Page 1 of 2
Connection to BRAHMA thermostat and "EMMETI" boiler
Posted: Fri Jan 03, 2020 7:02 pm
by mcasamento
I've bought the OTGW kit with a NodeMCU from Nodeshop but I'm only able to connect it in Monitor Mode thus receiving a lot of Error 03.
The thermostat is a BRAHMA KRONOS OT11 and if it can helo I've got a techincal document on my 1drive :
https://1drv.ms/b/s!AineZF8jPblsisRctwD ... Q?e=XfE2lA
The boiler is an Emmeti Althea S that is very likely to be somthing rebranded, but I don't have any other techincal document about it.
I've found that there is another thread on this forum with the same boiler and the same thermostat, posted by @ilcalmo:
viewtopic.php?f=75&t=10784&p=76588&hilit=emmeti#p76588 and I'm experiencing more or less the same behaviour, but unfortunately that thread has been abandoned and I'm not sure about what test should I do.
I've tried to set any possible reference voltage, but if I set a value under 1.042 or above 2.292 the thermostat will shut down, the values in between all give the same Error 03.
When in monitor mode it does returns some data:
15:29:01.817527 Error 03
15:29:01.941722 T00000300 Read-Data Status: 00000011 00000000
- CH enable: enabled (1)
- DHW enable: enabled (1)
- Cooling enable: disabled (0)
- OTC active: not active (0)
- CH2 enable: disabled (0)
- Summer/winter mode: winter (0)
- DHW blocking: unblocked (0)
15:29:02.313402 rror 03
15:29:02.472321 T10101281 Write-Data Room setpoint: 18.50
15:29:02.803894 Error 03
15:29:02.952177 T00110000 Read-Data Relative modulation level: 0.00
15:29:03.471337 00120000
15:29:03.815348 Error 03
15:29:03.945892 T00140000 Read-Data Day of week and time of day: Unk 00:00
15:29:04.319223 Error 03
15:29:04.854299 T80130000 Read-Data DHW flow rate: 0.00
15:29:05.204917 Error 03
15:29:05.356545 T1018134D Write-Data Room temperature: 19.30
15:29:05.721436 Error 03
15:29:05.858484 T80190000 Read-Data Boiler water temperature: 0.00
15:29:06.222383 Error 03
15:29:06.364653 T801A0000 Read-Data DHW temperature: 0.00
15:29:06.725769 Error 03
15:29:06.848825 T001B0000 Read-Data Outside temperature: 0.00
15:29:07.247142 Error 03
15:29:07.363161 T00110000 Read-Data Relative modulation level: 0.00
15:29:07.748304 Error 03
15:29:07.951760 T00120000 Read-Data CH water pressure: 0.00
15:29:08.345868 Error 03
15:29:08.561200 T801C0000 Read-Data Return water temperature: 0.00
15:29:08.901867 Error 03
15:29:09.048542 T00210000 Read-Data Exhaust temperature: 0.00
15:29:09.450935 Error 03
15:29:09.650637 T90382A00 Write-Data DHW setpoint: 42.00
15:29:10.074477 Error 03
15:29:10.671123 rror 03
15:29:10.853282 T10010500 Write-Data Control setpoint: 5.00
15:29:11.215412 Error 03
15:29:11.350799 T00000300 Read-Data Status: 00000011 00000000
15:29:11.714738 rror 03
15:29:11.853830 T00000300 Read-Data Status: 00000011 00000000
while when in monitoring mode it repetitively print:
09:23:13.964157 1002011C
09:23:14.965397 T1002011C Write-Data Master configuration: 00000001 28
- Smart power: supported (1)
09:23:15.965842 T1002011C Write-Data Master configuration: 00000001 28
09:23:16.798778 Command: PR=M
09:23:16.936919 PR: M=G
09:23:16.942489 T1002011C Write-Data Master configuration: 00000001 28
09:23:17.966690 T1002011C Write-Data Master configuration: 00000001 28
09:23:18.966793 T1002011C Write-Data Master configuration: 00000001 28
09:23:19.967947 T1002011C Write-Data Master configuration: 00000001 28
09:23:20.967173 T1002011C Write-Data Master configuration: 00000001 28
09:23:21.970215 1002011C
In the tech specs of the thermostat it does say:
The communication between the thermostat and the control
board of the boiler takes place by means of a two-wire
cable; the data are exchanged with the communication
protocol compatible OpenTherm ™ v3.0 Smart Power
Mode - Medium Power.
does that means I'd better give up ?
or anyone have a hint to try fixing the problem ?
Thanks in advance
Re: Connection to BRAHMA thermostat and "EMMETI" boiler
Posted: Fri Jan 03, 2020 11:52 pm
by hvxl
Your logs show that the messages from the thermostat are received properly. The Error 03 are coming from the boiler side. Given that the reference voltage setting almost exclusively affects the reception from the thermostat, there is not much sense in messing with that.
You describe both logs as being in monitor mode. The second one appears to be in gateway mode, as revealed by the "PR: M=G" response.
The OTGW supports OpenTherm v3.0 Smart Power, both medium and high power. But it does expect the devices to follow the specs. This means that both thermostat and boiler should start in low power mode and then negotiate to switch to medium power. As the OTGW has its own power, it doesn't need the boiler to provide extra power. It will therefor not ask the boiler to switch to medium power. If the thermostat requests a higher power level (medium or high), the OTGW will provide it, without involving the boiler.
With the OTGW in gateway mode, the thermostat repeats the same message when it doesn't get a response. With the OTGW in monitor mode, the thermostat requests different message IDs, suggesting that it is happy with the response it gets from the boiler. Yet, the OTGW can't make heads or tails of it. Possibly the boiler is always operating in medium power mode, even without being asked to do so via the methods defined in the opentherm specification. The OTGW does not currently handle such a situation.
One way to confirm if this is the case is to run the command DP=9C. This will report the CMCON register after each message. At those moments the OT lines should be idle. So, bit 6 and bit 7 should both be 1. Normally you would see C3 in gateway mode and C6 in monitor mode. If my theory is correct, I expect you to see 43 or 46.
Interesting would be to see logs of when you power up the boiler and connect the thermostat. Combined with the DP=9C test results, that would confirm if your equipment is really compatible with OpenTherm v3.0, or if they skip some vital steps and go straight into medium power mode.
Posted: Sat Jan 04, 2020 12:05 pm
by mcasamento
Thanks for your prompt reply!
I've issued the DP=9C command and as you expected, I see 9C=43 in the log
10:46:26.060352 Error 03
10:46:26.647251 T1002011C Write-Data Master configuration: 00000001 28
10:46:27.032586 Command: DP=9C
10:46:27.042043 rror 03
10:46:27.144766 DP: 9C
10:46:27.180485 9C=43
10:46:27.645828 T1002011C Write-Data Master configuration: 00000001 28
10:46:27.724847 9C=43
10:46:28.076281 Error 03
10:46:28.093093 9C=43
10:46:28.646539 T1002011C Write-Data Master configuration: 00000001 28
10:46:28.699925 9C=43
I'm now going to:
1. disconnect thermostat
2. shutdown boiler
3. restart otgw and issue DP=9C
4. power up boiler
5. connect thermostat and then post logs here
thanks again for your assistance
Marco
Posted: Sat Jan 04, 2020 12:21 pm
by mcasamento
Thanks for your prompt response
I've issued the "DP=9C" command and as you predicted the gateway started to return 9C=43
10:46:29.040012 Error 03
10:46:29.069176 9C=43
10:46:29.649571 T1002011C Write-Data Master configuration: 00000001 28
10:46:29.741316 9C=43
10:46:30.040200 Error 03
10:46:30.079540 9C=43
10:46:30.650593 1002011C
10:46:30.681969 9C=43
10:46:31.041528 Error 03
10:46:31.071098 9C=43
I've then:
1. disconnect the thermostat
2. shutdown the boiler
3. restart otgw
4. issued DP=9C
5. power up boiled
6. connected the thermostat
the relevant part of the logs are:
10:54:40.025183 Command: DP=9C
10:54:40.197395 DP: 9C
10:54:40.229976 9C=83
10:54:40.277508 R00000000 Read-Data Status: 00000000 00000000
- CH enable: disabled (0)
- DHW enable: disabled (0)
then I've powered up the boiler and a minute after connected the thermostat
10:55:04.375155 9C=83
10:55:05.165794 R00000000 Read-Data Status: 00000000 00000000
10:55:05.362572 9C=83
10:55:06.161501 00000000
10:55:06.194755 9C=83
10:55:07.006209 rror 03
10:55:07.040038 9C=83
10:55:07.166445 R00000000 Read-Data Status: 00000000 00000000
10:55:07.319975 9C=83
10:55:07.608005 BC0000000 Read-Ack Status: 00000000 00000000
- Fault indication: no fault (0)
- CH mode: not active (0)
- DHW mode: not active (0)
- Flame status: flame off (0)
- Cooling status: not active (0)
- CH2 mode: not active (0)
- Diagnostic indication: no diagnostics (0)
- Electricity production: not active (0)
10:55:07.836490 Command: PR=A
10:55:07.849805 9C=83
10:55:07.911838 PR: A=OpenTherm Gateway 4.2.5
10:55:07.920357 Command: SC=10:55/6
10:55:07.931698 Command: SR=21:01,04
10:55:07.942153 Command: SR=22:7,228
10:55:07.951983 9C=83
10:55:08.036520 SC: 10:55/6
10:55:08.070410 9C=83
10:55:08.115881 SR: 21:1/4
10:55:08.159510 9C=83
10:55:08.183149 SR: 22:7/228
10:55:08.207105 9C=83
10:55:08.228991 R80190000 Read-Data Boiler water temperature: 0.00
10:55:08.253351 9C=83
10:55:08.662798 B40191400 Read-Ack Boiler water temperature: 20.00
10:55:08.694877 9C=83
10:55:09.476964 R10010A00 Write-Data Control setpoint: 10.00
10:55:09.511354 9C=83
10:55:09.687646 BD0010A00 Write-Ack Control setpoint: 10.00
10:55:09.723062 9C=83
10:55:10.298087 R00060000 Read-Data Remote parameter flags: 00000000 00000000
10:55:10.332360 9C=83
10:55:10.604900 BC0060303 Read-Ack Remote parameter flags: 00000011 00000011
- DHW setpoint transfer: enabled (1)
- max CH setpoint transfer: enabled (1)
- DHW setpoint: read/write (1)
- max CH setpoint: read/write (1)
10:55:10.765613 9C=83
10:55:11.307046 R00110000 Read-Data Relative modulation level: 0.00
10:55:11.344389 9C=83
10:55:11.664130 BC0110000 Read-Ack Relative modulation level: 0.00
10:55:11.696321 9C=83
10:55:12.342718 R001B0000 Read-Data Outside temperature: 0.00
10:55:12.382984 9C=83
10:55:12.698272 BF01B0000 Unk-DataId Outside temperature: 0.00
10:55:12.721959 9C=83
10:55:13.386517 R801C0000 Read-Data Return water temperature: 0.00
10:55:13.424604 9C=83
10:55:13.716922 BC01C1F00 Read-Ack Return water temperature: 31.00
10:55:13.753705 9C=83
10:55:14.414715 900E6400
10:55:14.451969 9C=83
10:55:14.741970 B700E0000 Unk-DataId Maximum relative modulation level: 0.00
10:55:14.781495 9C=83
10:55:15.456057 00300000
10:55:15.505504 9C=83
10:55:15.750679 B40303C23 Read-Ack DHW setpoint boundaries: 60 35
10:55:15.789642 9C=83
10:55:16.491883 R00000000 Read-Data Status: 00000000 00000000
10:55:16.658634 9C=83
10:55:16.838956 BC0000000 Read-Ack Status: 00000000 00000000
10:55:17.043956 9C=83
10:55:17.529341 R80190000 Read-Data Boiler water temperature: 0.00
10:55:17.578252 9C=83
10:55:17.902027 BC0192600 Read-Ack Boiler water temperature: 38.00
10:55:17.936070 9C=83
10:55:18.564100 R10010A00 Write-Data Control setpoint: 10.00
10:55:18.594655 9C=83
10:55:18.965877 BD0010A00 Write-Ack Control setpoint: 10.00
10:55:19.001586 9C=83
10:55:19.595529 R80380000 Read-Data DHW setpoint: 0.00
10:55:19.640494 9C=83
10:55:19.975636 BC0382A00 Read-Ack DHW setpoint: 42.00
10:55:20.013496 9C=83
10:55:20.626156 R00390000 Read-Data Max CH water setpoint: 0.00
10:55:20.662041 9C=83
10:55:21.005246 B40393200 Read-Ack Max CH water setpoint: 50.00
10:55:21.044489 9C=83
10:55:21.663415 R80310000 Read-Data Max CH setpoint boundaries: 0 0
10:55:21.705724 9C=83
10:55:22.039436 B40315028 Read-Ack Max CH setpoint boundaries: 80 40
10:55:22.074381 9C=83
10:55:22.710948 00120000
10:55:22.749662 9C=83
10:55:23.109792 BC0120186 Read-Ack CH water pressure: 1.52
10:55:23.146994 9C=83
10:55:23.740753 00000000
10:55:23.777651 9C=83
10:55:24.125707 BC0000000 Read-Ack Status: 00000000 00000000
10:55:24.330084 9C=83
10:55:24.776762 R80190000 Read-Data Boiler water temperature: 0.00
10:55:24.830871 9C=83
10:55:25.146213 BC0192600 Read-Ack Boiler water temperature: 38.00
10:55:25.183437 9C=83
10:55:25.805919 R10010A00 Write-Data Control setpoint: 10.00
10:55:25.843342 9C=83
10:55:26.186890 BD0010A00 Write-Ack Control setpoint: 10.00
10:55:26.224326 9C=83
10:55:26.862345 R00740000 Read-Data Burner starts: 0
10:55:26.889505 9C=83
10:55:27.277050 BF0740000 Unk-DataId Burner starts: 0
10:55:27.328262 9C=83
10:55:27.884160 R00110000 Read-Data Relative modulation level: 0.00
10:55:27.914049 9C=83
10:55:28.272942 BC0110000 Read-Ack Relative modulation level: 0.00
10:55:28.317857 9C=83
10:55:28.922445 R001B0000 Read-Data Outside temperature: 0.00
10:55:28.946615 9C=83
10:55:29.302874 BF01B0000 Unk-DataId Outside temperature: 0.00
10:55:29.338808 9C=83
10:55:29.956788 R801C0000 Read-Data Return water temperature: 0.00
10:55:29.965582 9C=83
10:55:30.332543 BC01C1F00 Read-Ack Return water temperature: 31.00
10:55:30.351001 9C=83
10:55:30.980391 900E6400
10:55:31.004748 9C=83
10:55:31.367926 B700E0000 Unk-DataId Maximum relative modulation level: 0.00
10:55:31.413654 9C=83
10:55:32.012796 80750000
10:55:32.027428 9C=83
10:55:32.417575 B70750000 Unk-DataId CH pump starts: 0
10:55:32.429035 9C=83
10:55:33.050993 R00000000 Read-Data Status: 00000000 00000000
10:55:33.234294 9C=83
10:55:33.431858 BC0000000 Read-Ack Status: 00000000 00000000
10:55:33.537566 9C=83
10:55:34.082872 R80190000 Read-Data Boiler water temperature: 0.00
10:55:34.098063 9C=83
10:55:34.457923 BC0192600 Read-Ack Boiler water temperature: 38.00
10:55:34.468627 9C=83
10:55:35.118340 R10010A00 Write-Data Control setpoint: 10.00
10:55:35.150681 9C=83
10:55:35.493527 BD0010A00 Write-Ack Control setpoint: 10.00
10:55:35.536437 9C=83
10:55:36.163781 R80380000 Read-Data DHW setpoint: 0.00
10:55:36.200118 9C=83
10:55:36.530507 BC0382A00 Read-Ack DHW setpoint: 42.00
10:55:36.556732 9C=83
10:55:37.192138 R00390000 Read-Data Max CH water setpoint: 0.00
10:55:37.223962 9C=83
10:55:37.576216 B40393200 Read-Ack Max CH water setpoint: 50.00
10:55:37.585024 9C=83
10:55:38.231323 R80760000 Read-Data DHW pump/valve starts: 0
10:55:38.271545 9C=83
10:55:38.607861 B70760000 Unk-DataId DHW pump/valve starts: 0
10:55:38.633571 9C=83
10:55:39.641876 C0120186
10:55:39.680186 9C=83
10:55:40.912724 00000000
10:55:40.949984 9C=83
10:55:40.991403 BC0000000 Read-Ack Status: 00000000 00000000
10:55:41.126385 9C=83
10:55:41.630765 R80190000 Read-Data Boiler water temperature: 0.00
10:55:41.670308 9C=83
10:55:41.935795 BC0192600 Read-Ack Boiler water temperature: 38.00
10:55:41.948846 9C=83
10:55:42.360208 R10010A00 Write-Data Control setpoint: 10.00
10:55:42.387164 9C=83
10:55:42.743276 BD0010A00 Write-Ack Control setpoint: 10.00
10:55:42.781891 9C=83
10:55:43.393762 R00770000 Read-Data DHW burner starts: 0
10:55:43.426962 9C=83
10:55:43.890850 BF0770000 Unk-DataId DHW burner starts: 0
10:55:43.909963 9C=83
10:55:44.425957 R00110000 Read-Data Relative modulation level: 0.00
10:55:44.438919 9C=83
10:55:44.818125 BC0110000 Read-Ack Relative modulation level: 0.00
10:55:44.830634 9C=83
10:55:45.468110 R001B0000 Read-Data Outside temperature: 0.00
10:55:45.494086 9C=83
10:55:45.878104 BF01B0000 Unk-DataId Outside temperature: 0.00
10:55:45.919716 9C=83
10:55:46.506740 R801C0000 Read-Data Return water temperature: 0.00
10:55:46.539230 9C=83
10:55:46.893760 BC01C1F00 Read-Ack Return water temperature: 31.00
10:55:46.936834 9C=83
10:55:47.497595 9C=83
10:55:47.900849 B700E0000 Unk-DataId Maximum relative modulation level: 0.00
10:55:47.935259 9C=83
10:55:48.002145 .2.5
10:55:48.034087 9C=83
10:55:48.549975 R00780000 Read-Data Burner operation hours: 0
10:55:48.569172 9C=83
10:55:48.933881 BF0780000 Unk-DataId Burner operation hours: 0
10:55:48.976024 9C=83
10:55:49.583355 R00000000 Read-Data Status: 00000000 00000000
10:55:49.723372 9C=83
10:55:49.967090 BC0000000 Read-Ack Status: 00000000 00000000
10:55:50.197583 9C=83
10:55:50.615468 R80190000 Read-Data Boiler water temperature: 0.00
10:55:50.671294 9C=83
10:55:50.993360 BC0192600 Read-Ack Boiler water temperature: 38.00
10:55:51.027214 9C=83
10:55:51.656156 R10010A00 Write-Data Control setpoint: 10.00
10:55:51.705335 9C=83
10:55:52.010265 BD0010A00 Write-Ack Control setpoint: 10.00
10:55:52.052191 9C=83
10:55:52.691673 R80380000 Read-Data DHW setpoint: 0.00
10:55:52.741555 9C=83
10:55:53.064101 BC0382A00 Read-Ack DHW setpoint: 42.00
10:55:53.112446 9C=83
10:55:53.731356 R00390000 Read-Data Max CH water setpoint: 0.00
10:55:53.753696 9C=83
10:55:54.113881 B40393200 Read-Ack Max CH water setpoint: 50.00
10:55:54.149921 9C=83
10:55:54.760920 R80790000 Read-Data CH pump operation hours: 0
10:55:54.798750 9C=83
10:55:55.138991 B70790000 Unk-DataId CH pump operation hours: 0
10:55:55.171298 9C=83
10:55:55.790225 00120000
10:55:55.813376 9C=83
10:55:56.198761 C0120186
10:55:56.209715 9C=83
10:55:56.842652 R00000000 Read-Data Status: 00000000 00000000
10:55:57.023590 9C=83
10:55:57.214070 BC0000000 Read-Ack Status: 00000000 00000000
10:55:57.349814 9C=83
10:55:57.863622 R80190000 Read-Data Boiler water temperature: 0.00
10:55:57.895859 9C=83
10:55:58.247679 BC0192600 Read-Ack Boiler water temperature: 38.00
10:55:58.275675 9C=83
10:55:58.892868 R10010A00 Write-Data Control setpoint: 10.00
10:55:58.931711 9C=83
10:55:59.277249 BD0010A00 Write-Ack Control setpoint: 10.00
10:55:59.308125 9C=83
10:55:59.927647 R807A0000 Read-Data DHW pump/valve operation hours: 0
10:55:59.940083 9C=83
10:56:00.001388 Command: SC=10:56/6
10:56:00.146798 SC: 10:56/6
10:56:00.155828 9C=83
10:56:00.344163 B707A0000 Unk-DataId DHW pump/valve operation hours: 0
10:56:00.365792 9C=83
10:56:00.959068 R00110000 Read-Data Relative modulation level: 0.00
10:56:01.000248 9C=83
10:56:01.367862 BC0110000 Read-Ack Relative modulation level: 0.00
10:56:01.395632 9C=83
10:56:02.018865 R007B0000 Read-Data DHW burner operation hours: 0
10:56:02.060314 9C=83
10:56:02.379458 BF07B0000 Unk-DataId DHW burner operation hours: 0
10:56:02.405552 9C=83
10:56:03.028542 R801C0000 Read-Data Return water temperature: 0.00
10:56:03.055570 9C=83
10:56:03.403895 BC01C1F00 Read-Ack Return water temperature: 31.00
10:56:03.437710 9C=83
10:56:04.439519 F0740000
10:56:04.471082 9C=83
10:56:05.107825 R80750000 Read-Data CH pump starts: 0
10:56:05.141621 9C=83
10:56:05.511991 B70750000 Unk-DataId CH pump starts: 0
10:56:05.567208 9C=83
10:56:06.145903 R00000000 Read-Data Status: 00000000 00000000
10:56:06.334499 9C=83
10:56:06.446008 Error 03
10:56:06.505477 9C=C3
10:56:07.235526 R00000000 Read-Data Status: 00000000 00000000
10:56:07.433764 9C=C3
10:56:07.449325 Thermostat connected
10:56:07.635541 BC0000000 Read-Ack Status: 00000000 00000000
10:56:07.925091 9C=C3
10:56:10.142480 T1002011C Write-Data Master configuration: 00000001 28
10:56:10.226428 9C=C3
10:56:10.253040 Medium power
10:56:10.307418 T1002011C Write-Data Master configuration: 00000001 28
10:56:10.331010 9C=C3
10:56:10.720795 Error 03
10:56:10.759501 9C=43
10:56:11.633837 T1002011C Write-Data Master configuration: 00000001 28
10:56:11.694805 9C=43
10:56:12.043288 Error 03
10:56:12.079791 9C=43
10:56:12.451282 T1002011C Write-Data Master configuration: 00000001 28
