Page 1 of 2
Toon firmware 5.15.6 released
Posted: Wed Oct 16, 2019 6:48 pm
by TheHogNL
Eneco release Toon firmware 5.15.6 (
https://forum.eneco.nl/software-en-hard ... gaan-22279). We checked this firmware and it is safe to update to this new firmware. For releasenotes check the eneco forum.
As for regular Toon users this update will be auto-update. For rooted toons this is, ofcourse, blocked.
EDIT: one more important thing what changed with this firmware is that is it now easy to change the tenant (from toon to boxx or to other vendors in countries like germany or spain). Also you can choose quby as tenant which assumably allows you to have all options. You need a factory reset for this. After reset you will be asked in which country your toon is. This is the tenant selection screen. If you press the world icon 5 times you can select the quby option also.
Re: Toon firmware 5.15.6 released
Posted: Thu Oct 17, 2019 12:12 pm
by michel30
I just try to update the TOON, and I received this error message please contact support - prepare error dl afv
The log says:
>> 2019-10-17 10:47:45 +0100 (pid 22169) upgrade-qb2.sh qb2 uni 5.15.6 prepare
>> 2019-10-17 10:47:45 +0100 (pid 22169) prepare
qb-auto-update not running
>> 2019-10-17 10:49:09 +0100 (pid 22169) preparing
>> logKeyValText: key(upgrade-prep-info), value(upgrade-prep-start) and text(afv=qb2/uni/5.15.6)
>> Hotfix for writing System Time to RTC
Hardware Clock before: Thu Oct 17 09:48:51 2019 0.000000 seconds
Hardware Clock after : Thu Oct 17 09:49:10 2019 0.000000 seconds
Failed retrieving 'http://feed.hae.int/feeds/qb2/uni/5.15.6/SystemFeed', trying again verbosely:
--2019-10-17 10:49:14-- http://feed.hae.int/feeds/qb2/uni/5.15.6/SystemFeed
Resolving feed.hae.int... 172.22.0.1
Connecting to feed.hae.int|172.22.0.1|:80... failed: No route to host.
>> logKeyValText: key(upgrade-exit-status), value(prepare-error-dl-afv) and text({"fromVersion":"5.13.12","toVersion":"5.15.6"})
>> 2019-10-17 10:49:17 +0100 (pid 22169) prepare-error-dl-afv 'AFV download failed Maybe sync or non-existing?'
It looks like it could not connect to the server or someting else?
Posted: Thu Oct 17, 2019 7:40 pm
by prutser
Succesfully updated using SSH and the update script (not via the GUI). Rebooted somewhere in the middle. TSC file was updated to 2.1.1. after the reboot, the firmware was still on 5.13.12. Started the update again with the script and it installed succesfully after a while (and answering "yes" several times). Works like a charm.
Posted: Thu Oct 17, 2019 9:18 pm
by TheHogNL
prutser wrote:Succesfully updated using SSU and the update script (not via the GUI). Rebooted somewhere in the middle. TSC file was updated to 2.1.1. after the reboot, the firmware was still on 5.13.12. Started the update again with the script and it installed succesfully after a while (and answering "yes" several times). Works like a charm.
Don't know what SSU is but great to see it worked for you
Posted: Thu Oct 17, 2019 10:54 pm
by michel30
But for me it did not updated, lucky it fall back to the old firmware.
I used the TSC menu 2.1.1
Posted: Thu Oct 17, 2019 11:40 pm
by TheHogNL
Did you check the logs? Last couple of days Eneco released some new update scripts which we needed to check before we allow it to be used for rooted toons so there is a safety feature in the rooted toons update script for this. Maybe you did hit that.
Posted: Sat Oct 19, 2019 1:31 pm
by michel30
TheHogNL wrote:Did you check the logs? Last couple of days Eneco released some new update scripts which we needed to check before we allow it to be used for rooted toons so there is a safety feature in the rooted toons update script for this. Maybe you did hit that.
Hello.
