR_IRQS:272
MXC IRQ initialized
MXC GPIO hardware
Console: colour dummy device 80x30
Calibrating delay loop (skipped) preset value.. 199.88 BogoMIPS (lpj=999424)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
Configured for LCD: TM070RDH11
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Switching to clocksource mxc_timer1
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
msgmni has been set to 246
io scheduler noop registered (default)
imx-fb imx-fb.0: PreserveUBootFramebuffer(1): xres=800, yres=480 [skip _update_lcdc]
imx-fb imx-fb.0: PreserveUBootFramebuffer(2): xres=800, yres=480 [skip _update_lcdc]
Console: switching to colour frame buffer device 100x30
imx-fb imx-fb.0: fb0: DISP0 BG fb device registered successfully.
imx-fb imx-fb.0: PreserveUBootFramebuffer(3): xres=800, yres=480 [skip _update_lcdc]
imx-fb imx-fb.0: fb1: DISP0 FG fb device registered successfully.
Serial: IMX driver
imx-uart.0: ttymxc0 at MMIO 0x1000a000 (irq = 20) is a IMX
console [ttymxc0] enabled
imx-uart.1: ttymxc1 at MMIO 0x1000b000 (irq = 19) is a IMX
imx-uart.2: ttymxc2 at MMIO 0x1000c000 (irq = 18) is a IMX
NAND device: K9F1G08U0E detected, disabling sub-page writes
NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit)
Scanning device for bad blocks
RedBoot partition parsing not available
5 cmdlinepart partitions found on MTD device mxc_nand
Creating 5 MTD partitions on "mxc_nand":
0x000000100000-0x000000180000 : "u-boot-env"
0x000000180000-0x000000300000 : "splash-image"
0x000000300000-0x000000600000 : "kernel"
0x000000600000-0x000000900000 : "kernel-backup"
0x000000900000-0x000008000000 : "rootfs"
UBI: attaching mtd4 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 126976 bytes
UBI: smallest flash I/O unit: 2048
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
UBI: max. sequence number: 113374
UBI: attached mtd4 to ubi0
UBI: MTD device name: "rootfs"
UBI: MTD device size: 119 MiB
UBI: number of good PEBs: 952
UBI: number of bad PEBs: 0
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 4096
UBI: number of internal volumes: 1
UBI: number of user volumes: 1
UBI: available PEBs: 0
UBI: total number of reserved PEBs: 952
UBI: number of PEBs reserved for bad PEB handling: 9
UBI: max/mean erase counter: 9086/7552
UBI: image sequence number: 1276050741
UBI: background thread "ubi_bgt0d" started, PID 309
at25 spi0.0: 32 KByte at25640B eeprom, pagesize 64
spi_imx spi_imx.0: probed
FEC Ethernet Driver
fec_enet_mii_bus: probed
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
mxc-ehci mxc-ehci.0: initializing i.MX USB Controller
mxc-ehci mxc-ehci.0: portsc setup 1: 0x80000000
mxc-ehci mxc-ehci.0: Work around for USB enabled
ULPI transceiver vendor/product ID 0x0424/0x000d
mxc-ehci mxc-ehci.0: Freescale On-Chip EHCI Host Controller
mxc-ehci mxc-ehci.0: new USB bus registered, assigned bus number 1
mxc-ehci mxc-ehci.0: irq 56, io mem 0x10024000
mxc-ehci mxc-ehci.0: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: Freescale On-Chip EHCI Host Controller
usb usb1: Manufacturer: Linux 2.6.36-R10-h28 ehci_hcd
usb usb1: SerialNumber: mxc-ehci.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mxc-ehci mxc-ehci.2: initializing i.MX USB Controller
mxc-ehci mxc-ehci.2: portsc setup 1: 0x80000000
mxc-ehci mxc-ehci.2: Work around for USB enabled
mxc-ehci mxc-ehci.2: Freescale On-Chip EHCI Host Controller
mxc-ehci mxc-ehci.2: new USB bus registered, assigned bus number 2
mxc-ehci mxc-ehci.2: irq 55, io mem 0x10024400
mxc-ehci mxc-ehci.2: USB 2.0 started, EHCI 1.00
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: Freescale On-Chip EHCI Host Controller
usb usb2: Manufacturer: Linux 2.6.36-R10-h28 ehci_hcd
usb usb2: SerialNumber: mxc-ehci.2
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver usbserial
usbserial: USB Serial Driver core
input: TSC2007 Touchscreen as /devices/virtual/input/input0
rtc-isl1208 1-006f: chip found, driver version 0.3
rtc-isl1208 1-006f: rtc core: registered rtc-isl1208 as rtc0
i2c /dev entries driver
tmp431 0-004c: Could not read configuration register (-5)
imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
adt7410 0-0048: adt7410 temperature sensor registered.
adt7410 0-0049: adt7410 temperature sensor registered.
nf_conntrack version 0.5.0 (1970 buckets, 7880 max)
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP cubic registered
NET: Registered protocol family 17
Bridge firewalling registered
rtc-isl1208 1-006f: setting system clock to 2022-12-24 10:42:55 UTC (1671878575)
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: file system size: 117960704 bytes (115196 KiB, 112 MiB, 929 LEBs)
UBIFS: journal size: 5840896 bytes (5704 KiB, 5 MiB, 46 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root: 4952683 bytes (4836 KiB)
VFS: Mounted root (ubifs filesystem) on device 0:13.
Freeing init memory: 104K
usb 2-1: new high speed USB device using mxc-ehci and address 2
INIT: version 2.86 bootingusb 2-1: New USB device found, idVendor=148f, idProduct=5370
usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 2-1: Product: 802.11 n WLAN
usb 2-1: Manufacturer: Ralink
usb 2-1: SerialNumber: 1.0
Enter runlevel:
Prodrive B.V. ED2.0
DRAM: 128 MiB
NAND: 128 MiB
LCD: 800x480, pbb 4
In: serial
Out: serial
Err: serial
Net: FEC
OK
Starting kernel ...
NR_IRQS:272
MXC IRQ initialized
MXC GPIO hardware
TCP reno registered
Serial: IMX driver
FEC Ethernet Driver
Enter runlevel:
Re: Toon Recovery help please
First you say you have done the toonrecovery succesfully and then you say you don't seen the toon recovery menu and show a normal boot. After a succesfull toonrecoveyr you should just ssh to the toon and not expect a new menu again.kappl01 wrote: ↑Sat Dec 24, 2022 1:12 pm Hello The Hogh & All,