10:56:12.535327 9C=43
10:56:12.865012 Error 03
10:56:12.897973 9C=43
10:56:13.726332 rror 03
10:56:13.765500 9C=43
10:56:14.337103 T1002011C Write-Data Master configuration: 00000001 28
10:56:14.399573 9C=43
10:56:14.725918 Error 03
10:56:14.765172 9C=43
10:56:15.339517 T1002011C Write-Data Master configuration: 00000001 28
10:56:15.397017 9C=43
10:56:15.737059 Error 03
10:56:15.774925 9C=43
10:56:16.337257 T1002011C Write-Data Master configuration: 00000001 28
10:56:16.415022 9C=43
10:56:16.749899 Error 03
10:56:16.790510 9C=43
10:56:17.340948 T1002011C Write-Data Master configuration: 00000001 28
10:56:17.423424 9C=43
10:56:17.761947 Error 03
10:56:17.799589 9C=43
10:56:18.338032 T1002011C Write-Data Master configuration: 00000001 28
10:56:18.435547 9C=43
10:56:18.730031 Error 03
10:56:18.771163 9C=43
Am I wrong or the OTGW has been able to read data from the boiler til I connected the thermostat ? that's light up some hopes maybe
Posted: Sat Jan 04, 2020 3:04 pm
by hvxl
It certainly looks that way. It also looks like the boiler is switching to Medium Power mode as soon as it receives the Master Configuration message that indicates the thermostat supports Smart Power. You could try configuring the OTGW not to pass this message on to the boiler (UI=2). Then disconnect the thermostat and get the OTGW and boiler communicating again. When you finally reconnect the thermostat, communication will hopefully continue to work.
Posted: Mon Jan 06, 2020 11:18 pm
by mcasamento
I've tried to:
2. shutdown boiler and otgw
3. power up boiler
4. wait for connection (and I believe it connected succesfully)
5. Issue UI=2
6. connect thermostat
Unfortunately it doesn't seems to work, or maybe I've misunderstood you
I've tried the same thing with some (probably irrelevant) variant but I'm attaching the log that I believe is most similar to what you suggested.
May you help to understand what should I look in the log or from where can I start to study what's happening ?
EDIT: it seems I can't attach file, so I'm pasting the log as code inside here
20:52:20.590693 C0000000
20:52:21.204837 R00000000 Read-Data Status: 00000000 00000000
20:52:21.601957 BC0000000 Read-Ack Status: 00000000 00000000
20:52:21.682673 Command: PR=A
20:52:21.825137 PR: A=OpenTherm Gateway 4.2.5
20:52:22.233244 R00000000 Read-Data Status: 00000000 00000000
20:52:22.608632 BC0000000 Read-Ack Status: 00000000 00000000
20:52:23.265513 R80190000 Read-Data Boiler water temperature: 0.00
20:52:23.633661 BC0192500 Read-Ack Boiler water temperature: 37.00
20:52:24.300226 R10010A00 Write-Data Control setpoint: 10.00
20:52:24.673253 BD0010A00 Write-Ack Control setpoint: 10.00
20:52:25.342167 R80380000 Read-Data DHW setpoint: 0.00
20:52:25.706630 B40382D00 Read-Ack DHW setpoint: 45.00
20:52:26.374051 R00390000 Read-Data Max CH water setpoint: 0.00
20:52:26.754915 B40393200 Read-Ack Max CH water setpoint: 50.00
20:52:27.405534 R00000000 Read-Data Status: 00000000 00000000
20:52:27.785455 BC0000000 Read-Ack Status: 00000000 00000000
20:52:28.434906 R00120000 Read-Data CH water pressure: 0.00
20:52:28.603632 Command: PR=M
20:52:28.730280 PR: M=G
20:52:28.824373 BC0120186 Read-Ack CH water pressure: 1.52
20:52:29.465772 R00000000 Read-Data Status: 00000000 00000000
20:52:29.848567 BC0000000 Read-Ack Status: 00000000 00000000
20:52:30.498913 R80190000 Read-Data Boiler water temperature: 0.00
20:52:30.911387 BC0192500 Read-Ack Boiler water temperature: 37.00
20:52:31.542033 R10010A00 Write-Data Control setpoint: 10.00
20:52:31.918322 BD0010A00 Write-Ack Control setpoint: 10.00
20:52:32.568868 R00000000 Read-Data Status: 00000000 00000000
20:52:32.946748 BC0000000 Read-Ack Status: 00000000 00000000
20:52:33.607796 R00110000 Read-Data Relative modulation level: 0.00
20:52:33.988493 BC0110000 Read-Ack Relative modulation level: 0.00
20:52:34.653223 R00000000 Read-Data Status: 00000000 00000000
20:52:35.013416 BC0000000 Read-Ack Status: 00000000 00000000
20:52:35.679010 R801C0000 Read-Data Return water temperature: 0.00
20:52:36.067587 B401C1D00 Read-Ack Return water temperature: 29.00
20:52:36.714926 R00000000 Read-Data Status: 00000000 00000000
20:52:36.825536 Command: PR=W
20:52:36.923757 PR: W=A
20:52:37.098271 BC0000000 Read-Ack Status: 00000000 00000000
20:52:37.744998 R00000000 Read-Data Status: 00000000 00000000
20:52:38.130716 BC0000000 Read-Ack Status: 00000000 00000000
20:52:38.778351 R00000000 Read-Data Status: 00000000 00000000
20:52:39.160062 BC0000000 Read-Ack Status: 00000000 00000000
20:52:39.808004 R80190000 Read-Data Boiler water temperature: 0.00
20:52:40.217330 BC0192500 Read-Ack Boiler water temperature: 37.00
20:52:40.849715 R10010A00 Write-Data Control setpoint: 10.00
20:52:41.227516 BD0010A00 Write-Ack Control setpoint: 10.00
20:52:41.877021 R80380000 Read-Data DHW setpoint: 0.00
20:52:42.260897 B40382D00 Read-Ack DHW setpoint: 45.00
20:52:42.909154 R00390000 Read-Data Max CH water setpoint: 0.00
20:52:43.281710 B40393200 Read-Ack Max CH water setpoint: 50.00
20:52:43.947874 R00000000 Read-Data Status: 00000000 00000000
20:52:44.361919 BC0000000 Read-Ack Status: 00000000 00000000
20:52:44.978742 R00120000 Read-Data CH water pressure: 0.00
20:52:45.337281 BC0120186 Read-Ack CH water pressure: 1.52
20:52:46.021494 R00000000 Read-Data Status: 00000000 00000000
20:52:46.396780 BC0000000 Read-Ack Status: 00000000 00000000
20:52:47.048201 R80190000 Read-Data Boiler water temperature: 0.00
20:52:47.410963 BC0192500 Read-Ack Boiler water temperature: 37.00
20:52:48.077646 R10010A00 Write-Data Control setpoint: 10.00
20:52:48.456511 BD0010A00 Write-Ack Control setpoint: 10.00
20:52:49.106681 R00000000 Read-Data Status: 00000000 00000000
20:52:49.520371 BC0000000 Read-Ack Status: 00000000 00000000
20:52:50.139092 R00110000 Read-Data Relative modulation level: 0.00
20:52:50.496412 BC0110000 Read-Ack Relative modulation level: 0.00
20:52:51.179387 R00000000 Read-Data Status: 00000000 00000000
20:52:51.553936 BC0000000 Read-Ack Status: 00000000 00000000
20:52:52.220491 R801C0000 Read-Data Return water temperature: 0.00
20:52:52.598253 B401C1D00 Read-Ack Return water temperature: 29.00
20:52:53.246178 R00000000 Read-Data Status: 00000000 00000000
20:52:53.416354 Command: SW=45.00
20:52:53.532201 SW: 45.00
20:52:53.627562 BC0000000 Read-Ack Status: 00000000 00000000
20:52:54.285361 R00000000 Read-Data Status: 00000000 00000000
20:52:54.687650 BC0000000 Read-Ack Status: 00000000 00000000
20:52:55.321210 R00000000 Read-Data Status: 00000000 00000000
20:52:55.702262 BC0000000 Read-Ack Status: 00000000 00000000
20:52:56.348409 R80190000 Read-Data Boiler water temperature: 0.00
20:52:56.736256 BC0192500 Read-Ack Boiler water temperature: 37.00
20:52:57.382565 R10010A00 Write-Data Control setpoint: 10.00
20:52:57.772378 BD0010A00 Write-Ack Control setpoint: 10.00
20:52:58.412258 R80380000 Read-Data DHW setpoint: 0.00
20:52:58.789075 B40382D00 Read-Ack DHW setpoint: 45.00
20:52:59.453816 R00390000 Read-Data Max CH water setpoint: 0.00
20:52:59.844539 B40393200 Read-Ack Max CH water setpoint: 50.00
20:53:00.493734 R00000000 Read-Data Status: 00000000 00000000
20:53:00.866205 BC0000000 Read-Ack Status: 00000000 00000000
20:53:01.530791 R00120000 Read-Data CH water pressure: 0.00
20:53:01.907723 BC0120186 Read-Ack CH water pressure: 1.52
20:53:02.572605 R00000000 Read-Data Status: 00000000 00000000
20:53:02.987858 BC0000000 Read-Ack Status: 00000000 00000000
20:53:03.604064 R80190000 Read-Data Boiler water temperature: 0.00
20:53:03.999671 BC0192500 Read-Ack Boiler water temperature: 37.00
20:53:04.630596 R10010A00 Write-Data Control setpoint: 10.00
20:53:05.013210 BD0010A00 Write-Ack Control setpoint: 10.00
20:53:05.661089 R00000000 Read-Data Status: 00000000 00000000
20:53:06.042424 BC0000000 Read-Ack Status: 00000000 00000000
20:53:06.692233 R00110000 Read-Data Relative modulation level: 0.00
20:53:06.705395 Command: HW=1
20:53:06.769380 HW: 1
20:53:07.074278 BC0110000 Read-Ack Relative modulation level: 0.00
20:53:07.723369 R80000200 Read-Data Status: 00000010 00000000
20:53:08.161936 B40000200 Read-Ack Status: 00000010 00000000
20:53:08.455596 Command: SH=51.97
20:53:08.531753 SH: 51.97
20:53:08.759202 R801C0000 Read-Data Return water temperature: 0.00
20:53:09.157163 B401C1D00 Read-Ack Return water temperature: 29.00
20:53:09.793554 R80000200 Read-Data Status: 00000010 00000000
20:53:10.132061 B40000200 Read-Ack Status: 00000010 00000000
20:53:10.828526 R80000200 Read-Data Status: 00000010 00000000
20:53:11.217722 B40000200 Read-Ack Status: 00000010 00000000
20:53:11.866154 R80000200 Read-Data Status: 00000010 00000000
20:53:12.247427 B40000200 Read-Ack Status: 00000010 00000000
20:53:12.894901 R80190000 Read-Data Boiler water temperature: 0.00
20:53:13.274019 BC0192500 Read-Ack Boiler water temperature: 37.00
20:53:13.922527 R10010A00 Write-Data Control setpoint: 10.00
20:53:14.330620 BD0010A00 Write-Ack Control setpoint: 10.00
20:53:14.965498 R80380000 Read-Data DHW setpoint: 0.00
20:53:15.346980 B40382D00 Read-Ack DHW setpoint: 45.00
20:53:15.996502 R00390000 Read-Data Max CH water setpoint: 0.00
20:53:16.381663 B40393200 Read-Ack Max CH water setpoint: 50.00
20:53:17.025860 R80000200 Read-Data Status: 00000010 00000000
20:53:17.407240 B40000200 Read-Ack Status: 00000010 00000000
20:53:18.054701 R00120000 Read-Data CH water pressure: 0.00
20:53:18.437839 BC0120186 Read-Ack CH water pressure: 1.52
20:53:19.083307 R80000200 Read-Data Status: 00000010 00000000
20:53:19.502095 B40000200 Read-Ack Status: 00000010 00000000
20:53:20.117738 R80190000 Read-Data Boiler water temperature: 0.00
20:53:20.511134 BC0192500 Read-Ack Boiler water temperature: 37.00
20:53:21.152984 R10010A00 Write-Data Control setpoint: 10.00
20:53:21.534411 BD0010A00 Write-Ack Control setpoint: 10.00
20:53:22.185240 R80000200 Read-Data Status: 00000010 00000000
20:53:22.562355 B40000200 Read-Ack Status: 00000010 00000000
20:53:23.209684 R00110000 Read-Data Relative modulation level: 0.00
20:53:23.589960 BC0110000 Read-Ack Relative modulation level: 0.00
20:53:24.239337 R80000200 Read-Data Status: 00000010 00000000
20:53:24.655841 B40000200 Read-Ack Status: 00000010 00000000
20:53:25.274269 R801C0000 Read-Data Return water temperature: 0.00
20:53:25.665713 B401C1D00 Read-Ack Return water temperature: 29.00
20:53:26.316813 R80000200 Read-Data Status: 00000010 00000000
20:53:26.695946 B40000200 Read-Ack Status: 00000010 00000000
20:53:27.344337 R80000200 Read-Data Status: 00000010 00000000
20:53:27.728013 B40000200 Read-Ack Status: 00000010 00000000
20:53:28.374679 R80000200 Read-Data Status: 00000010 00000000
20:53:28.797234 B40000200 Read-Ack Status: 00000010 00000000
20:53:29.415016 R80190000 Read-Data Boiler water temperature: 0.00
20:53:29.818998 BC0192500 Read-Ack Boiler water temperature: 37.00
20:53:30.450294 R10010A00 Write-Data Control setpoint: 10.00
20:53:30.834009 BD0010A00 Write-Ack Control setpoint: 10.00
20:53:31.247323 Command: TC=22.00
20:53:31.331192 TC: 22.00
20:53:31.483087 R80380000 Read-Data DHW setpoint: 0.00
20:53:31.862515 B40382D00 Read-Ack DHW setpoint: 45.00
20:53:32.510860 R00390000 Read-Data Max CH water setpoint: 0.00
20:53:32.888732 B40393200 Read-Ack Max CH water setpoint: 50.00
20:53:33.537261 R80000200 Read-Data Status: 00000010 00000000
20:53:33.920390 B40000200 Read-Ack Status: 00000010 00000000
20:53:34.567547 R00120000 Read-Data CH water pressure: 0.00
20:53:34.929266 BC0120186 Read-Ack CH water pressure: 1.52
20:53:35.613042 R80000200 Read-Data Status: 00000010 00000000
20:53:35.993177 B40000200 Read-Ack Status: 00000010 00000000
20:53:36.647282 R80190000 Read-Data Boiler water temperature: 0.00
20:53:37.014976 BC0192500 Read-Ack Boiler water temperature: 37.00
20:53:37.680731 R10010A00 Write-Data Control setpoint: 10.00
20:53:38.065426 BD0010A00 Write-Ack Control setpoint: 10.00
20:53:38.718022 R80000200 Read-Data Status: 00000010 00000000
20:53:39.128283 B40000200 Read-Ack Status: 00000010 00000000
20:53:39.747430 R00110000 Read-Data Relative modulation level: 0.00
20:53:40.092748 BC0110000 Read-Ack Relative modulation level: 0.00
20:53:40.774798 R80000200 Read-Data Status: 00000010 00000000
20:53:41.147899 B40000200 Read-Ack Status: 00000010 00000000
20:53:41.811600 R801C0000 Read-Data Return water temperature: 0.00
20:53:42.196919 B401C1D00 Read-Ack Return water temperature: 29.00
20:53:42.846132 R80000200 Read-Data Status: 00000010 00000000
20:53:43.220243 B40000200 Read-Ack Status: 00000010 00000000
20:53:43.881671 R80000200 Read-Data Status: 00000010 00000000
20:53:44.228140 B40000200 Read-Ack Status: 00000010 00000000
20:53:44.913394 R80000200 Read-Data Status: 00000010 00000000
20:53:45.148935 Command: PR=L
20:53:45.157424 Command: PR=G
20:53:45.229297 PR: L=FXOMPC
20:53:45.278047 B40000200 Read-Ack Status: 00000010 00000000
20:53:45.503831 PR: G=00
20:53:45.939488 R80190000 Read-Data Boiler water temperature: 0.00
20:53:46.138298 Command: PR=V
20:53:46.147470 Command: PR=T
20:53:46.159054 Command: PR=S
20:53:46.230063 PR: V=3
20:53:46.327584 BC0192500 Read-Ack Boiler water temperature: 37.00
20:53:46.434630 PR: T=11
20:53:46.472306 PR: S=16.00
20:53:46.974326 R10010A00 Write-Data Control setpoint: 10.00
20:53:47.362393 BD0010A00 Write-Ack Control setpoint: 10.00
20:53:48.033774 R80380000 Read-Data DHW setpoint: 0.00
20:53:48.391336 B40382D00 Read-Ack DHW setpoint: 45.00
20:53:49.037544 R00390000 Read-Data Max CH water setpoint: 0.00
20:53:49.451651 B40393200 Read-Ack Max CH water setpoint: 50.00
20:53:50.069847 R80000200 Read-Data Status: 00000010 00000000
20:53:50.460614 B40000200 Read-Ack Status: 00000010 00000000
20:53:51.108236 R00120000 Read-Data CH water pressure: 0.00
20:53:51.488279 BC0120186 Read-Ack CH water pressure: 1.52
20:53:52.137058 R80000200 Read-Data Status: 00000010 00000000
20:53:52.514494 B40000200 Read-Ack Status: 00000010 00000000
20:53:53.180752 R80190000 Read-Data Boiler water temperature: 0.00
20:53:53.599011 BC0192500 Read-Ack Boiler water temperature: 37.00
20:53:54.218282 R10010A00 Write-Data Control setpoint: 10.00
20:53:54.610076 BD0010A00 Write-Ack Control setpoint: 10.00
20:53:55.257154 R80000200 Read-Data Status: 00000010 00000000
20:53:55.635257 B40000200 Read-Ack Status: 00000010 00000000
20:53:56.119565 Command: UI=2
20:53:56.225900 UI: 2
20:53:56.308916 R00110000 Read-Data Relative modulation level: 0.00
20:53:56.662783 BC0110000 Read-Ack Relative modulation level: 0.00
20:53:57.311026 R80000200 Read-Data Status: 00000010 00000000
20:53:57.687865 B40000200 Read-Ack Status: 00000010 00000000
20:53:58.339230 R801C0000 Read-Data Return water temperature: 0.00
20:53:58.766525 B401C1D00 Read-Ack Return water temperature: 29.00
20:53:59.375643 R80000200 Read-Data Status: 00000010 00000000
20:53:59.785703 B40000200 Read-Ack Status: 00000010 00000000
20:54:00.405854 R80000200 Read-Data Status: 00000010 00000000
20:54:00.793641 B40000200 Read-Ack Status: 00000010 00000000
20:54:01.433879 R80000200 Read-Data Status: 00000010 00000000
20:54:01.812791 B40000200 Read-Ack Status: 00000010 00000000
20:54:02.476925 R80190000 Read-Data Boiler water temperature: 0.00
20:54:02.858943 BC0192500 Read-Ack Boiler water temperature: 37.00
20:54:03.508253 R10010A00 Write-Data Control setpoint: 10.00
20:54:03.930825 BD0010A00 Write-Ack Control setpoint: 10.00
20:54:04.541621 R80380000 Read-Data DHW setpoint: 0.00
20:54:04.931026 B40382D00 Read-Ack DHW setpoint: 45.00
20:54:05.581146 R00390000 Read-Data Max CH water setpoint: 0.00
20:54:05.952502 B40393200 Read-Ack Max CH water setpoint: 50.00
20:54:06.616214 R80000200 Read-Data Status: 00000010 00000000
20:54:06.973525 B40000200 Read-Ack Status: 00000010 00000000
20:54:07.655476 R00120000 Read-Data CH water pressure: 0.00
20:54:08.071614 BC0120186 Read-Ack CH water pressure: 1.52
20:54:08.683939 R80000200 Read-Data Status: 00000010 00000000
20:54:09.078835 B40000200 Read-Ack Status: 00000010 00000000
20:54:09.725103 R80190000 Read-Data Boiler water temperature: 0.00
20:54:10.087525 BC0192500 Read-Ack Boiler water temperature: 37.00
20:54:10.768417 R10010A00 Write-Data Control setpoint: 10.00
20:54:11.147177 BD0010A00 Write-Ack Control setpoint: 10.00
20:54:11.821087 R80000200 Read-Data Status: 00000010 00000000
20:54:12.221511 B40000200 Read-Ack Status: 00000010 00000000
20:54:12.855928 R00110000 Read-Data Relative modulation level: 0.00
20:54:13.233980 BC0110000 Read-Ack Relative modulation level: 0.00
20:54:13.896680 R80000200 Read-Data Status: 00000010 00000000
20:54:14.265692 B40000200 Read-Ack Status: 00000010 00000000
20:54:14.928514 R801C0000 Read-Data Return water temperature: 0.00
20:54:15.347846 B401C1D00 Read-Ack Return water temperature: 29.00
20:54:15.964545 R80000200 Read-Data Status: 00000010 00000000
20:54:16.364976 B40000200 Read-Ack Status: 00000010 00000000
20:54:17.002310 R80000200 Read-Data Status: 00000010 00000000
20:54:17.381993 B40000200 Read-Ack Status: 00000010 00000000
20:54:18.038365 R80000200 Read-Data Status: 00000010 00000000
20:54:18.410227 B40000200 Read-Ack Status: 00000010 00000000
20:54:19.061546 R80190000 Read-Data Boiler water temperature: 0.00
20:54:19.412426 BC0192500 Read-Ack Boiler water temperature: 37.00
20:54:20.094887 R10010A00 Write-Data Control setpoint: 10.00
20:54:20.518248 BD0010A00 Write-Ack Control setpoint: 10.00
20:54:21.135175 R80380000 Read-Data DHW setpoint: 0.00
20:54:21.526643 B40382D00 Read-Ack DHW setpoint: 45.00
20:54:22.174863 R00390000 Read-Data Max CH water setpoint: 0.00
20:54:22.555129 B40393200 Read-Ack Max CH water setpoint: 50.00
20:54:23.204073 R80000200 Read-Data Status: 00000010 00000000
20:54:23.581522 B40000200 Read-Ack Status: 00000010 00000000
20:54:24.246286 R00120000 Read-Data CH water pressure: 0.00
20:54:24.665824 BC0120186 Read-Ack CH water pressure: 1.52
20:54:25.282735 R80000200 Read-Data Status: 00000010 00000000
20:54:25.674292 B40000200 Read-Ack Status: 00000010 00000000
20:54:26.324596 R80190000 Read-Data Boiler water temperature: 0.00
20:54:26.699955 B40192400 Read-Ack Boiler water temperature: 36.00
20:54:27.365342 R10010A00 Write-Data Control setpoint: 10.00
20:54:27.747873 BD0010A00 Write-Ack Control setpoint: 10.00
20:54:28.402126 R80000200 Read-Data Status: 00000010 00000000
20:54:28.810613 B40000200 Read-Ack Status: 00000010 00000000
20:54:29.209867 Thermostat connected
20:54:32.206589 T1002011C Write-Data Master configuration: 00000001 28
20:54:32.277688 Medium power
20:54:33.610830 T1002011C Write-Data Master configuration: 00000001 28
20:54:34.008283 Error 03
20:54:34.638033 T1002011C Write-Data Master configuration: 00000001 28
20:54:35.035710 Error 03
20:54:35.638738 T1002011C Write-Data Master configuration: 00000001 28