The Toon is running on 5.13.12 and I used the TSC menu 2.1.1 and from that menu I did the upgrade to 5.15.6.
I also post the log file above and the last line says: 2019-10-17 10:49:17 +0100 (pid 22169) prepare-error-dl-afv 'AFV download failed Maybe sync or non-existing?'
I checked the log /mnt/data/update/upgrade-qb2.sh.log Or is there another log file what I need to check or do I need to wait for a new TSC menu?
Posted: Sat Oct 19, 2019 1:38 pm
by Chris83
Hello today i tried updating the toon the the newest firmware, But i failed.
Is there a way to force it to update? or do i need to remove some things?
Tunnel is alive and configured.
Upgrade script downloaded. We need to download the upgrade files first. No upgrade is done yet. Do you want me to download the files (yes) or quit (anything else)?
Starting the upgrade prepare option which downloads all necessary files. No upgrade is done yet.
Waiting to finish. Sometimes this takes a minute or two .
Done preparing.
After downloading the files the free space on the Toon is less then 5000 KB. This could cause the upgrade to fail. Do you still want to continue (yes)?
Posted: Sat Oct 19, 2019 4:07 pm
by TheHogNL
Chris83 wrote:Hello today i tried updating the toon the the newest firmware, But i failed.
From what version are you upgrading?
You can always run the update script manually. You can then ignore that disk space warning. But you better look if you can remove some toonstore-apps you are not using
Posted: Sat Oct 19, 2019 4:09 pm
by TheHogNL
Your issue is this: Connecting to feed.hae.int|172.22.0.1|:80... failed: No route to host.
This means your VPN failed/dropped while downloading the files. You can safely try it again.
Posted: Sat Oct 19, 2019 5:20 pm
by Chris83
TheHogNL wrote:Chris83 wrote:Hello today i tried updating the toon the the newest firmware, But i failed.
Hello i'm running 5.13.12.
I removed all the toonstore apps im not using. Only Buienradar en Domoticz are still running.
And i tried the script manually.
Your Toon already tried downloading version 5.15.6 before. Need to force this version!
yes
Progress: 22% .
Prepare failed. Please check the logs at /mnt/data/update/upgrade-qb2.sh.log
Posted: Sat Oct 19, 2019 6:53 pm
by TheHogNL
Prepare is the download part of the update. Please check that log (post it here or on a online notepad thing and paste the link) /mnt/data/update/upgrade-qb2.sh.log
Posted: Sat Oct 19, 2019 9:19 pm
by michel30
The upgrade is not working on my Toon, all what I try does not work, reboot cleanup some space, but it gives me the error:
Filesystem Type Size Used Available Use% Mounted on
ubi0:rootfs ubifs 103.3M 85.0M 18.2M 82% /
tmpfs tmpfs 61.6M 184.0K 61.4M 0% /var/volatile
See here my log files:
>> opkg_dl.download: opkg --cache /mnt/data/update --download-only upgrade # try 1/5
>> opkg_dl.download.supervisor: monitoring /mnt/data/update for threshold 5000
> opkg_dl.update.supervisor: Exit
> opkg_dl.download.supervisor: /tmp/opkg-qq2O6G/happ-pwrusage_1.836-master_qb2.ipk: downloading
> opkg_dl.download.supervisor: /tmp/opkg-qq2O6G/happ-pwrusage_1.836-master_qb2.ipk: file -> symlink
