Gas usage null
Posted: Mon Oct 14, 2019 4:26 pm
by Bpiep
When I use the toon mobile app the gas usage isn’t displayed. The Power usage is. On the Toon itself the gas (and power) usage is displayed properly. When I check
http://ipaddress-toon/happ_pwrusage?act ... rrentUsage the gasUsage value is null and the avgValue is also null. I tried to solve this but nothing works.
Re: Gas usage null
Posted: Tue Oct 15, 2019 8:08 pm
by TerrorSource
Bpiep wrote:When I use the toon mobile app the gas usage isn’t displayed. The Power usage is. On the Toon itself the gas (and power) usage is displayed properly. When I check
Could you check the settings of the Meteradapter? Maybe the Gas-usage is not checked.
Re: Gas usage null
Posted: Tue Oct 15, 2019 9:40 pm
by Bpiep
I double checked the settings of Meteradapter and everything is in order. On Toon the gas usage is displayed properly with graphs and everything. So, I don’t understand it. My neighbour has the exact same issue BTW.
Re: Gas usage null
Posted: Thu May 07, 2020 12:08 pm
by jmw
I have the same issue with a rooted Toon (new generation).
http://<toon ip>/happ_pwrusage?action=GetCurrentUsage gives me
{"result":"ok",
"powerUsage": {"value":0, "avgValue":421.41},
"powerProduction": {"value":3545, "avgValue":533.66},
"gasUsage": {"value":null,"avgValue":null}
If I check on the Toon screen itself I can see my daily/weekly/month Gas usage being registered.
Also external data user slimmemeterportaal.nl is registering Gas usage.
All this would mean:
- Main 'slimme meter' is providing readings (both to Toon & direct external providers)
- Toon actually sees some data from the P1 and displays it... but the Json file reports it empty.
Happy to help troubleshoot but I have no clue where to start.
(not sure if related by other data users like the Andriod App also seem to have issues with Gas reporting, while the data is on the actual Toon:
viewtopic.php?f=102&t=12402&start=150#p94291 )
Re: Gas usage null
Posted: Thu May 07, 2020 8:45 pm
by RoadXY
Same for me. Electricity is working.
My guess is it's a firmware issue.