20:54:35.966218 Error 03
20:54:36.636952 T1002011C Write-Data Master configuration: 00000001 28
20:54:37.035830 Error 03
20:54:37.637489 T1002011C Write-Data Master configuration: 00000001 28
20:54:38.034432 Error 03
20:54:38.638964 T1002011C Write-Data Master configuration: 00000001 28
20:54:39.041040 Error 03
20:54:39.639416 T1002011C Write-Data Master configuration: 00000001 28
20:54:40.059092 Error 03
20:54:40.639711 T1002011C Write-Data Master configuration: 00000001 28
20:54:41.024428 Error 03
20:54:41.643496 T1002011C Write-Data Master configuration: 00000001 28
20:54:42.073309 Error 03
20:54:42.642979 T1002011C Write-Data Master configuration: 00000001 28
Posted: Tue Jan 07, 2020 11:09 pm
by hvxl
The procedure is what I intended, but somehow the OTGW doesn't send an alternative message when it receives MsgID 2 from the thermostat. The only reason I can think of for that to happen is if the list of alternatives is empty. In that case the OTGW will still send the received message to the boiler. Did you happen to clear all alternative messages at some point?
Looking at the part of the log when it's just the OTGW talking to the boiler, it seems that way. The UserDefined slots in the message sequence are filled with status messages. That's what the OTGW does when there are no alternative messages available.
So, for the next try, first define an alternative message that your boiler supports, like the boiler water temperature (AA=25). The UI=2 command is stored in EEPROM, so it should not be necessary to repeat that, although it won't hurt either.
Posted: Wed Jan 08, 2020 4:07 pm
by mcasamento
Something has changed!!
I've issued AA=25 and restarted the boiler (it wouldn't connect to the OTGW without restarting).
Then I've connected the thermostat but the thermostat wouldn't connect, keep saying "Connecting...". After about a minute a button on the thermostat turned red, to indicate a faulty connection, I pressed it again, it tried to connect for a while with "Connecting..." on the display, but no success
Follow the relevant log
4:15:04.761809 B40000200 Read-Ack Status: 00000010 00000000
14:15:05.377459 R80190000 Read-Data Boiler water temperature: 0.00
14:15:05.776614 BC0192900 Read-Ack Boiler water temperature: 41.00
14:15:06.418030 R10010A00 Write-Data Control setpoint: 10.00
14:15:06.807632 BD0010A00 Write-Ack Control setpoint: 10.00
14:15:07.453397 R80380000 Read-Data DHW setpoint: 0.00
14:15:07.848085 B40382D00 Read-Ack DHW setpoint: 45.00
14:15:08.490520 R00390000 Read-Data Max CH water setpoint: 0.00
14:15:08.906092 B40393400 Read-Ack Max CH water setpoint: 52.00
14:15:09.525723 R80190000 Read-Data Boiler water temperature: 0.00
14:15:09.921745 BC0192900 Read-Ack Boiler water temperature: 41.00
14:15:10.556116 R00120000 Read-Data CH water pressure: 0.00
14:15:10.940471 B4012016C Read-Ack CH water pressure: 1.42
14:15:11.586758 R80000200 Read-Data Status: 00000010 00000000
14:15:11.964418 B40000200 Read-Ack Status: 00000010 00000000
14:15:12.628044 R80190000 Read-Data Boiler water temperature: 0.00
14:15:13.011204 BC0192900 Read-Ack Boiler water temperature: 41.00
14:15:13.658540 R10010A00 Write-Data Control setpoint: 10.00
14:15:14.062519 BD0010A00 Write-Ack Control setpoint: 10.00
14:15:14.697795 R80190000 Read-Data Boiler water temperature: 0.00
14:15:15.029177 BC0192900 Read-Ack Boiler water temperature: 41.00
14:15:15.736135 R00110000 Read-Data Relative modulation level: 0.00
14:15:16.122127 BC0110000 Read-Ack Relative modulation level: 0.00
14:15:16.765707 R80190000 Read-Data Boiler water temperature: 0.00
14:15:17.149780 BC0192900 Read-Ack Boiler water temperature: 41.00
14:15:17.801400 R801C0000 Read-Data Return water temperature: 0.00
14:15:18.214838 B401C1D00 Read-Ack Return water temperature: 29.00
14:15:18.827659 R80190000 Read-Data Boiler water temperature: 0.00
14:15:19.228322 BC0192900 Read-Ack Boiler water temperature: 41.00
14:15:19.868016 R80190000 Read-Data Boiler water temperature: 0.00
14:15:20.245297 BC0192900 Read-Ack Boiler water temperature: 41.00
14:15:20.894215 R80000200 Read-Data Status: 00000010 00000000
14:15:21.202012 Error 03
14:15:21.986662 R80000200 Read-Data Status: 00000010 00000000
14:15:22.220264 Thermostat connected
14:15:22.370006 B40000200 Read-Ack Status: 00000010 00000000
14:15:24.905937 T1002011C Write-Data Master configuration: 00000001 28
14:15:25.000772 R80190000 Read-Data Boiler water temperature: 0.00
14:15:25.028857 Medium power
14:15:25.096320 T1002011C Write-Data Master configuration: 00000001 28
14:15:25.142726 R80190000 Read-Data Boiler water temperature: 0.00
14:15:25.503204 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:25.542540 AD002011C Write-Ack Master configuration: 00000001 28
14:15:25.705914 T00030000 Read-Data Slave configuration: 00000000 0
14:15:26.107603 B40030100 Read-Ack Slave configuration: 00000001 0
- DHW: present (1)
- Control type: modulating (0)
- Cooling: not supported (0)
- DHW: instantaneous (0)
- Master pump control: allowed (0)
- CH2: not present (0)
- Remote water filling: available/unknown (0)
- Heat/cool mode control: heat (0)
14:15:26.373757 T00060000 Read-Data Remote parameter flags: 00000000 00000000
14:15:26.716638 BC0060303 Read-Ack Remote parameter flags: 00000011 00000011
14:15:27.304989 T00050000 Read-Data Application-specific flags: 00000000 0
14:15:27.726826 B40050100 Read-Ack Application-specific flags: 00000001 0
- Service request: yes (1)
- Lockout-reset: disabled (0)
- Low water pressure: no fault (0)
- Gas/flame fault: no fault (0)
- Air pressure fault: no fault (0)
- Water over-temperature: no fault (0)
14:15:27.921437 T000A0000 Read-Data Number of TSPs: 0
14:15:28.287313 BF00A0000 Unk-DataId Number of TSPs: 0
14:15:28.507771 T000C0000 Read-Data Size of fault buffer: 0
14:15:28.880796 BF00C0000 Unk-DataId Size of fault buffer: 0
14:15:29.107780 T00120000 Read-Data CH water pressure: 0.00
14:15:29.490121 B4012016C Read-Ack CH water pressure: 1.42
14:15:29.707318 T00110000 Read-Data Relative modulation level: 0.00
14:15:30.087398 BC0110000 Read-Ack Relative modulation level: 0.00
14:15:30.301365 T00120000 Read-Data CH water pressure: 0.00
14:15:30.691969 B4012016C Read-Ack CH water pressure: 1.42
14:15:30.901704 T80130000 Read-Data DHW flow rate: 0.00
14:15:31.284242 B70130000 Unk-DataId DHW flow rate: 0.00
14:15:31.508344 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:31.885336 BF0140000 Unk-DataId Day of week and time of day: Unk 00:00
14:15:31.904684 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:32.105010 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:32.496831 BF0140000 Unk-DataId Day of week and time of day: Unk 00:00
14:15:32.521906 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:32.702573 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:33.095788 BF0140000 Unk-DataId Day of week and time of day: Unk 00:00
14:15:33.139373 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:33.303107 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:33.330373 R80190000 Read-Data Boiler water temperature: 0.00
14:15:33.703435 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:33.765241 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:33.904080 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:33.954820 R80190000 Read-Data Boiler water temperature: 0.00
14:15:34.262639 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:34.312276 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:34.505278 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:34.545428 R80190000 Read-Data Boiler water temperature: 0.00
14:15:34.919493 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:34.979656 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:35.105891 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:35.122362 R80190000 Read-Data Boiler water temperature: 0.00
14:15:35.523982 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:35.577402 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:35.707494 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:35.749608 R80190000 Read-Data Boiler water temperature: 0.00
14:15:36.131329 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:36.196841 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:36.313537 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:36.333109 R80190000 Read-Data Boiler water temperature: 0.00
14:15:36.688603 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:36.733785 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:37.309891 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:37.367379 R80190000 Read-Data Boiler water temperature: 0.00
14:15:37.699230 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:37.736788 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:37.913398 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:37.951712 R80190000 Read-Data Boiler water temperature: 0.00
14:15:38.277917 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:38.336035 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:38.513294 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:38.544231 R80190000 Read-Data Boiler water temperature: 0.00
14:15:38.891019 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:38.942265 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:39.115663 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:39.166692 R80190000 Read-Data Boiler water temperature: 0.00
14:15:39.488449 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:39.536580 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:39.713361 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:39.746279 R80190000 Read-Data Boiler water temperature: 0.00
14:15:40.099860 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:40.153422 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:40.310383 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:40.329025 R80190000 Read-Data Boiler water temperature: 0.00
14:15:40.646255 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:40.678539 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:40.913698 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:40.938007 R80190000 Read-Data Boiler water temperature: 0.00
14:15:41.294487 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:41.310604 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:41.517841 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:41.564944 R80190000 Read-Data Boiler water temperature: 0.00
14:15:41.907470 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:41.967419 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:42.114561 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:42.159255 R80190000 Read-Data Boiler water temperature: 0.00
14:15:42.521020 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:42.565246 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:42.715007 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:42.772322 R80190000 Read-Data Boiler water temperature: 0.00
14:15:43.129786 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:43.199604 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:43.317244 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:43.334359 R80190000 Read-Data Boiler water temperature: 0.00
14:15:43.732213 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:43.765048 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:43.910559 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:43.932361 R80190000 Read-Data Boiler water temperature: 0.00
14:15:44.334893 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:44.414405 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:44.515966 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:44.563896 R80190000 Read-Data Boiler water temperature: 0.00
14:15:44.935480 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:44.979979 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:45.117091 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:45.170654 R80190000 Read-Data Boiler water temperature: 0.00
14:15:45.499434 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:45.535445 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:45.716364 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:45.746811 R80190000 Read-Data Boiler water temperature: 0.00
14:15:46.104076 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:46.162783 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:46.317364 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:46.358275 R80190000 Read-Data Boiler water temperature: 0.00
14:15:46.706119 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:46.748126 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:47.323659 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:47.391793 R80190000 Read-Data Boiler water temperature: 0.00
14:15:47.702307 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:47.743515 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:47.918755 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:47.944728 R80190000 Read-Data Boiler water temperature: 0.00
14:15:48.304130 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:48.324455 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:48.520185 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:48.580364 R80190000 Read-Data Boiler water temperature: 0.00
14:15:48.907955 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:48.962745 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:49.122474 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:49.171551 R80190000 Read-Data Boiler water temperature: 0.00
14:15:49.505030 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:49.548127 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:49.719750 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:49.765089 R80190000 Read-Data Boiler water temperature: 0.00
14:15:50.115299 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:50.157874 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:50.316417 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:50.392004 R80190000 Read-Data Boiler water temperature: 0.00
14:15:50.720471 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:50.757920 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:50.922896 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:51.001039 R80190000 Read-Data Boiler water temperature: 0.00
14:15:51.320406 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:51.381943 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:51.522363 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:51.585026 R80190000 Read-Data Boiler water temperature: 0.00
14:15:51.925575 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:51.973783 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:52.117612 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:52.137384 R80190000 Read-Data Boiler water temperature: 0.00
14:15:52.534867 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:52.570805 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:52.722568 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:52.762885 R80190000 Read-Data Boiler water temperature: 0.00
14:15:53.135658 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:53.187712 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:53.317445 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:53.362193 R80190000 Read-Data Boiler water temperature: 0.00
14:15:53.706781 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:53.776943 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:53.918913 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:53.978745 R80190000 Read-Data Boiler water temperature: 0.00
14:15:54.299969 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:54.330316 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:54.518867 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:54.583626 R80190000 Read-Data Boiler water temperature: 0.00
14:15:54.898048 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:54.955577 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:55.124188 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:55.175086 R80190000 Read-Data Boiler water temperature: 0.00
14:15:55.498804 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:55.536835 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:55.723490 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:55.776453 R80190000 Read-Data Boiler water temperature: 0.00
14:15:56.109448 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:56.162655 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:56.326764 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:56.385450 R80190000 Read-Data Boiler water temperature: 0.00
14:15:56.705096 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:56.724372 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:57.326753 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:57.364191 R80190000 Read-Data Boiler water temperature: 0.00
14:15:57.711024 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:57.767901 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:57.924948 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:57.963382 R80190000 Read-Data Boiler water temperature: 0.00
14:15:58.306240 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:58.339332 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:58.521842 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:58.572075 R80190000 Read-Data Boiler water temperature: 0.00
14:15:58.922239 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:58.991155 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:59.127728 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:59.163921 R80190000 Read-Data Boiler water temperature: 0.00
14:15:59.522837 B40192800 Read-Ack Boiler water temperature: 40.00
14:15:59.567950 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:15:59.726508 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:15:59.783240 R80190000 Read-Data Boiler water temperature: 0.00
14:16:00.128541 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:00.149719 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:00.330170 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:00.363277 R80190000 Read-Data Boiler water temperature: 0.00
14:16:00.743522 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:00.761618 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:00.928347 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:00.947003 R80190000 Read-Data Boiler water temperature: 0.00
14:16:01.345430 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:01.379421 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:01.526635 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:01.563037 R80190000 Read-Data Boiler water temperature: 0.00