> opkg_dl.download.supervisor: /tmp/opkg-qq2O6G/psplash-quby_0.1+git0+14c8f7b705-r15-q16_armv5e.ipk: file -> symlink
> opkg_dl.download.supervisor: /tmp/opkg-qq2O6G/qmf-tenantize_1.2-r0_armv5e.ipk: file -> symlink
> opkg_dl.download.supervisor: /tmp/opkg-qq2O6G/tenant-all_1.158-master_all.ipk: file -> symlink
> opkg_dl.download.supervisor: /tmp/opkg-qq2O6G/qt-gui_1.9714-master_qb2.ipk: downloading
> opkg_dl.download.supervisor: /tmp/opkg-qq2O6G/hdrv-zwave_1.1650-master_qb2.ipk: file -> symlink
> opkg_dl.download.supervisor: /tmp/opkg-qq2O6G/base-qb2-uni_5.15.6-0_qb2.ipk: file -> symlink
> opkg_dl.download.supervisor: /tmp/opkg-qq2O6G/happ-thermstat_1.2375-master_qb2.ipk: downloading
> opkg_dl.download.supervisor: /tmp/opkg-qq2O6G/happ-weather_1.256-master_qb2.ipk: file -> symlink
> opkg_dl.download.supervisor: /tmp/opkg-qq2O6G/hdrv-p1_1.1058-master_qb2.ipk: file -> symlink
> opkg_dl.download.supervisor: /tmp/opkg-qq2O6G/happ-scsync_1.448-master_qb2.ipk: file -> symlink
> opkg_dl.download.supervisor: /tmp/opkg-qq2O6G/happ-thermstat_1.2375-master_qb2.ipk: file -> symlink
> opkg_dl.download.supervisor: /tmp/opkg-qq2O6G/hcb-config_1.494-master_qb2.ipk: file -> symlink
/tmp/update.status.vars: Downloading 0% (1/206)
Downloading http://feed.hae.int/feeds/qb2/uni/5.15.6/../../POOL/happ-pwrusage_1.836-master_qb2.ipk.
/tmp/update.status.vars: Downloading 1% (4/206) happ-pwrusage
Downloading http://feed.hae.int/feeds/qb2/uni/5.15.6/../../POOL/tenant-all_1.158-master_all.ipk.
Downloading http://feed.hae.int/feeds/qb2/oe/angelica-1.5.1-master-white-label/armv5e/qmf-tenantize_1.2-r0_armv5e.ipk.
Downloading http://feed.hae.int/feeds/qb2/oe/angelica-1.5.1-master-white-label/armv5e/psplash-quby_0.1+git0+14c8f7b705-r15-q16_armv5e.ipk.
/tmp/update.status.vars: Downloading 23% (49/206) tenant-eneco-nl
Downloading http://feed.hae.int/feeds/qb2/uni/5.15.6/../../POOL/qt-gui_1.9714-master_qb2.ipk.
/tmp/update.status.vars: Downloading 27% (59/206) qt-gui
Downloading http://feed.hae.int/feeds/qb2/uni/5.15.6/../../POOL/hdrv-zwave_1.1650-master_qb2.ipk.
/tmp/update.status.vars: Downloading 37% (79/206) hdrv-zwave
Downloading http://feed.hae.int/feeds/qb2/uni/5.15.6/../../POOL/base-qb2-uni_5.15.6-0_qb2.ipk.
/tmp/update.status.vars: Downloading 40% (85/206) base-qb2-uni
Downloading http://feed.hae.int/feeds/qb2/uni/5.15.6/../../POOL/happ-weather_1.256-master_qb2.ipk.
/tmp/update.status.vars: Downloading 49% (104/206) happ-weather
Downloading http://feed.hae.int/feeds/qb2/uni/5.15.6/../../POOL/hdrv-p1_1.1058-master_qb2.ipk.
/tmp/update.status.vars: Downloading 71% (150/206) hdrv-p1
Downloading http://feed.hae.int/feeds/qb2/uni/5.15.6/../../POOL/happ-thermstat_1.2375-master_qb2.ipk.
/tmp/update.status.vars: Downloading 81% (170/206) happ-thermstat
/tmp/update.status.vars: Downloading 82% (173/206) qmf-tenantize
Downloading http://feed.hae.int/feeds/qb2/uni/5.15.6/../../POOL/happ-scsync_1.448-master_qb2.ipk.
/tmp/update.status.vars: Downloading 90% (189/206) happ-scsync
Downloading http://feed.hae.int/feeds/qb2/uni/5.15.6/../../POOL/hcb-config_1.494-master_qb2.ipk.
Downloading http://feed.hae.int/feeds/qb2/oe/angelica-1.5.1-master-white-label/quby2/qmf-collateral_1.1-r0_quby2.ipk.
/tmp/update.status.vars: Downloading 95% (199/206) hcb-config
/tmp/update.status.vars: Downloading 100% (206/206)
Collected errors:
* opkg_download: Failed to download http://feed.hae.int/feeds/qb2/uni/5.15.6/../../POOL/qt-gui_1.9714-master_qb2.ipk: Timeout was reached.
* opkg_install_pkg: Failed to download qt-gui. Perhaps you need to run 'opkg update'?
> opkg_dl.download: Exit code: 255
> opkg_dl.download: md5sum-verify: 7cb27c7324887891d554a11227dc9235 base-qb2-uni_5.15.6-0_qb2.ipk
> opkg_dl.download: md5sum-verify: c78fbf0564a31c7a544124393eef8828 happ-pwrusage_1.836-master_qb2.ipk
> opkg_dl.download: md5sum-verify: 49322077398a1e7b7b5a08f8562b8580 happ-scsync_1.448-master_qb2.ipk
> opkg_dl.download: md5sum-verify: e464d927c2d975df2ce1ca9d836856e8 happ-thermstat_1.2375-master_qb2.ipk
> opkg_dl.download: md5sum-verify: d9a4e2d534b6c77d02817c4e6eea8bc4 happ-weather_1.256-master_qb2.ipk
> opkg_dl.download: md5sum-verify: 245c4ec7286a8fad90c4389d1fe0ba0c hcb-config_1.494-master_qb2.ipk
> opkg_dl.download: md5sum-verify: 31ff3d3ac1735e8c0c0d8375ea33b3e1 hdrv-p1_1.1058-master_qb2.ipk
> opkg_dl.download: md5sum-verify: 357a5d508d38ac8aef178e50d708d6cb hdrv-zwave_1.1650-master_qb2.ipk
> opkg_dl.download: md5sum-verify: f71e59577cf22855717769966f8953e7 psplash-quby_0.1+git0+14c8f7b705-r15-q16_armv5e.ipk
> opkg_dl.download: md5sum-verify: c0609c74d45ed8f6de4a18077ca862e9 qmf-collateral_1.1-r0_quby2.ipk
> opkg_dl.download.supervisor: Exit
> opkg_dl.download: md5sum-verify: 6bc98b16c9b3236f6ccdebb6806ed759 qmf-tenantize_1.2-r0_armv5e.ipk
> opkg_dl.download: md5sum-verify: 15c2322dd63f7303abe59db5c997b5ef tenant-all_1.158-master_all.ipk
>> logKeyValText: key(upgrade-dl-retry-warning), value(opkg-dl-try1) and text(try1)
>> opkg_dl.download: opkg --cache /mnt/data/update --download-only upgrade # try 2/5
> opkg_dl.download.supervisor: /tmp/opkg-u4Rwkd/happ-pwrusage_1.836-master_qb2.ipk: file -> symlink
> opkg_dl.download.supervisor: /tmp/opkg-u4Rwkd/psplash-quby_0.1+git0+14c8f7b705-r15-q16_armv5e.ipk: file -> symlink
> opkg_dl.download.supervisor: /tmp/opkg-u4Rwkd/qmf-tenantize_1.2-r0_armv5e.ipk: file -> symlink
> opkg_dl.download.supervisor: /tmp/opkg-u4Rwkd/qt-gui_1.9714-master_qb2.ipk: downloading
> opkg_dl.download.supervisor: /tmp/opkg-u4Rwkd/tenant-all_1.158-master_all.ipk: file -> symlink
> opkg_dl.download.supervisor: /tmp/opkg-u4Rwkd/qt-gui_1.9714-master_qb2.ipk: file -> symlink
> opkg_dl.download.supervisor: Disk space check failed! (3116 < 5000) Aborting download!