14:16:01.942726 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:01.982317 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:02.123551 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:02.166835 R80190000 Read-Data Boiler water temperature: 0.00
14:16:02.518929 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:02.576386 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:02.728192 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:02.746026 R80190000 Read-Data Boiler water temperature: 0.00
14:16:03.120797 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:03.160805 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:03.329159 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:03.349393 R80190000 Read-Data Boiler water temperature: 0.00
14:16:03.710908 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:03.751368 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:03.924593 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:03.969786 R80190000 Read-Data Boiler water temperature: 0.00
14:16:04.312555 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:04.371013 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:04.531466 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:04.566460 R80190000 Read-Data Boiler water temperature: 0.00
14:16:04.910070 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:04.947808 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:05.125730 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:05.170416 R80190000 Read-Data Boiler water temperature: 0.00
14:16:05.508074 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:05.527869 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:05.733644 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:05.764014 R80190000 Read-Data Boiler water temperature: 0.00
14:16:06.148186 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:06.205429 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:06.331559 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:06.349080 R80190000 Read-Data Boiler water temperature: 0.00
14:16:06.722674 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:06.772371 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:07.334837 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:07.401098 R80190000 Read-Data Boiler water temperature: 0.00
14:16:07.726757 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:07.806082 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:07.932647 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:07.976532 R80190000 Read-Data Boiler water temperature: 0.00
14:16:08.291730 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:08.374693 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:08.533219 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:08.576465 R80190000 Read-Data Boiler water temperature: 0.00
14:16:08.940102 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:09.005984 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:09.130949 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:09.175206 R80190000 Read-Data Boiler water temperature: 0.00
14:16:09.545097 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:09.623693 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:09.732271 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:09.762216 R80190000 Read-Data Boiler water temperature: 0.00
14:16:10.154863 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:10.193138 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:10.332708 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:10.360488 R80190000 Read-Data Boiler water temperature: 0.00
14:16:10.715346 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:10.755313 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:10.935655 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:10.972590 R80190000 Read-Data Boiler water temperature: 0.00
14:16:11.318259 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:11.353167 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:11.535090 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:11.575534 R80190000 Read-Data Boiler water temperature: 0.00
14:16:11.887954 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:11.914286 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:12.134148 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:12.186981 R80190000 Read-Data Boiler water temperature: 0.00
14:16:12.507948 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:12.564889 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:12.737962 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:12.804838 R80190000 Read-Data Boiler water temperature: 0.00
14:16:13.119710 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:13.158374 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:13.333547 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:13.404860 R80190000 Read-Data Boiler water temperature: 0.00
14:16:13.715268 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:13.756528 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:13.942273 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:14.011086 R80190000 Read-Data Boiler water temperature: 0.00
14:16:14.320150 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:14.358353 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:14.538813 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:14.581217 R80190000 Read-Data Boiler water temperature: 0.00
14:16:14.920114 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:14.964510 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:15.140404 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:15.179934 R80190000 Read-Data Boiler water temperature: 0.00
14:16:15.521952 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:15.561378 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:15.738360 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:15.780632 R80190000 Read-Data Boiler water temperature: 0.00
14:16:18.283273 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:18.332322 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:18.381585 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:18.410546 R80190000 Read-Data Boiler water temperature: 0.00
14:16:18.437351 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:18.465421 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:18.494025 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:18.523073 R80190000 Read-Data Boiler water temperature: 0.00
14:16:18.552574 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:18.581945 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:18.612538 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:18.640743 R80190000 Read-Data Boiler water temperature: 0.00
14:16:18.670305 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:18.699180 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:18.728811 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:18.756752 R80190000 Read-Data Boiler water temperature: 0.00
14:16:18.961345 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:18.999412 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:19.137613 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:19.217950 R80190000 Read-Data Boiler water temperature: 0.00
14:16:19.562521 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:19.610210 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:19.746607 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:19.787822 R80190000 Read-Data Boiler water temperature: 0.00
14:16:20.115967 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:20.177858 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:20.345395 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:20.398288 R80190000 Read-Data Boiler water temperature: 0.00
14:16:20.722302 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:20.783160 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:20.942919 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:21.011191 R80190000 Read-Data Boiler water temperature: 0.00
14:16:21.329107 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:21.350279 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:21.541984 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:21.561191 R80190000 Read-Data Boiler water temperature: 0.00
14:16:21.926723 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:22.001688 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:22.139700 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:22.185160 R80190000 Read-Data Boiler water temperature: 0.00
14:16:22.529795 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:22.563355 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:22.741949 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:22.786483 R80190000 Read-Data Boiler water temperature: 0.00
14:16:23.127815 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:23.184756 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:23.344157 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:23.373938 R80190000 Read-Data Boiler water temperature: 0.00
14:16:23.732554 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:23.784419 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:23.940414 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:23.989102 R80190000 Read-Data Boiler water temperature: 0.00
14:16:24.336797 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:24.387283 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:24.541154 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:24.615235 R80190000 Read-Data Boiler water temperature: 0.00
14:16:24.943357 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:24.984690 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:25.145763 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:25.212226 R80190000 Read-Data Boiler water temperature: 0.00
14:16:25.546460 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:25.613337 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:25.748225 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:25.804359 R80190000 Read-Data Boiler water temperature: 0.00
14:16:26.148895 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:26.210030 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:26.342100 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:26.380657 R80190000 Read-Data Boiler water temperature: 0.00
14:16:26.753300 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:26.812683 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:27.348290 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:27.395197 R80190000 Read-Data Boiler water temperature: 0.00
14:16:27.714593 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:27.781104 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:27.945664 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:27.964884 R80190000 Read-Data Boiler water temperature: 0.00
14:16:28.327785 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:28.380181 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:28.542789 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:28.600341 R80190000 Read-Data Boiler water temperature: 0.00
14:16:28.932052 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:28.968267 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:29.148135 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:29.203949 R80190000 Read-Data Boiler water temperature: 0.00
14:16:29.528066 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:29.577917 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:29.749207 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:29.768391 R80190000 Read-Data Boiler water temperature: 0.00
14:16:30.133136 B40192800 Read-Ack Boiler water temperature: 40.00
14:16:30.156470 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:30.349636 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:30.388568 R80190000 Read-Data Boiler water temperature: 0.00
14:16:30.726028 B40192700 Read-Ack Boiler water temperature: 39.00
14:16:30.778842 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:30.946439 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:30.964575 R80190000 Read-Data Boiler water temperature: 0.00
14:16:31.331794 B40192700 Read-Ack Boiler water temperature: 39.00
14:16:31.403197 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:31.547808 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:31.590865 R80190000 Read-Data Boiler water temperature: 0.00
14:16:31.929981 B40192700 Read-Ack Boiler water temperature: 39.00
14:16:31.981418 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:32.157119 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:32.216192 R80190000 Read-Data Boiler water temperature: 0.00
14:16:32.530491 B40192700 Read-Ack Boiler water temperature: 39.00
14:16:32.566074 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:32.746041 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:32.786127 R80190000 Read-Data Boiler water temperature: 0.00
14:16:33.143207 B40192700 Read-Ack Boiler water temperature: 39.00
14:16:33.217344 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:33.345748 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:33.409164 R80190000 Read-Data Boiler water temperature: 0.00
14:16:33.695690 B40192700 Read-Ack Boiler water temperature: 39.00
14:16:33.776664 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:33.947870 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:34.006870 R80190000 Read-Data Boiler water temperature: 0.00
14:16:34.351141 B40192700 Read-Ack Boiler water temperature: 39.00
14:16:34.405087 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:34.552588 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:34.590713 R80190000 Read-Data Boiler water temperature: 0.00
14:16:34.957517 B40192700 Read-Ack Boiler water temperature: 39.00
14:16:34.996722 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:35.151145 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:35.169069 R80190000 Read-Data Boiler water temperature: 0.00
14:16:35.575869 B40192700 Read-Ack Boiler water temperature: 39.00
14:16:35.603464 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:35.748206 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:35.809925 R80190000 Read-Data Boiler water temperature: 0.00
14:16:36.168806 B40192700 Read-Ack Boiler water temperature: 39.00
14:16:36.210043 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:36.356145 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:36.418298 R80190000 Read-Data Boiler water temperature: 0.00
14:16:36.726447 B40192700 Read-Ack Boiler water temperature: 39.00
14:16:36.773635 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:37.349529 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:37.401708 R80190000 Read-Data Boiler water temperature: 0.00
14:16:37.732183 B40192700 Read-Ack Boiler water temperature: 39.00
14:16:37.768706 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:37.953444 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:37.999925 R80190000 Read-Data Boiler water temperature: 0.00
14:16:38.332814 B40192700 Read-Ack Boiler water temperature: 39.00
14:16:38.398583 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:38.556621 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:38.602830 R80190000 Read-Data Boiler water temperature: 0.00
14:16:38.944368 B40192700 Read-Ack Boiler water temperature: 39.00
14:16:38.990308 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:39.153951 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:39.202611 R80190000 Read-Data Boiler water temperature: 0.00
14:16:39.532260 B40192700 Read-Ack Boiler water temperature: 39.00
14:16:39.574813 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:39.764732 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:39.803892 R80190000 Read-Data Boiler water temperature: 0.00
14:16:40.135702 B40192700 Read-Ack Boiler water temperature: 39.00
14:16:40.169471 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:40.357352 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:40.405712 R80190000 Read-Data Boiler water temperature: 0.00
14:16:40.739803 B40192700 Read-Ack Boiler water temperature: 39.00
14:16:40.771956 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:40.955946 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:41.005943 R80190000 Read-Data Boiler water temperature: 0.00
14:16:41.339643 B40192700 Read-Ack Boiler water temperature: 39.00
14:16:41.356313 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:41.556751 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:41.573140 R80190000 Read-Data Boiler water temperature: 0.00
14:16:41.945853 B40192700 Read-Ack Boiler water temperature: 39.00
14:16:42.017383 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:42.158309 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:42.210633 R80190000 Read-Data Boiler water temperature: 0.00
14:16:42.557870 B40192700 Read-Ack Boiler water temperature: 39.00
14:16:42.595368 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:42.767081 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:42.799405 R80190000 Read-Data Boiler water temperature: 0.00
14:16:44.239645 OpenTherm Gateway 4.2.5
14:16:47.123328 T1002011C Write-Data Master configuration: 00000001 28
- Smart power: supported (1)
14:16:47.198377 R00060000 Read-Data Remote parameter flags: 00000000 00000000
14:16:47.230368 Medium power
14:16:47.350544 T1002011C Write-Data Master configuration: 00000001 28
14:16:47.453099 R00060000 Read-Data Remote parameter flags: 00000000 00000000
14:16:47.726485 BC0060303 Read-Ack Remote parameter flags: 00000011 00000011
- DHW setpoint transfer: enabled (1)
- max CH setpoint transfer: enabled (1)
- DHW setpoint: read/write (1)
- max CH setpoint: read/write (1)
14:16:47.928511 AD002011C Write-Ack Master configuration: 00000001 28
14:16:47.987178 T00030000 Read-Data Slave configuration: 00000000 0
14:16:48.328767 B40030100 Read-Ack Slave configuration: 00000001 0
- DHW: present (1)
14:16:48.571278 T00060000 Read-Data Remote parameter flags: 00000000 00000000
14:16:48.946438 BC0060303 Read-Ack Remote parameter flags: 00000011 00000011
14:16:49.151422 T00050000 Read-Data Application-specific flags: 00000000 0
14:16:49.530235 B40050100 Read-Ack Application-specific flags: 00000001 0
14:16:49.751061 T000A0000 Read-Data Number of TSPs: 0
14:16:50.136243 BF00A0000 Unk-DataId Number of TSPs: 0
14:16:50.352098 T000C0000 Read-Data Size of fault buffer: 0
14:16:50.759408 BF00C0000 Unk-DataId Size of fault buffer: 0
14:16:50.958161 T90101201 Write-Data Room setpoint: 18.00
14:16:51.356022 B70100000 Unk-DataId Room setpoint: 0.00
14:16:51.391178 AD0100000 Write-Ack Room setpoint: 0.00
14:16:51.553018 T90101201 Write-Data Room setpoint: 18.00
14:16:51.960560 B70100000 Unk-DataId Room setpoint: 0.00
14:16:51.993020 AD0100000 Write-Ack Room setpoint: 0.00
14:16:52.153036 T90101201 Write-Data Room setpoint: 18.00
14:16:52.569455 B70100000 Unk-DataId Room setpoint: 0.00
14:16:52.603722 AD0100000 Write-Ack Room setpoint: 0.00
14:16:52.755097 T90101201 Write-Data Room setpoint: 18.00
14:16:52.800464 R00300000 Read-Data DHW setpoint boundaries: 0 0
14:16:53.172362 B40303C23 Read-Ack DHW setpoint boundaries: 60 35
14:16:53.203859 A50101201 Write-Ack Room setpoint: 18.00
14:16:53.358704 T00110000 Read-Data Relative modulation level: 0.00
14:16:53.778645 BC0110000 Read-Ack Relative modulation level: 0.00
14:16:53.956535 T00120000 Read-Data CH water pressure: 0.00
14:16:54.335703 B4012016C Read-Ack CH water pressure: 1.42
14:16:54.554289 T80130000 Read-Data DHW flow rate: 0.00
14:16:54.938745 B70130000 Unk-DataId DHW flow rate: 0.00
14:16:55.154293 T90101201 Write-Data Room setpoint: 18.00
14:16:55.200698 R80310000 Read-Data Max CH setpoint boundaries: 0 0
14:16:55.540042 B40315028 Read-Ack Max CH setpoint boundaries: 80 40
14:16:55.573946 A50101201 Write-Ack Room setpoint: 18.00
14:16:55.756942 T00110000 Read-Data Relative modulation level: 0.00
14:16:56.137272 BC0110000 Read-Ack Relative modulation level: 0.00
14:16:56.358392 T00120000 Read-Data CH water pressure: 0.00
14:16:56.740072 B4012016C Read-Ack CH water pressure: 1.42
14:16:57.358346 T80130000 Read-Data DHW flow rate: 0.00
14:16:57.737593 B70130000 Unk-DataId DHW flow rate: 0.00
14:16:57.957078 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:58.344703 BF0140000 Unk-DataId Day of week and time of day: Unk 00:00
14:16:58.385169 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:58.559741 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:58.950653 BF0140000 Unk-DataId Day of week and time of day: Unk 00:00
14:16:58.988856 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:59.157382 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:59.518743 BF0140000 Unk-DataId Day of week and time of day: Unk 00:00
14:16:59.549032 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:16:59.758972 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:16:59.811397 R80190000 Read-Data Boiler water temperature: 0.00
14:17:00.163754 B40192700 Read-Ack Boiler water temperature: 39.00
14:17:00.181694 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:17:00.360213 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:17:00.400339 R80190000 Read-Data Boiler water temperature: 0.00
14:17:00.725700 B40192700 Read-Ack Boiler water temperature: 39.00
14:17:00.761568 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:17:00.959683 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:17:00.999393 R80190000 Read-Data Boiler water temperature: 0.00
14:17:01.378876 B40192700 Read-Ack Boiler water temperature: 39.00
14:17:01.400228 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:17:01.561571 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:17:01.588790 R80190000 Read-Data Boiler water temperature: 0.00
14:17:01.936210 B40192700 Read-Ack Boiler water temperature: 39.00
14:17:01.978731 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:17:02.160258 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:17:02.201450 R80190000 Read-Data Boiler water temperature: 0.00
14:17:02.544180 B40192700 Read-Ack Boiler water temperature: 39.00
14:17:02.605089 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:17:02.762895 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:17:02.808375 R80190000 Read-Data Boiler water temperature: 0.00
14:17:03.144848 B40192700 Read-Ack Boiler water temperature: 39.00
14:17:03.161546 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:17:03.359579 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:17:03.408464 R80190000 Read-Data Boiler water temperature: 0.00
14:17:03.749243 B40192700 Read-Ack Boiler water temperature: 39.00
14:17:03.792136 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:17:03.960289 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:17:03.984445 R80190000 Read-Data Boiler water temperature: 0.00
14:17:04.325493 B40192700 Read-Ack Boiler water temperature: 39.00
14:17:04.381033 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:17:04.563314 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:17:04.616511 R80190000 Read-Data Boiler water temperature: 0.00
14:17:04.946940 B40192700 Read-Ack Boiler water temperature: 39.00
14:17:05.013130 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:17:05.162241 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:17:05.224401 R80190000 Read-Data Boiler water temperature: 0.00
14:17:05.531176 B40192700 Read-Ack Boiler water temperature: 39.00
14:17:05.549001 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:17:05.763788 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:17:05.782412 R80190000 Read-Data Boiler water temperature: 0.00
14:17:06.139714 B40192700 Read-Ack Boiler water temperature: 39.00
14:17:06.158211 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:17:06.361754 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:17:06.385200 R80190000 Read-Data Boiler water temperature: 0.00
14:17:06.748036 B40192700 Read-Ack Boiler water temperature: 39.00
14:17:06.780425 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:17:07.364519 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:17:07.426995 R80190000 Read-Data Boiler water temperature: 0.00
14:17:07.753448 B40192700 Read-Ack Boiler water temperature: 39.00
14:17:07.795528 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:17:07.966805 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:17:08.016906 R80190000 Read-Data Boiler water temperature: 0.00
14:17:08.367953 B40192700 Read-Ack Boiler water temperature: 39.00
14:17:08.437846 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:17:08.564507 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:17:08.614515 R80190000 Read-Data Boiler water temperature: 0.00
14:17:08.977118 B40192700 Read-Ack Boiler water temperature: 39.00
14:17:09.029586 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:17:09.165784 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:17:09.183943 R80190000 Read-Data Boiler water temperature: 0.00
14:17:10.168454 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:17:10.229929 R80190000 Read-Data Boiler water temperature: 0.00
14:17:10.585336 B40192700 Read-Ack Boiler water temperature: 39.00
14:17:10.628567 AC0140000 Read-Ack Day of week and time of day: Unk 00:00
14:17:10.767849 T00140000 Read-Data Day of week and time of day: Unk 00:00
14:17:10.806008 R80190000 Read-Data Boiler water temperature: 0.00
14:17:10.898679 High power
14:17:10.946397 Thermostat disconnected
14:17:10.966588 R00000000 Read-Data Status: 00000000 00000000
- CH enable: disabled (0)
- DHW enable: disabled (0)
- Cooling enable: disabled (0)
- OTC active: not active (0)
- CH2 enable: disabled (0)
- Summer/winter mode: winter (0)
- DHW blocking: unblocked (0)
14:17:11.212131 BC0000000 Read-Ack Status: 00000000 00000000
- Fault indication: no fault (0)
- CH mode: not active (0)
- DHW mode: not active (0)
- Flame status: flame off (0)
- Cooling status: not active (0)
- CH2 mode: not active (0)
- Diagnostic indication: no diagnostics (0)
- Electricity production: not active (0)
14:17:11.974151 R80190000 Read-Data Boiler water temperature: 0.00
14:17:12.341921 B40192700 Read-Ack Boiler water temperature: 39.00
14:17:13.005382 R10010A00 Write-Data Control setpoint: 10.00
14:17:13.384622 BD0010A00 Write-Ack Control setpoint: 10.00
14:17:14.048606 R80190000 Read-Data Boiler water temperature: 0.00
14:17:14.439075 B40192700 Read-Ack Boiler water temperature: 39.00
14:17:15.086463 R00110000 Read-Data Relative modulation level: 0.00
14:17:15.466146 BC0110000 Read-Ack Relative modulation level: 0.00
14:17:16.126845 R001B0000 Read-Data Outside temperature: 0.00
14:17:16.504552 BF01B0000 Unk-DataId Outside temperature: 0.00
14:17:17.168891 R801C0000 Read-Data Return water temperature: 0.00
14:17:17.536975 B401C1D00 Read-Ack Return water temperature: 29.00
14:17:18.203523 R900E6400 Write-Data Maximum relative modulation level: 100.00
14:17:18.548976 B700E0000 Unk-DataId Maximum relative modulation level: 0.00
14:17:19.232624 R80190000 Read-Data Boiler water temperature: 0.00
14:17:19.609704 B40192700 Read-Ack Boiler water temperature: 39.00
14:17:20.272786 R00000000 Read-Data Status: 00000000 00000000
14:17:20.655521 BC0000000 Read-Ack Status: 00000000 00000000
14:17:21.316599 R80190000 Read-Data Boiler water temperature: 0.00
14:17:21.727257 B40192700 Read-Ack Boiler water temperature: 39.00
14:17:22.344522 R10010A00 Write-Data Control setpoint: 10.00
14:17:22.745388 BD0010A00 Write-Ack Control setpoint: 10.00
14:17:23.374403 R80380000 Read-Data DHW setpoint: 0.00
14:17:23.756107 B40382D00 Read-Ack DHW setpoint: 45.00
14:17:24.403709 R00390000 Read-Data Max CH water setpoint: 0.00
14:17:24.776291 B40393400 Read-Ack Max CH water setpoint: 52.00
14:17:25.445273 R80190000 Read-Data Boiler water temperature: 0.00
14:17:25.820940 B40192700 Read-Ack Boiler water temperature: 39.00
14:17:26.482069 R00120000 Read-Data CH water pressure: 0.00
14:17:26.850868 B4012016C Read-Ack CH water pressure: 1.42
14:17:27.516053 R00000000 Read-Data Status: 00000000 00000000
14:17:27.860235 BC0000000 Read-Ack Status: 00000000 00000000
14:17:28.554209 R80190000 Read-Data Boiler water temperature: 0.00
14:17:28.920426 B40192700 Read-Ack Boiler water temperature: 39.00
14:17:29.570663 R10010A00 Write-Data Control setpoint: 10.00
14:17:29.953457 BD0010A00 Write-Ack Control setpoint: 10.00
14:17:30.604437 R80190000 Read-Data Boiler water temperature: 0.00
14:17:30.985378 B40192700 Read-Ack Boiler water temperature: 39.00
14:17:31.632834 R00110000 Read-Data Relative modulation level: 0.00
14:17:32.050545 BC0110000 Read-Ack Relative modulation level: 0.00
14:17:32.669762 R001B0000 Read-Data Outside temperature: 0.00
14:17:33.064796 BF01B0000 Unk-DataId Outside temperature: 0.00
14:17:33.700441 R801C0000 Read-Data Return water temperature: 0.00
14:17:34.077896 B401C1D00 Read-Ack Return water temperature: 29.00
14:17:34.725254 R900E6400 Write-Data Maximum relative modulation level: 100.00
14:17:35.102340 B700E0000 Unk-DataId Maximum relative modulation level: 0.00
14:17:35.771014 R80190000 Read-Data Boiler water temperature: 0.00
14:17:36.140284 B40192700 Read-Ack Boiler water temperature: 39.00
14:17:36.802586 R00000000 Read-Data Status: 00000000 00000000
14:17:37.171135 BC0000000 Read-Ack Status: 00000000 00000000
14:17:37.835711 R80190000 Read-Data Boiler water temperature: 0.00
14:17:38.187910 B40192700 Read-Ack Boiler water temperature: 39.00
14:17:38.868021 R10010A00 Write-Data Control setpoint: 10.00
14:17:39.241927 BD0010A00 Write-Ack Control setpoint: 10.00
14:17:39.904640 R80380000 Read-Data DHW setpoint: 0.00
14:17:40.273520 B40382D00 Read-Ack DHW setpoint: 45.00
14:17:40.949951 R00390000 Read-Data Max CH water setpoint: 0.00
14:17:41.314363 B40393400 Read-Ack Max CH water setpoint: 52.00
it has however practically stopped to send 03 Errors, we're making progress!
How can we try to understand what's needed to make the thermostat connect to OTGW ? Should I try to some how sniff communication in monitor mode ? If yes, should I first empty UI and AA messages ?
Thank you very much for your assistance!
Re: Connection to BRAHMA thermostat and "EMMETI" boiler
Posted: Wed Jan 08, 2020 6:17 pm
by hvxl
Ah, progress! Now the thermostat seems unhappy about the response to MsgID 20. Rather than responding Unk-DataId as the boiler does, the OTGW returns Read-Data, but with a day of week of 0. This is supposed to mean "no DoW info available", but the thermostat possibly considers it invalid. This may need to be changed in the firmware.
For now, try enabling the "Automatically update the gateway clock" setting in OTmonitor. That should cause the OTGW to return a valid day and time. As a bonus the thermostat will have the correct time, so you don't have to set that manually anymore.
Posted: Fri Jan 10, 2020 1:33 am
by mcasamento
Changed again! Or at least it does look different to me. No more begging for date and time, but still the thermostat can't connect
23:26:14.662944 Command: PR=M
23:26:18.696161 Command: GW=1
23:26:19.914307 Command: GW=0
23:26:22.248275 Command: GW=1
23:56:44.262625 80190000
23:56:44.781566 B40191E00 Read-Ack Boiler water temperature: 30.00
23:56:44.820989 Command: PR=A
23:56:44.962575 PR: A=OpenTherm Gateway 4.2.5
23:56:45.003300 Command: SC=23:56/4
23:56:45.193947 SC: 23:56/4
23:56:45.365658 R801C0000 Read-Data Return water temperature: 0.00
23:56:45.860878 B401C1B00 Read-Ack Return water temperature: 27.00
23:56:46.462025 R80190000 Read-Data Boiler water temperature: 0.00
23:56:46.663971 B40191E00 Read-Ack Boiler water temperature: 30.00
23:56:47.363987 R80190000 Read-Data Boiler water temperature: 0.00
23:56:47.863956 B40191E00 Read-Ack Boiler water temperature: 30.00
23:56:48.469561 R00000000 Read-Data Status: 00000000 00000000
23:56:49.090223 BC0000000 Read-Ack Status: 00000000 00000000
23:56:49.569219 R80190000 Read-Data Boiler water temperature: 0.00
23:56:49.899665 B40191E00 Read-Ack Boiler water temperature: 30.00
23:56:50.563858 R10010A00 Write-Data Control setpoint: 10.00
23:56:50.862852 BD0010A00 Write-Ack Control setpoint: 10.00
23:56:51.588177 R80380000 Read-Data DHW setpoint: 0.00
23:56:51.873929 B40382D00 Read-Ack DHW setpoint: 45.00
23:56:52.564600 R00390000 Read-Data Max CH water setpoint: 0.00
23:56:52.885421 B40393400 Read-Ack Max CH water setpoint: 52.00
23:56:53.556548 R80190000 Read-Data Boiler water temperature: 0.00
23:56:53.663394 Command: PR=M
23:56:54.173647 PR: M=G
23:56:54.219158 B40191E00 Read-Ack Boiler water temperature: 30.00
23:56:54.603072 R00120000 Read-Data CH water pressure: 0.00
23:56:54.961904 B4012016C Read-Ack CH water pressure: 1.42
23:56:55.627155 R00000000 Read-Data Status: 00000000 00000000
23:56:56.395819 BC0000000 Read-Ack Status: 00000000 00000000
23:56:57.231991 R80190000 Read-Data Boiler water temperature: 0.00
23:56:57.317973 B40191E00 Read-Ack Boiler water temperature: 30.00
23:56:57.856156 R10010A00 Write-Data Control setpoint: 10.00
23:56:58.149707 BD0010A00 Write-Ack Control setpoint: 10.00
23:56:58.730331 R80190000 Read-Data Boiler water temperature: 0.00
23:56:59.104900 B40191E00 Read-Ack Boiler water temperature: 30.00
23:56:59.769501 R00110000 Read-Data Relative modulation level: 0.00
23:57:00.034333 Command: SC=23:57/4
23:57:00.151968 SC: 23:57/4
23:57:00.191361 BC0110000 Read-Ack Relative modulation level: 0.00
23:57:00.820558 R80190000 Read-Data Boiler water temperature: 0.00
23:57:01.181906 B40191E00 Read-Ack Boiler water temperature: 30.00
23:57:01.846034 R801C0000 Read-Data Return water temperature: 0.00
23:57:02.229220 B401C1B00 Read-Ack Return water temperature: 27.00
23:57:02.895399 R80190000 Read-Data Boiler water temperature: 0.00
23:57:03.291555 B40191E00 Read-Ack Boiler water temperature: 30.00
23:57:03.932510 R80190000 Read-Data Boiler water temperature: 0.00
23:57:04.284712 B40191E00 Read-Ack Boiler water temperature: 30.00
23:57:04.967003 R00000000 Read-Data Status: 00000000 00000000
23:57:05.349387 BC0000000 Read-Ack Status: 00000000 00000000
23:57:05.999642 R80190000 Read-Data Boiler water temperature: 0.00
23:57:06.381643 B40191E00 Read-Ack Boiler water temperature: 30.00
23:57:07.026782 R10010A00 Write-Data Control setpoint: 10.00
23:57:07.445164 BD0010A00 Write-Ack Control setpoint: 10.00
23:57:08.067259 R80380000 Read-Data DHW setpoint: 0.00
23:57:08.458726 B40382D00 Read-Ack DHW setpoint: 45.00
23:57:09.106109 R00390000 Read-Data Max CH water setpoint: 0.00
23:57:09.482021 B40393400 Read-Ack Max CH water setpoint: 52.00
23:57:10.150011 R80190000 Read-Data Boiler water temperature: 0.00
23:57:10.524393 B40191E00 Read-Ack Boiler water temperature: 30.00
23:57:11.188604 R00120000 Read-Data CH water pressure: 0.00
23:57:11.595408 B4012016C Read-Ack CH water pressure: 1.42
23:57:12.226490 R00000000 Read-Data Status: 00000000 00000000
23:57:12.600534 BC0000000 Read-Ack Status: 00000000 00000000
23:57:13.256470 R80190000 Read-Data Boiler water temperature: 0.00
23:57:13.636902 B40191E00 Read-Ack Boiler water temperature: 30.00
23:57:14.290234 R10010A00 Write-Data Control setpoint: 10.00
23:57:14.667902 BD0010A00 Write-Ack Control setpoint: 10.00
23:57:15.314580 R80190000 Read-Data Boiler water temperature: 0.00
23:57:15.698648 B40191E00 Read-Ack Boiler water temperature: 30.00
23:57:16.349521 R00110000 Read-Data Relative modulation level: 0.00
23:57:16.753352 BC0110000 Read-Ack Relative modulation level: 0.00
23:57:17.392289 R80190000 Read-Data Boiler water temperature: 0.00
23:57:17.769828 B40191E00 Read-Ack Boiler water temperature: 30.00
23:57:18.417565 R801C0000 Read-Data Return water temperature: 0.00
23:57:18.791713 B401C1B00 Read-Ack Return water temperature: 27.00
23:57:19.457531 R80190000 Read-Data Boiler water temperature: 0.00
23:57:19.833282 B40191E00 Read-Ack Boiler water temperature: 30.00
23:57:20.498493 R80190000 Read-Data Boiler water temperature: 0.00
23:57:20.866210 B40191E00 Read-Ack Boiler water temperature: 30.00
23:57:21.530954 R00000000 Read-Data Status: 00000000 00000000
23:57:21.881545 BC0000000 Read-Ack Status: 00000000 00000000
23:57:22.555029 R80190000 Read-Data Boiler water temperature: 0.00
23:57:22.932475 B40191E00 Read-Ack Boiler water temperature: 30.00
23:57:23.600192 R10010A00 Write-Data Control setpoint: 10.00
23:57:23.975604 BD0010A00 Write-Ack Control setpoint: 10.00
23:57:24.640595 R80380000 Read-Data DHW setpoint: 0.00
23:57:25.053531 B40382D00 Read-Ack DHW setpoint: 45.00
23:57:25.667652 R00390000 Read-Data Max CH water setpoint: 0.00
23:57:26.062804 B40393400 Read-Ack Max CH water setpoint: 52.00
23:57:26.715226 R80190000 Read-Data Boiler water temperature: 0.00
23:57:27.090049 B40191E00 Read-Ack Boiler water temperature: 30.00
23:57:27.752334 R00120000 Read-Data CH water pressure: 0.00
23:57:28.133557 B4012016C Read-Ack CH water pressure: 1.42
23:57:28.792219 R00000000 Read-Data Status: 00000000 00000000
23:57:29.161625 BC0000000 Read-Ack Status: 00000000 00000000
23:57:29.824765 R80190000 Read-Data Boiler water temperature: 0.00
23:57:30.207696 B40191E00 Read-Ack Boiler water temperature: 30.00
23:57:30.862794 R10010A00 Write-Data Control setpoint: 10.00
23:57:31.244170 BD0010A00 Write-Ack Control setpoint: 10.00
23:57:31.892439 R80190000 Read-Data Boiler water temperature: 0.00