Killed
> opkg_dl.download: Exit code: 137
sh: can't kill pid 3224: No such process
>> Disk space check killed opkg! (/tmp/opkg-killed-reason:out-of-disk-space)
> Performing extra cleanup actions
+ rm -rf /mnt/data/update/base-qb2-uni_5.15.6-0_qb2.ipk /mnt/data/update/happ-pwrusage_1.836-master_qb2.ipk /mnt/data/update/happ-scsync_1.448-master_qb2.ipk /mnt/data/update/happ-thermstat_1.2375-master_qb2.ipk /mnt/data/update/happ-weather_1.256-master_qb2.ipk /mnt/data/update/hcb-config_1.494-master_qb2.ipk /mnt/data/update/hdrv-p1_1.1058-master_qb2.ipk /mnt/data/update/hdrv-zwave_1.1650-master_qb2.ipk /mnt/data/update/psplash-quby_0.1+git0+14c8f7b705-r15-q16_armv5e.ipk /mnt/data/update/qmf-collateral_1.1-r0_quby2.ipk /mnt/data/update/qmf-tenantize_1.2-r0_armv5e.ipk /mnt/data/update/qt-gui_1.9714-master_qb2.ipk /mnt/data/update/tenant-all_1.158-master_all.ipk /tmp/opkg-u4Rwkd
+ du -h /mnt/data/update/updated-rooted.status /mnt/data/update/upgrade-qb2.sh /mnt/data/update/upgrade-qb2.sh.log /mnt/data/update/upgrade-qb2.sh.res
4.0K /mnt/data/update/updated-rooted.status
40.0K /mnt/data/update/upgrade-qb2.sh
16.0K /mnt/data/update/upgrade-qb2.sh.log
4.0K /mnt/data/update/upgrade-qb2.sh.res
+ find /mnt/data/update -name _opkg.*.script.* ! -name upgrade-qb2.sh*
+ xargs -r -t rm -f
+ set +x
>> logKeyValText: key(upgrade-error-disk-space-report), value({"log":6068,"config":240,"rrd":20324}) and text({"fromVersion":"5.13.12","toVersion":"5.15.6"})
>> logKeyValText: key(upgrade-exit-status), value(prepare-error-opkg-download-out-of-disk-space) and text({"fromVersion":"5.13.12","toVersion":"5.15.6"})
>> 2019-10-19 20:03:44 +0100 (pid 2277) prepare-error-opkg-download-out-of-disk-space 'Not enough disk space to download required packages!'
Or do I need to remove some apps?
Posted: Sat Oct 19, 2019 10:38 pm
by TheHogNL
Check your diskusage with
On a fresh toon1 with a few toonstore apps and already on 5.15.6 this results in this list below. Compare it to your result and look where your toon is really higher.
0 /HCBv2
764 /bin
0 /boot
0 /configured
0 /dev
1092 /etc
6376 /lib
0 /linuxrc
8304 /mnt
0 /proc
42064 /qmf
80 /root
896 /sbin
0 /sys
0 /tmp
77468 /usr
820 /var
Posted: Sun Oct 20, 2019 1:27 pm
by Chris83
TheHogNL wrote:Prepare is the download part of the update. Please check that log (post it here or on a online notepad thing and paste the link) /mnt/data/update/upgrade-qb2.sh.log
Seems like there is nog enough space free on the toon to download the packages.
604.0K /mnt/data/update/upgrade-qb2.sh.log
+ + find /mnt/data/update -name _opkg.*.script.* ! -name upgrade-qb2.sh*
xargs -r -t rm -f
+ set +x
>> logKeyValText: key(upgrade-error-disk-space-report), value({"log":2760,"config":120,"rrd":8148}) and text({"fromVersion":"5.13.12","toVersion":"5.15.6"})
>> 2019-10-19 16:37:34 +0100 (pid 31880) prepare-error-opkg-download-out-of-disk-space 'Not enough disk space to download required packages!'
df -h
Filesystem Size Used Available Use% Mounted on
ubi0:rootfs 103.3M 78.9M 19.6M 80% /
tmpfs 61.6M 452.0K 61.2M 1% /var/volatile