23:57:32.272157 B40191E00 Read-Ack Boiler water temperature: 30.00
23:57:32.919421 R00110000 Read-Data Relative modulation level: 0.00
23:57:33.301890 BC0110000 Read-Ack Relative modulation level: 0.00
23:57:33.954181 R80190000 Read-Data Boiler water temperature: 0.00
23:57:34.364034 B40191E00 Read-Ack Boiler water temperature: 30.00
23:57:34.998061 R801C0000 Read-Data Return water temperature: 0.00
23:57:35.372320 B401C1B00 Read-Ack Return water temperature: 27.00
23:57:36.027072 R80190000 Read-Data Boiler water temperature: 0.00
23:57:36.404268 B40191E00 Read-Ack Boiler water temperature: 30.00
23:57:37.058039 R80190000 Read-Data Boiler water temperature: 0.00
23:57:37.434541 B40191E00 Read-Ack Boiler water temperature: 30.00
23:57:38.092355 R00000000 Read-Data Status: 00000000 00000000
23:57:38.457519 BC0000000 Read-Ack Status: 00000000 00000000
23:57:39.123541 R80190000 Read-Data Boiler water temperature: 0.00
23:57:39.518655 B40191E00 Read-Ack Boiler water temperature: 30.00
23:57:40.173657 R10010A00 Write-Data Control setpoint: 10.00
23:57:40.551332 BD0010A00 Write-Ack Control setpoint: 10.00
23:57:41.202944 R80380000 Read-Data DHW setpoint: 0.00
23:57:41.587907 B40382D00 Read-Ack DHW setpoint: 45.00
23:57:42.228911 R00390000 Read-Data Max CH water setpoint: 0.00
23:57:42.616172 B40393400 Read-Ack Max CH water setpoint: 52.00
23:57:43.260278 R80190000 Read-Data Boiler water temperature: 0.00
23:57:43.675138 B40191E00 Read-Ack Boiler water temperature: 30.00
23:57:44.299303 R00120000 Read-Data CH water pressure: 0.00
23:57:44.684218 B4012016C Read-Ack CH water pressure: 1.42
23:57:45.334255 R00000000 Read-Data Status: 00000000 00000000
23:57:45.705106 BC0000000 Read-Ack Status: 00000000 00000000
23:57:46.372220 R80190000 Read-Data Boiler water temperature: 0.00
23:57:46.755992 B40191E00 Read-Ack Boiler water temperature: 30.00
23:57:47.414902 R10010A00 Write-Data Control setpoint: 10.00
23:57:47.781040 BD0010A00 Write-Ack Control setpoint: 10.00
23:57:48.449457 R80190000 Read-Data Boiler water temperature: 0.00
23:57:48.830834 B40191E00 Read-Ack Boiler water temperature: 30.00
23:57:49.474319 R00110000 Read-Data Relative modulation level: 0.00
23:57:49.866591 BC0110000 Read-Ack Relative modulation level: 0.00
23:57:50.516175 R80190000 Read-Data Boiler water temperature: 0.00
23:57:50.890277 B40191E00 Read-Ack Boiler water temperature: 30.00
23:57:51.538095 R801C0000 Read-Data Return water temperature: 0.00
23:57:51.925842 B401C1B00 Read-Ack Return water temperature: 27.00
23:57:52.583325 R80190000 Read-Data Boiler water temperature: 0.00
23:57:52.982181 B40191E00 Read-Ack Boiler water temperature: 30.00
23:57:53.613980 R80190000 Read-Data Boiler water temperature: 0.00
23:57:53.995298 B40191E00 Read-Ack Boiler water temperature: 30.00
23:57:54.472566 Error 03
23:57:54.707670 R00000000 Read-Data Status: 00000000 00000000
23:57:54.947708 Thermostat connected
23:57:55.103988 BC0000000 Read-Ack Status: 00000000 00000000
23:57:58.168595 T1002011C Write-Data Master configuration: 00000001 28
23:57:58.234517 R80190000 Read-Data Boiler water temperature: 0.00
23:57:58.258514 Medium power
23:57:58.353397 T1002011C Write-Data Master configuration: 00000001 28
23:57:58.388634 R80190000 Read-Data Boiler water temperature: 0.00
23:57:58.744213 B40191E00 Read-Ack Boiler water temperature: 30.00
23:57:58.787278 AD002011C Write-Ack Master configuration: 00000001 28
23:57:58.956900 T00030000 Read-Data Slave configuration: 00000000 0
23:57:59.301681 B40030100 Read-Ack Slave configuration: 00000001 0
- DHW: present (1)
23:57:59.600163 T00060000 Read-Data Remote parameter flags: 00000000 00000000
23:57:59.965267 BC0060303 Read-Ack Remote parameter flags: 00000011 00000011
23:58:00.120172 Command: SC=23:58/4
23:58:00.139807 T00050000 Read-Data Application-specific flags: 00000000 0
23:58:00.242891 SC: 23:58/4
23:58:00.565562 B40050100 Read-Ack Application-specific flags: 00000001 0
23:58:00.757935 T000A0000 Read-Data Number of TSPs: 0
23:58:01.175722 BF00A0000 Unk-DataId Number of TSPs: 0
23:58:01.364782 T000C0000 Read-Data Size of fault buffer: 0
23:58:01.722209 BF00C0000 Unk-DataId Size of fault buffer: 0
23:58:02.360789 T90100F01 Write-Data Room setpoint: 15.00
23:58:02.731747 B70100000 Unk-DataId Room setpoint: 0.00
23:58:02.766758 AD0100000 Write-Ack Room setpoint: 0.00
23:58:02.965610 T90100F01 Write-Data Room setpoint: 15.00
23:58:03.328323 B70100000 Unk-DataId Room setpoint: 0.00
23:58:03.384545 AD0100000 Write-Ack Room setpoint: 0.00
23:58:03.556406 T90100F01 Write-Data Room setpoint: 15.00
23:58:03.941191 B70100000 Unk-DataId Room setpoint: 0.00
23:58:04.003368 AD0100000 Write-Ack Room setpoint: 0.00
23:58:04.158508 T90100F01 Write-Data Room setpoint: 15.00
23:58:04.214358 R80190000 Read-Data Boiler water temperature: 0.00
23:58:04.538713 B40191E00 Read-Ack Boiler water temperature: 30.00
23:58:04.578144 A50100F01 Write-Ack Room setpoint: 15.00
23:58:04.759877 T00110000 Read-Data Relative modulation level: 0.00
23:58:05.144492 BC0110000 Read-Ack Relative modulation level: 0.00
23:58:05.361628 T00120000 Read-Data CH water pressure: 0.00
23:58:05.691262 B4012016C Read-Ack CH water pressure: 1.42
23:58:05.860603 T80130000 Read-Data DHW flow rate: 0.00
23:58:06.239404 B70130000 Unk-DataId DHW flow rate: 0.00
23:58:06.472255 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:58:06.845067 BF0140000 Unk-DataId Day of week and time of day: Unk 00:00
23:58:06.896531 A4014973A Read-Ack Day of week and time of day: Thu 23:58
23:58:07.064075 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:58:07.465928 BF0140000 Unk-DataId Day of week and time of day: Unk 00:00
23:58:07.520403 A4014973A Read-Ack Day of week and time of day: Thu 23:58
23:58:07.669556 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:58:08.025396 BF0140000 Unk-DataId Day of week and time of day: Unk 00:00
23:58:08.077359 A4014973A Read-Ack Day of week and time of day: Thu 23:58
23:58:08.267107 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:58:08.315766 R80190000 Read-Data Boiler water temperature: 0.00
23:58:08.626387 B40191E00 Read-Ack Boiler water temperature: 30.00
23:58:08.680183 A4014973A Read-Ack Day of week and time of day: Thu 23:58
23:58:08.868735 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:58:08.918015 R80190000 Read-Data Boiler water temperature: 0.00
23:58:09.286245 B40191E00 Read-Ack Boiler water temperature: 30.00
23:58:09.347440 A4014973A Read-Ack Day of week and time of day: Thu 23:58
23:58:09.460597 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:58:09.505458 R80190000 Read-Data Boiler water temperature: 0.00
23:58:09.841688 B40191E00 Read-Ack Boiler water temperature: 30.00
******LOG CUT BECAUSE message is too big and those messages are all the same***************
23:58:58.870017 A4014973A Read-Ack Day of week and time of day: Thu 23:58
23:58:58.996365 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:58:59.013237 R80190000 Read-Data Boiler water temperature: 0.00
23:58:59.399374 B40191E00 Read-Ack Boiler water temperature: 30.00
23:58:59.461569 A4014973A Read-Ack Day of week and time of day: Thu 23:58
23:58:59.601885 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:58:59.655160 R80190000 Read-Data Boiler water temperature: 0.00
23:59:00.002772 Command: SC=23:59/4
23:59:00.058466 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:00.087449 A4014973A Read-Ack Day of week and time of day: Thu 23:58
23:59:00.115160 SC: 23:59/4
23:59:00.164915 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:00.211587 R80190000 Read-Data Boiler water temperature: 0.00
23:59:00.615920 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:00.669999 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:00.801680 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:00.837555 R80190000 Read-Data Boiler water temperature: 0.00
23:59:01.219872 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:01.259526 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:01.402739 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:01.458092 R80190000 Read-Data Boiler water temperature: 0.00
23:59:01.782997 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:01.818675 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:02.403594 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:02.465159 R80190000 Read-Data Boiler water temperature: 0.00
23:59:02.762340 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:02.778523 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:03.006556 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:03.040892 R80190000 Read-Data Boiler water temperature: 0.00
23:59:03.379378 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:03.436566 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:03.604369 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:03.647493 R80190000 Read-Data Boiler water temperature: 0.00
23:59:03.983041 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:04.045255 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:04.203244 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:04.255020 R80190000 Read-Data Boiler water temperature: 0.00
23:59:04.586128 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:04.645185 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:04.805852 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:04.866955 R80190000 Read-Data Boiler water temperature: 0.00
23:59:05.186273 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:05.205545 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:05.401426 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:05.451496 R80190000 Read-Data Boiler water temperature: 0.00
23:59:05.784960 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:05.844888 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:06.008656 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:06.047241 R80190000 Read-Data Boiler water temperature: 0.00
23:59:06.393360 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:06.447402 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:06.606151 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:06.641829 R80190000 Read-Data Boiler water temperature: 0.00
23:59:06.999393 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:07.052374 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:07.209505 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:07.240666 R80190000 Read-Data Boiler water temperature: 0.00
23:59:07.597695 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:07.641327 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:07.800181 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:07.838278 R80190000 Read-Data Boiler water temperature: 0.00
23:59:08.212030 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:08.282707 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:08.411727 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:08.451027 R80190000 Read-Data Boiler water temperature: 0.00
23:59:08.809896 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:08.897666 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:09.011119 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:09.065198 R80190000 Read-Data Boiler water temperature: 0.00
23:59:09.379526 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:09.438709 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:09.606914 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:09.663344 R80190000 Read-Data Boiler water temperature: 0.00
23:59:09.988937 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:10.047289 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:10.210317 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:10.265211 R80190000 Read-Data Boiler water temperature: 0.00
23:59:10.586110 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:10.667404 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:10.813075 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:10.871836 R80190000 Read-Data Boiler water temperature: 0.00
23:59:11.188789 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:11.243075 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:11.408506 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:11.480157 R80190000 Read-Data Boiler water temperature: 0.00
23:59:11.786664 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:11.827313 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:12.410671 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:12.446039 R80190000 Read-Data Boiler water temperature: 0.00
23:59:12.793164 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:12.809192 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:13.010947 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:13.030809 R80190000 Read-Data Boiler water temperature: 0.00
23:59:13.383347 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:13.412870 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:13.611310 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:13.649361 R80190000 Read-Data Boiler water temperature: 0.00
23:59:13.986586 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:14.037644 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:14.212245 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:14.265783 R80190000 Read-Data Boiler water temperature: 0.00
23:59:14.596519 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:14.642649 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:14.808360 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:14.876202 R80190000 Read-Data Boiler water temperature: 0.00
23:59:15.202834 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:15.246880 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:15.415119 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:15.481291 R80190000 Read-Data Boiler water temperature: 0.00
23:59:15.802815 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:15.863998 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:16.011682 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:16.052518 R80190000 Read-Data Boiler water temperature: 0.00
23:59:16.409623 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:16.448184 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:16.613861 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:16.655190 R80190000 Read-Data Boiler water temperature: 0.00
23:59:17.015758 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:17.061979 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:17.214083 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:17.262539 R80190000 Read-Data Boiler water temperature: 0.00
23:59:17.618265 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:17.653808 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:18.863666 OpenTherm Gateway 4.2.5
23:59:18.918902 Command: SC=23:59/4
23:59:18.950823 T1002011C Write-Data Master configuration: 00000001 28
23:59:19.002538 R00060000 Read-Data Remote parameter flags: 00000000 00000000
23:59:19.027975 Medium power
23:59:19.053236 SC: 23:59/4
23:59:19.102205 T1002011C Write-Data Master configuration: 00000001 28
23:59:19.141935 R00060000 Read-Data Remote parameter flags: 00000000 00000000
23:59:19.460474 BC0060303 Read-Ack Remote parameter flags: 00000011 00000011
23:59:19.639637 AD002011C Write-Ack Master configuration: 00000001 28
23:59:19.686866 T00030000 Read-Data Slave configuration: 00000000 0
23:59:20.054071 B40030100 Read-Ack Slave configuration: 00000001 0
- DHW: present (1)
- Control type: modulating (0)
- Cooling: not supported (0)
- DHW: instantaneous (0)
- Master pump control: allowed (0)
- CH2: not present (0)
- Remote water filling: available/unknown (0)
- Heat/cool mode control: heat (0)
23:59:20.382531 T00060000 Read-Data Remote parameter flags: 00000000 00000000
23:59:20.619225 BC0060303 Read-Ack Remote parameter flags: 00000011 00000011
23:59:20.872002 T00050000 Read-Data Application-specific flags: 00000000 0
23:59:21.270155 B40050100 Read-Ack Application-specific flags: 00000001 0
- Service request: yes (1)
- Lockout-reset: disabled (0)
- Low water pressure: no fault (0)
- Gas/flame fault: no fault (0)
- Air pressure fault: no fault (0)
- Water over-temperature: no fault (0)
23:59:21.476830 T000A0000 Read-Data Number of TSPs: 0
23:59:21.869999 BF00A0000 Unk-DataId Number of TSPs: 0
23:59:22.574532 T000C0000 Read-Data Size of fault buffer: 0
23:59:22.947090 BF00C0000 Unk-DataId Size of fault buffer: 0
23:59:23.174444 T90100F01 Write-Data Room setpoint: 15.00
23:59:23.551897 B70100000 Unk-DataId Room setpoint: 0.00
23:59:23.591136 AD0100000 Write-Ack Room setpoint: 0.00
23:59:23.769302 T90100F01 Write-Data Room setpoint: 15.00
23:59:24.151726 B70100000 Unk-DataId Room setpoint: 0.00
23:59:24.229677 AD0100000 Write-Ack Room setpoint: 0.00
23:59:24.370560 T90100F01 Write-Data Room setpoint: 15.00
23:59:24.742194 B70100000 Unk-DataId Room setpoint: 0.00
23:59:24.785080 AD0100000 Write-Ack Room setpoint: 0.00
23:59:24.974120 T90100F01 Write-Data Room setpoint: 15.00
23:59:25.001896 R00300000 Read-Data DHW setpoint boundaries: 0 0
23:59:25.349713 B40303C23 Read-Ack DHW setpoint boundaries: 60 35
23:59:25.407190 A50100F01 Write-Ack Room setpoint: 15.00
23:59:25.569869 T00110000 Read-Data Relative modulation level: 0.00
23:59:25.941100 BC0110000 Read-Ack Relative modulation level: 0.00
23:59:26.169728 T00120000 Read-Data CH water pressure: 0.00
23:59:26.540665 B4012016C Read-Ack CH water pressure: 1.42
23:59:26.771654 T80130000 Read-Data DHW flow rate: 0.00
23:59:27.146720 B70130000 Unk-DataId DHW flow rate: 0.00
23:59:27.369681 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:27.747571 BF0140000 Unk-DataId Day of week and time of day: Unk 00:00
23:59:27.778451 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:27.974236 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:28.352219 BF0140000 Unk-DataId Day of week and time of day: Unk 00:00
23:59:28.381578 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:28.572896 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:28.959712 BF0140000 Unk-DataId Day of week and time of day: Unk 00:00
23:59:29.025501 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:29.178557 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:29.240317 R80310000 Read-Data Max CH setpoint boundaries: 0 0
23:59:29.579245 B40315028 Read-Ack Max CH setpoint boundaries: 80 40
23:59:29.654430 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:29.776742 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:29.795386 R80190000 Read-Data Boiler water temperature: 0.00
23:59:30.134997 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:30.205106 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:30.378989 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:30.419865 R80190000 Read-Data Boiler water temperature: 0.00
23:59:30.749414 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:30.787267 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:30.978757 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:31.060993 R80190000 Read-Data Boiler water temperature: 0.00
23:59:31.388746 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:31.440784 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:32.080979 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:32.127513 R80190000 Read-Data Boiler water temperature: 0.00
23:59:32.450717 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:32.501275 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:32.680093 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:32.717914 R80190000 Read-Data Boiler water temperature: 0.00
23:59:33.056581 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:33.104035 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:33.279406 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:33.333262 R80190000 Read-Data Boiler water temperature: 0.00
23:59:33.655161 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:33.720404 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:33.882629 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:33.954688 R80190000 Read-Data Boiler water temperature: 0.00
23:59:34.261250 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:34.326334 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:34.481449 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:34.556173 R80190000 Read-Data Boiler water temperature: 0.00
23:59:34.854837 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:34.920991 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:35.081630 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:35.168265 R80190000 Read-Data Boiler water temperature: 0.00
23:59:35.463253 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:35.523634 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:35.677114 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:35.726872 R80190000 Read-Data Boiler water temperature: 0.00
23:59:36.059318 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:36.134990 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:36.277771 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:36.317161 R80190000 Read-Data Boiler water temperature: 0.00
23:59:36.665824 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:36.703604 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:36.877245 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:36.914192 R80190000 Read-Data Boiler water temperature: 0.00
23:59:37.226948 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:37.278448 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:37.487981 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:37.543783 R80190000 Read-Data Boiler water temperature: 0.00
23:59:37.876837 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:37.934782 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:38.083580 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:38.104186 R80190000 Read-Data Boiler water temperature: 0.00
23:59:38.479804 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:38.523756 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:38.683280 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:38.726833 R80190000 Read-Data Boiler water temperature: 0.00
23:59:39.086266 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:39.149186 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:39.285585 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:39.307907 R80190000 Read-Data Boiler water temperature: 0.00
23:59:39.689557 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:39.739855 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:39.884848 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:39.942416 R80190000 Read-Data Boiler water temperature: 0.00
23:59:40.265592 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:40.321846 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:40.486320 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:40.544805 R80190000 Read-Data Boiler water temperature: 0.00
23:59:40.863705 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:40.913054 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:41.084623 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:41.138541 R80190000 Read-Data Boiler water temperature: 0.00
23:59:41.468115 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:41.517969 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:42.188947 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:42.259477 R80190000 Read-Data Boiler water temperature: 0.00
23:59:42.563409 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:42.615315 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:42.789096 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:42.832918 R80190000 Read-Data Boiler water temperature: 0.00
23:59:43.169734 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:43.245255 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:43.389422 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:43.411452 R80190000 Read-Data Boiler water temperature: 0.00
23:59:43.758935 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:43.813961 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:43.984206 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:44.036642 R80190000 Read-Data Boiler water temperature: 0.00
23:59:44.365874 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:44.411500 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:44.587908 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:44.675022 R80190000 Read-Data Boiler water temperature: 0.00
23:59:44.964053 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:45.034143 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:45.190650 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:45.232892 R80190000 Read-Data Boiler water temperature: 0.00
23:59:45.594196 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:45.621472 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:45.783353 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:45.823533 R80190000 Read-Data Boiler water temperature: 0.00
23:59:46.178912 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:46.234440 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:46.390064 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:46.429138 R80190000 Read-Data Boiler water temperature: 0.00
23:59:46.783972 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:46.828690 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:46.992197 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:47.045695 R80190000 Read-Data Boiler water temperature: 0.00
23:59:47.388139 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:47.415140 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:47.586407 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:47.620261 R80190000 Read-Data Boiler water temperature: 0.00
23:59:47.994086 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:48.011642 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:48.190337 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:48.238483 R80190000 Read-Data Boiler water temperature: 0.00
23:59:48.568138 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:48.606523 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:48.789376 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:48.805735 R80190000 Read-Data Boiler water temperature: 0.00
23:59:49.168821 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:49.201770 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:49.391934 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:49.468375 R80190000 Read-Data Boiler water temperature: 0.00
23:59:49.770285 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:49.850493 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:49.988529 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:50.039867 R80190000 Read-Data Boiler water temperature: 0.00
23:59:50.375212 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:50.430782 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:50.592283 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:50.664488 R80190000 Read-Data Boiler water temperature: 0.00
23:59:50.970160 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:51.032145 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:51.191853 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:51.237381 R80190000 Read-Data Boiler water temperature: 0.00
23:59:51.563380 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:51.605369 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:52.192567 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:52.227782 R80190000 Read-Data Boiler water temperature: 0.00
23:59:52.573473 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:52.635022 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:52.793917 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:52.813614 R80190000 Read-Data Boiler water temperature: 0.00
23:59:53.178686 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:53.227609 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:53.393854 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:53.415878 R80190000 Read-Data Boiler water temperature: 0.00
23:59:53.769060 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:53.819727 AC014973B Read-Ack Day of week and time of day: Thu 23:59
23:59:53.988972 Command: GW=0
23:59:54.005527 T00140000 Read-Data Day of week and time of day: Unk 00:00
23:59:54.036625 R80190000 Read-Data Boiler water temperature: 0.00
23:59:54.098900 GW: 0
23:59:55.240230 Low power
23:59:55.287712 B40191E00 Read-Ack Boiler water temperature: 30.00
23:59:58.224913 T1002011C Write-Data Master configuration: 00000001 28
23:59:58.314109 Medium power
23:59:58.900363 T1002011C Write-Data Master configuration: 00000001 28
23:59:59.025064 Low power
23:59:59.581841 T1002011C Write-Data Master configuration: 00000001 28
23:59:59.646347 Medium power
00:00:00.001383 Command: SC=00:00/5
00:00:00.103887 SC: 00:00/5
00:00:00.260222 T1002011C Write-Data Master configuration: 00000001 28
00:00:00.323972 Low power
00:00:00.944690 T1002011C Write-Data Master configuration: 00000001 28
00:00:01.010972 Medium power
00:00:01.627055 T1002011C Write-Data Master configuration: 00000001 28
00:00:01.787239 Low power
00:00:02.304457 T1002011C Write-Data Master configuration: 00000001 28
00:00:02.453261 Medium power
00:00:02.988499 T1002011C Write-Data Master configuration: 00000001 28
00:00:03.120059 Low power
00:00:03.661610 T1002011C Write-Data Master configuration: 00000001 28
00:00:03.778031 Medium power
00:00:04.347032 T1002011C Write-Data Master configuration: 00000001 28
00:00:04.453523 Low power
00:00:05.025267 T1002011C Write-Data Master configuration: 00000001 28
00:00:05.106025 Medium power
00:00:05.705306 T1002011C Write-Data Master configuration: 00000001 28
00:00:05.772300 Low power
00:00:06.383882 T1002011C Write-Data Master configuration: 00000001 28
00:00:06.463797 Medium power
00:00:07.064033 T1002011C Write-Data Master configuration: 00000001 28
00:00:07.130867 Low power
00:00:07.747813 T1002011C Write-Data Master configuration: 00000001 28
00:00:07.802076 Medium power
00:00:08.426725 T1002011C Write-Data Master configuration: 00000001 28
00:00:08.484166 Low power
00:00:09.104610 T1002011C Write-Data Master configuration: 00000001 28
00:00:09.183042 Medium power
00:00:09.790279 T1002011C Write-Data Master configuration: 00000001 28
00:00:09.847019 Low power
00:00:10.470584 T1002011C Write-Data Master configuration: 00000001 28
00:00:10.526298 Medium power
00:00:11.151880 T1002011C Write-Data Master configuration: 00000001 28
00:00:11.198426 Low power
00:00:11.828695 T1002011C Write-Data Master configuration: 00000001 28
00:00:11.885971 Medium power
00:00:12.508807 T1002011C Write-Data Master configuration: 00000001 28
00:00:12.564419 Low power
00:00:13.192775 T1002011C Write-Data Master configuration: 00000001 28
00:00:13.267951 Medium power
00:00:13.867063 T1002011C Write-Data Master configuration: 00000001 28
00:00:13.935202 Low power
00:00:14.555502 T1002011C Write-Data Master configuration: 00000001 28
00:00:14.595401 Medium power
00:00:15.230770 T1002011C Write-Data Master configuration: 00000001 28
00:00:15.296661 Low power
00:00:15.909136 T1002011C Write-Data Master configuration: 00000001 28
00:00:15.966163 Medium power
00:00:16.596723 T1002011C Write-Data Master configuration: 00000001 28
00:00:16.671468 Low power
00:00:17.269166 T1002011C Write-Data Master configuration: 00000001 28
00:00:17.352359 Medium power
00:00:17.954846 T1002011C Write-Data Master configuration: 00000001 28
00:00:18.026504 Low power
00:00:18.636942 T1002011C Write-Data Master configuration: 00000001 28
00:00:18.706402 Medium power
The thermostat didn't connect to OTGW and I've switched it to Monitor mode but after a while it give up saying "Connect OT+ Slave".
I've then disconnected and reconnected the thermostat and it did connected to the OTGW (that in the meanwhile was left in monitor mode) but giving the usual Error 03 and the otgw only log "TXXXX.." messages.
For one I'd like to make use of that beautiful gateway but I'm also really curious to understand what's happening
Thanks for your support and explanation
Posted: Fri Jan 10, 2020 6:46 pm
by hvxl
That's not correct. Look at the 'T' messages. At some point the thermostat gets stuck again, repeatedly asking for the "Day of week and time of day". Even though it now gets a correct answer. So I'm not really sure how to proceed. The only thing I can think of is to change the firmware to return Unk-DataId, like the boiler does, and see if that makes a difference. But that's a bit of work.
For future logs, please switch off the "Include details of bit fields" option. It makes the logs bigger and harder for me to read.
Did you notice that your boiler indicates that it has a problem? The "Application-specific flags" message response has the "Service request" bit active. Maybe because of the water pressure, which is quite low at 1.42 bar (although the low water pressure bit is not set).
Posted: Sat Jan 11, 2020 2:15 pm
by hvxl
Try the attached firmware (4.2.5.3). It sends Unk-DataId in response to a Read-Data request of MsgID 20 when no recent time information is available. So, switch off the "Automatically update the gateway clock" setting, if that is still on.
Posted: Sat Jan 11, 2020 9:51 pm
by mcasamento
THANK YOU very much for your effort Schelte, is much appreciated!
I know I'm late with my reply, the seasonal flu hit my familiy, both my wife and daughter, I'm just waiting for my turn
No, I didn't know the boiler have that service bit on, I'm still not able to decode those messages properly.
I've just uploaded the firmware and it didn't work on first attempt but I want to do another proper and carefully logged test, before I post the new logs. Just a question, I guess I should reissue UI=2 and AA=25, right ?
Posted: Sun Jan 12, 2020 12:45 am
by hvxl
If you didn't uncheck the "Transfer old EEPROM settings to the new firmware" box during the firmware upgrade, then those settings should have been copied. If your otmonitor is still running, you can check by opening the firmware upgrade window and clicking on the button with the magnifying glass. That will show which Alternative IDs and Blocked MessageIDs were transferred.
If that information is lost and you want to make sure, you can repeat the UI=2 command. I suggest to first run DA=25 before you repeat the AA=25 command, to avoid duplicates. Not that that would be a big deal.
Posted: Mon Jan 13, 2020 5:13 pm
by mcasamento
Good News first: IT WORKS maybe not everything but it started to work!! Thank you genius!!
Bad News then: I wasn't able to copy Alternative ID's with magnifying glass, so I went to the path you described, issuing:
DA=25
DA=25 (two times, just in case)
KI=2
KI=2 (two times, just in case)
UI=2
AA=25
BUT it seemed it didn't work, So I've turned down boiler and OTGW with thermostat disconnected, but nothing, event the connection to the boiler (that was working) stopped working.
Then I've repeated the step above and added a simple GW=R, while everything was up and connected (and thermostat keep saying connecting) and BUM! It started to flash green and thermostat got connected and OTMonitor start to print messages!
The bad News here is that for my own easy I run those command on a ubuntu laptop near the thermostat where I forgot to check "save log"
, so I didn't collected the exact log of what I did, but I'm pretty sure that was the sequence
What don't work, is the TT=xx or TC=xx, the boiler don't start whatever value i put, I've concluded that my thermostat don't support override, but maybe you have another idea
Oh, and finally, if I set the OTGW in monitor mode, everything stop to works, and I only see a lot of error 03. I have to restart the boiler for it to works again, to me is seems like the boiler "learns" to communicate either in monitoring mode or in gateway mode.
Follows log of my try to override room temp
15:50:45.606544 80130000
15:50:45.625123 R80190000 Read-Data Boiler water temperature: 0.00
15:50:45.987716 B40192200 Read-Ack Boiler water temperature: 34.00
15:50:45.994338 Command: PR=A
15:50:46.001715 A70130000 Unk-DataId DHW flow rate: 0.00
15:50:46.060321 PR: A=OpenTherm Gateway 4.2.5.3
15:50:46.205138 T80190000 Read-Data Boiler water temperature: 0.00
15:50:46.583429 B40192200 Read-Ack Boiler water temperature: 34.00
15:50:46.807823 T801A0000 Read-Data DHW temperature: 0.00
15:50:47.191702 BC01A1A00 Read-Ack DHW temperature: 26.00
15:50:47.406613 T00000300 Read-Data Status: 00000011 00000000
15:50:47.789779 BC0000300 Read-Ack Status: 00000011 00000000
15:50:48.008563 T00110000 Read-Data Relative modulation level: 0.00
15:50:48.608585 00120000
15:50:48.996511 BC0120186 Read-Ack CH water pressure: 1.52
15:50:49.209653 T00000300 Read-Data Status: 00000011 00000000
15:50:49.614770 BC0000300 Read-Ack Status: 00000011 00000000
15:50:49.808646 T00000300 Read-Data Status: 00000011 00000000
15:50:50.221569 BC0000300 Read-Ack Status: 00000011 00000000
15:50:50.409142 T00000300 Read-Data Status: 00000011 00000000
15:50:50.831554 BC0000300 Read-Ack Status: 00000011 00000000
15:50:51.009661 T00000300 Read-Data Status: 00000011 00000000
15:50:51.441671 BC0000300 Read-Ack Status: 00000011 00000000
15:50:51.609480 T00000300 Read-Data Status: 00000011 00000000
15:50:51.993107 BC0000300 Read-Ack Status: 00000011 00000000
15:50:52.209504 T00000300 Read-Data Status: 00000011 00000000
15:50:52.614318 BC0000300 Read-Ack Status: 00000011 00000000
15:50:52.809203 T00110000 Read-Data Relative modulation level: 0.00
15:50:53.189808 C0110000
15:50:53.409791 T00120000 Read-Data CH water pressure: 0.00
15:50:53.800650 BC0120186 Read-Ack CH water pressure: 1.52
15:50:54.010875 T00000300 Read-Data Status: 00000011 00000000
15:50:54.396455 BC0000300 Read-Ack Status: 00000011 00000000
15:50:54.612475 T00000300 Read-Data Status: 00000011 00000000
15:50:54.994720 BC0000300 Read-Ack Status: 00000011 00000000
15:50:55.612149 T80130000 Read-Data DHW flow rate: 0.00
15:50:55.642384 R80190000 Read-Data Boiler water temperature: 0.00
15:50:56.003488 B40192200 Read-Ack Boiler water temperature: 34.00
15:50:56.047300 A70130000 Unk-DataId DHW flow rate: 0.00
15:50:56.213462 T80190000 Read-Data Boiler water temperature: 0.00
15:50:56.813718 801A0000
15:50:57.199861 BC01A1A00 Read-Ack DHW temperature: 26.00
15:50:57.411647 T00000300 Read-Data Status: 00000011 00000000
15:50:57.805244 BC0000300 Read-Ack Status: 00000011 00000000
15:50:58.018122 T00110000 Read-Data Relative modulation level: 0.00
15:50:58.416116 BC0110000 Read-Ack Relative modulation level: 0.00
15:50:58.613803 T00120000 Read-Data CH water pressure: 0.00
15:50:59.022443 BC0120186 Read-Ack CH water pressure: 1.52
15:50:59.219174 T00000300 Read-Data Status: 00000011 00000000
15:50:59.627493 BC0000300 Read-Ack Status: 00000011 00000000
15:50:59.819059 T00000300 Read-Data Status: 00000011 00000000
15:51:00.233027 BC0000300 Read-Ack Status: 00000011 00000000
15:51:00.415052 T00000300 Read-Data Status: 00000011 00000000
15:51:00.844007 BC0000300 Read-Ack Status: 00000011 00000000
15:51:01.014771 T00000300 Read-Data Status: 00000011 00000000
15:51:01.398359 C0000300
15:51:01.615303 T00000300 Read-Data Status: 00000011 00000000
15:51:01.994666 BC0000300 Read-Ack Status: 00000011 00000000
15:51:02.220859 T00000300 Read-Data Status: 00000011 00000000
15:51:02.601461 BC0000300 Read-Ack Status: 00000011 00000000
15:51:02.820721 T00110000 Read-Data Relative modulation level: 0.00
15:51:03.196411 BC0110000 Read-Ack Relative modulation level: 0.00
15:51:03.416701 T00120000 Read-Data CH water pressure: 0.00
15:51:03.804093 BC0120186 Read-Ack CH water pressure: 1.52
15:51:04.016805 T00000300 Read-Data Status: 00000011 00000000
15:51:04.401443 BC0000300 Read-Ack Status: 00000011 00000000
15:51:04.620169 T00000300 Read-Data Status: 00000011 00000000
15:51:04.744840 teway 4.2.5.3
15:51:05.003704 BC0000300 Read-Ack Status: 00000011 00000000
15:51:05.618955 T80130000 Read-Data DHW flow rate: 0.00
15:51:05.632703 R80190000 Read-Data Boiler water temperature: 0.00
15:51:06.009807 B40192200 Read-Ack Boiler water temperature: 34.00
15:51:06.032251 A70130000 Unk-DataId DHW flow rate: 0.00
15:51:06.231501 T80190000 Read-Data Boiler water temperature: 0.00
15:51:06.613779 B40192200 Read-Ack Boiler water temperature: 34.00
15:51:06.825878 T801A0000 Read-Data DHW temperature: 0.00
15:51:07.224997 BC01A1A00 Read-Ack DHW temperature: 26.00
15:51:07.424333 T00000300 Read-Data Status: 00000011 00000000
15:51:07.830584 BC0000300 Read-Ack Status: 00000011 00000000
15:51:08.020620 T00110000 Read-Data Relative modulation level: 0.00
15:51:08.434325 BC0110000 Read-Ack Relative modulation level: 0.00
15:51:08.620330 T00120000 Read-Data CH water pressure: 0.00
15:51:09.063974 BC0120186 Read-Ack CH water pressure: 1.52
15:51:09.641711 C0000300
15:51:09.824533 T00000300 Read-Data Status: 00000011 00000000
15:51:10.200083 BC0000300 Read-Ack Status: 00000011 00000000
15:51:10.423090 T00000300 Read-Data Status: 00000011 00000000
15:51:10.807564 BC0000300 Read-Ack Status: 00000011 00000000
15:51:11.022274 T00000300 Read-Data Status: 00000011 00000000
15:51:11.406448 BC0000300 Read-Ack Status: 00000011 00000000
15:51:11.623241 T00000300 Read-Data Status: 00000011 00000000
15:51:12.023654 BC0000300 Read-Ack Status: 00000011 00000000
15:51:12.230795 T00000300 Read-Data Status: 00000011 00000000
15:51:12.607740 BC0000300 Read-Ack Status: 00000011 00000000
15:51:12.732124 Gateway 4.2.5.3
15:51:12.827807 T00110000 Read-Data Relative modulation level: 0.00
15:51:13.205257 BC0110000 Read-Ack Relative modulation level: 0.00
15:51:13.425817 T00120000 Read-Data CH water pressure: 0.00
15:51:13.810730 BC0120186 Read-Ack CH water pressure: 1.52
15:51:14.025924 T00000300 Read-Data Status: 00000011 00000000
15:51:14.441930 BC0000300 Read-Ack Status: 00000011 00000000
15:51:14.628174 T00000300 Read-Data Status: 00000011 00000000
15:51:15.015670 BC0000300 Read-Ack Status: 00000011 00000000
15:51:15.630500 T80130000 Read-Data DHW flow rate: 0.00
15:51:15.662048 R80190000 Read-Data Boiler water temperature: 0.00
15:51:16.017181 B40192200 Read-Ack Boiler water temperature: 34.00
15:51:16.040066 A70130000 Unk-DataId DHW flow rate: 0.00
15:51:16.225367 T80190000 Read-Data Boiler water temperature: 0.00
15:51:16.631164 B40192200 Read-Ack Boiler water temperature: 34.00
15:51:16.828155 T801A0000 Read-Data DHW temperature: 0.00
15:51:17.234716 BC01A1A00 Read-Ack DHW temperature: 26.00
15:51:17.425818 00000300
15:51:17.838047 BC0000300 Read-Ack Status: 00000011 00000000
15:51:18.029616 T00110000 Read-Data Relative modulation level: 0.00
15:51:18.442532 BC0110000 Read-Ack Relative modulation level: 0.00
15:51:18.626621 T00120000 Read-Data CH water pressure: 0.00
15:51:19.006897 BC0120186 Read-Ack CH water pressure: 1.52
15:51:19.228966 T00000300 Read-Data Status: 00000011 00000000
15:51:19.610093 BC0000300 Read-Ack Status: 00000011 00000000
15:51:19.827573 T00000300 Read-Data Status: 00000011 00000000
15:51:20.199672 BC0000300 Read-Ack Status: 00000011 00000000
15:51:20.429330 T00000300 Read-Data Status: 00000011 00000000
15:51:20.808141 B
15:51:21.031501 00000300
15:51:21.417395 BC0000300 Read-Ack Status: 00000011 00000000
15:51:21.631041 T00000300 Read-Data Status: 00000011 00000000
15:51:22.012898 BC0000300 Read-Ack Status: 00000011 00000000
15:51:22.234601 T00000300 Read-Data Status: 00000011 00000000
15:51:22.610406 BC0000300 Read-Ack Status: 00000011 00000000
15:51:22.831284 T00110000 Read-Data Relative modulation level: 0.00
15:51:23.220184 BC0110000 Read-Ack Relative modulation level: 0.00
15:51:23.432004 T00120000 Read-Data CH water pressure: 0.00
15:51:23.818590 BC0120186 Read-Ack CH water pressure: 1.52
15:51:24.034064 T00000300 Read-Data Status: 00000011 00000000
15:51:24.420992 BC0000300 Read-Ack Status: 00000011 00000000
15:51:24.632640 T00000300 Read-Data Status: 00000011 00000000
15:51:25.027372 BC0000300 Read-Ack Status: 00000011 00000000
15:51:25.733302 80130000
15:51:25.774210 R80190000 Read-Data Boiler water temperature: 0.00
15:51:26.135055 B40192200 Read-Ack Boiler water temperature: 34.00
15:51:26.146634 A70130000 Unk-DataId DHW flow rate: 0.00
15:51:26.333474 T80190000 Read-Data Boiler water temperature: 0.00
15:51:26.742985 B40192200 Read-Ack Boiler water temperature: 34.00
15:51:26.935463 T801A0000 Read-Data DHW temperature: 0.00
15:51:27.354494 BC01A1A00 Read-Ack DHW temperature: 26.00
15:51:27.533936 T00000300 Read-Data Status: 00000011 00000000
15:51:27.960383 BC0000300 Read-Ack Status: 00000011 00000000
15:51:28.135430 T00110000 Read-Data Relative modulation level: 0.00
15:51:28.518380 BC0110000 Read-Ack Relative modulation level: 0.00
15:51:28.733627 T00120000 Read-Data CH water pressure: 0.00
15:51:29.118307 C0120186
15:51:29.335426 T00000300 Read-Data Status: 00000011 00000000
15:51:29.721702 BC0000300 Read-Ack Status: 00000011 00000000
15:51:29.935370 T00000300 Read-Data Status: 00000011 00000000
15:51:30.326573 BC0000300 Read-Ack Status: 00000011 00000000
15:51:30.537668 T00000300 Read-Data Status: 00000011 00000000
15:51:30.916661 BC0000300 Read-Ack Status: 00000011 00000000
15:51:31.135709 T00000300 Read-Data Status: 00000011 00000000
15:51:31.524397 BC0000300 Read-Ack Status: 00000011 00000000
15:51:31.736480 T00000300 Read-Data Status: 00000011 00000000
15:51:32.125860 BC0000300 Read-Ack Status: 00000011 00000000
15:51:32.339073 T00000300 Read-Data Status: 00000011 00000000
15:51:32.720743 BC0000300 Read-Ack Status: 00000011 00000000
15:51:32.945651 T90101201 Write-Data Room setpoint: 18.00
15:51:32.962895 R80190000 Read-Data Boiler water temperature: 0.00
15:51:33.326641 B40192200 Read-Ack Boiler water temperature: 34.00
15:51:33.335933 A50101201 Write-Ack Room setpoint: 18.00
15:51:33.880214 C0110000
15:51:34.139283 T00120000 Read-Data CH water pressure: 0.00
15:51:34.536800 BC0120186 Read-Ack CH water pressure: 1.52
15:51:35.238451 T80130000 Read-Data DHW flow rate: 0.00
15:51:35.244275 R80190000 Read-Data Boiler water temperature: 0.00
15:51:35.645345 B40192200 Read-Ack Boiler water temperature: 34.00
15:51:35.658953 A70130000 Unk-DataId DHW flow rate: 0.00
15:51:35.840427 T00140000 Read-Data Day of week and time of day: Unk 00:00
15:51:35.852884 R80190000 Read-Data Boiler water temperature: 0.00
15:51:36.252478 B40192200 Read-Ack Boiler water temperature: 34.00
15:51:36.265011 AF0140000 Unk-DataId Day of week and time of day: Unk 00:00
15:51:36.444187 T90181567 Write-Data Room temperature: 21.40
15:51:36.470071 R80190000 Read-Data Boiler water temperature: 0.00
15:51:36.857012 B40192200 Read-Ack Boiler water temperature: 34.00
15:51:36.877619 AF0181567 Unk-DataId Room temperature: 21.40
15:51:37.463803 40192200
15:51:37.641047 T801A0000 Read-Data DHW temperature: 0.00
15:51:39.227284 BC01A1A00 Read-Ack DHW temperature: 26.00
15:51:39.250360 T00110000 Read-Data Relative modulation level: 0.00
15:51:39.292004 BC0110000 Read-Ack Relative modulation level: 0.00
15:51:39.319625 T00120000 Read-Data CH water pressure: 0.00
15:51:39.339761 BC0120186 Read-Ack CH water pressure: 1.52
15:51:39.449305 T001B0000 Read-Data Outside temperature: 0.00
15:51:39.470598 R80190000 Read-Data Boiler water temperature: 0.00
15:51:39.822408 B40192200 Read-Ack Boiler water temperature: 34.00
15:51:39.838956 AF01B0000 Unk-DataId Outside temperature: 0.00
15:51:40.042437 T801C0000 Read-Data Return water temperature: 0.00
15:51:40.353228 BC01C1A00 Read-Ack Return water temperature: 26.00
15:51:40.543780 T00210000 Read-Data Exhaust temperature: 0.00
15:51:40.932772 BC0211B00 Read-Ack Exhaust temperature: 27.00
15:51:41.145135 T10382D00 Write-Data DHW setpoint: 45.00
15:51:41.542955 BD0382D00 Write-Ack DHW setpoint: 45.00
15:51:42.142210 D0393400
15:51:42.344316 T10010000 Write-Data Control setpoint: 0.00
15:51:42.726377 BD0010000 Write-Ack Control setpoint: 0.00
15:51:42.946164 T00110000 Read-Data Relative modulation level: 0.00
15:51:43.342363 BC0110000 Read-Ack Relative modulation level: 0.00
15:51:43.544028 T00120000 Read-Data CH water pressure: 0.00
15:51:43.955384 BC0120186 Read-Ack CH water pressure: 1.52
15:51:44.145899 T00000300 Read-Data Status: 00000011 00000000
15:51:44.554569 BC0000300 Read-Ack Status: 00000011 00000000
15:51:45.610092 40192200
15:51:45.638317 A70130000 Unk-DataId DHW flow rate: 0.00
15:51:45.849589 T80190000 Read-Data Boiler water temperature: 0.00
15:51:46.104594 Command: PR=M
15:51:46.236758 PR: M=G
15:51:46.249611 B40192200 Read-Ack Boiler water temperature: 34.00
15:51:46.445622 T801A0000 Read-Data DHW temperature: 0.00
15:51:46.871268 BC01A1A00 Read-Ack DHW temperature: 26.00
15:51:47.048870 T00000300 Read-Data Status: 00000011 00000000
15:51:47.429794 BC0000300 Read-Ack Status: 00000011 00000000
15:51:47.647014 T00000300 Read-Data Status: 00000011 00000000
15:51:48.036752 BC0000300 Read-Ack Status: 00000011 00000000
15:51:48.250375 T00110000 Read-Data Relative modulation level: 0.00
15:51:48.631424 BC0110000 Read-Ack Relative modulation level: 0.00
15:51:48.851439 T00120000 Read-Data CH water pressure: 0.00
15:51:49.228574 BC0120186 Read-Ack CH water pressure: 1.52
15:51:49.449222 T00000300 Read-Data Status: 00000011 00000000
15:51:50.051927 00000300
15:51:50.435554 BC0000300 Read-Ack Status: 00000011 00000000
15:51:50.653694 T00000300 Read-Data Status: 00000011 00000000
15:51:51.032385 BC0000300 Read-Ack Status: 00000011 00000000
15:51:51.252746 T00000300 Read-Data Status: 00000011 00000000
15:51:51.640257 BC0000300 Read-Ack Status: 00000011 00000000
15:51:51.854937 T00000300 Read-Data Status: 00000011 00000000
15:51:52.236943 BC0000300 Read-Ack Status: 00000011 00000000
15:51:52.452584 T00000300 Read-Data Status: 00000011 00000000
15:51:52.854210 BC0000300 Read-Ack Status: 00000011 00000000
15:51:53.051666 T00110000 Read-Data Relative modulation level: 0.00
15:51:53.661022 00120000
15:51:54.057982 BC0120186 Read-Ack CH water pressure: 1.52
15:51:54.250132 T00000300 Read-Data Status: 00000011 00000000
15:51:54.666922 BC0000300 Read-Ack Status: 00000011 00000000
15:51:55.353382 T80130000 Read-Data DHW flow rate: 0.00
15:51:55.397320 R80190000 Read-Data Boiler water temperature: 0.00
15:51:55.770019 B40192200 Read-Ack Boiler water temperature: 34.00
15:51:55.792157 A70130000 Unk-DataId DHW flow rate: 0.00
15:51:55.953487 T80190000 Read-Data Boiler water temperature: 0.00
15:51:56.378967 B40192200 Read-Ack Boiler water temperature: 34.00
15:51:56.555252 T801A0000 Read-Data DHW temperature: 0.00
15:51:56.940030 BC01A1A00 Read-Ack DHW temperature: 26.00
15:51:57.154494 T00000300 Read-Data Status: 00000011 00000000
15:51:57.536990 BC0000300 Read-Ack Status: 00000011 00000000
15:51:57.760578 T00110000 Read-Data Relative modulation level: 0.00
15:51:58.144505 C0110000
15:51:58.354730 T00120000 Read-Data CH water pressure: 0.00
15:51:58.588020 Command: TT=27.14
15:51:58.736412 TT: 27.14
15:51:58.754685 BC0120186 Read-Ack CH water pressure: 1.52
15:51:58.954435 T00000300 Read-Data Status: 00000011 00000000
15:51:59.334419 BC0000300 Read-Ack Status: 00000011 00000000
15:51:59.553150 T00000300 Read-Data Status: 00000011 00000000
15:51:59.942441 BC0000300 Read-Ack Status: 00000011 00000000
15:52:00.156108 T00000300 Read-Data Status: 00000011 00000000
15:52:00.541077 BC0000300 Read-Ack Status: 00000011 00000000
15:52:00.758222 T00000300 Read-Data Status: 00000011 00000000
15:52:01.150386 BC0000300 Read-Ack Status: 00000011 00000000
15:52:01.357784 T00000300 Read-Data Status: 00000011 00000000
15:52:01.744780 C0000300
15:52:01.959586 T00000300 Read-Data Status: 00000011 00000000
15:52:02.352285 BC0000300 Read-Ack Status: 00000011 00000000
15:52:02.556234 T00000300 Read-Data Status: 00000011 00000000
15:52:02.969379 BC0000300 Read-Ack Status: 00000011 00000000
15:52:03.157612 T00110000 Read-Data Relative modulation level: 0.00
15:52:03.575950 BC0110000 Read-Ack Relative modulation level: 0.00
15:52:03.759024 T00120000 Read-Data CH water pressure: 0.00
15:52:04.181531 BC0120186 Read-Ack CH water pressure: 1.52
15:52:04.357881 T00000300 Read-Data Status: 00000011 00000000
15:52:04.732342 BC0000300 Read-Ack Status: 00000011 00000000
15:52:05.360560 T80130000 Read-Data DHW flow rate: 0.00
15:52:05.414257 R80190000 Read-Data Boiler water temperature: 0.00
15:52:05.741863 B40192200 Read-Ack Boiler water temperature: 34.00
15:52:05.802515 A70130000 Unk-DataId DHW flow rate: 0.00
15:52:05.959216 T80190000 Read-Data Boiler water temperature: 0.00
15:52:06.331872 40192200
15:52:06.559587 T801A0000 Read-Data DHW temperature: 0.00
15:52:06.943744 BC01A1A00 Read-Ack DHW temperature: 26.00
15:52:07.162770 T00000300 Read-Data Status: 00000011 00000000
15:52:07.548516 BC0000300 Read-Ack Status: 00000011 00000000
15:52:07.761662 T00110000 Read-Data Relative modulation level: 0.00
15:52:08.139455 BC0110000 Read-Ack Relative modulation level: 0.00
15:52:08.363522 T00120000 Read-Data CH water pressure: 0.00
15:52:08.752966 BC0120186 Read-Ack CH water pressure: 1.52
15:52:08.962511 T00000300 Read-Data Status: 00000011 00000000
15:52:09.344835 BC0000300 Read-Ack Status: 00000011 00000000
15:52:09.561874 T00000300 Read-Data Status: 00000011 00000000
15:52:09.944155 C0000300
15:52:10.163803 T00000300 Read-Data Status: 00000011 00000000
15:52:10.545470 BC0000300 Read-Ack Status: 00000011 00000000
15:52:10.766700 T00000300 Read-Data Status: 00000011 00000000
15:52:11.153701 BC0000300 Read-Ack Status: 00000011 00000000
15:52:11.363031 T00000300 Read-Data Status: 00000011 00000000
15:52:11.760822 BC0000300 Read-Ack Status: 00000011 00000000
15:52:11.964060 T00000300 Read-Data Status: 00000011 00000000
15:52:12.326004 BC0000300 Read-Ack Status: 00000011 00000000
15:52:12.565851 T00000300 Read-Data Status: 00000011 00000000
15:52:12.980192 BC0000300 Read-Ack Status: 00000011 00000000
15:52:13.166319 T00110000 Read-Data Relative modulation level: 0.00
15:52:13.586762 BC0110000 Read-Ack Relative modulation level: 0.00
15:52:13.769489 T00120000 Read-Data CH water pressure: 0.00
15:52:14.194914 BC0120186 Read-Ack CH water pressure: 1.52
15:52:14.365769 00000300
15:52:14.753222 BC0000300 Read-Ack Status: 00000011 00000000
15:52:15.368446 T80130000 Read-Data DHW flow rate: 0.00
15:52:15.414088 R80190000 Read-Data Boiler water temperature: 0.00
15:52:15.746166 B40192200 Read-Ack Boiler water temperature: 34.00
15:52:15.785264 A70130000 Unk-DataId DHW flow rate: 0.00
15:52:15.964745 T80190000 Read-Data Boiler water temperature: 0.00
15:52:16.355230 B40192200 Read-Ack Boiler water temperature: 34.00
15:52:16.570499 T801A0000 Read-Data DHW temperature: 0.00
15:52:16.955424 BC01A1A00 Read-Ack DHW temperature: 26.00
15:52:17.174404 T00000300 Read-Data Status: 00000011 00000000
15:52:17.550567 BC0000300 Read-Ack Status: 00000011 00000000
15:52:17.769334 T00110000 Read-Data Relative modulation level: 0.00
15:52:18.158398 C0110000
15:52:18.373168 T00120000 Read-Data CH water pressure: 0.00
15:52:18.752045 BC0120186 Read-Ack CH water pressure: 1.52
15:52:18.974880 T00000300 Read-Data Status: 00000011 00000000
15:52:19.360440 BC0000300 Read-Ack Status: 00000011 00000000
15:52:19.572435 T00000300 Read-Data Status: 00000011 00000000
15:52:19.966139 BC0000300 Read-Ack Status: 00000011 00000000
15:52:20.168479 T00000300 Read-Data Status: 00000011 00000000
15:52:20.573968 BC0000300 Read-Ack Status: 00000011 00000000
15:52:20.770164 T00000300 Read-Data Status: 00000011 00000000
15:52:21.180162 BC0000300 Read-Ack Status: 00000011 00000000
15:52:21.368829 T00000300 Read-Data Status: 00000011 00000000
15:52:21.785178 BC0000300 Read-Ack Status: 00000011 00000000
15:52:21.970299 T00000300 Read-Data Status: 00000011 00000000
15:52:22.392810 BC0000300 Read-Ack Status: 00000011 00000000
15:52:22.491569 3
15:52:22.534678 T00000300 Read-Data Status: 00000011 00000000
15:52:22.999363 BC0000300 Read-Ack Status: 00000011 00000000
15:52:23.171609 T00110000 Read-Data Relative modulation level: 0.00
15:52:23.597427 BC0110000 Read-Ack Relative modulation level: 0.00
15:52:23.775404 T00120000 Read-Data CH water pressure: 0.00
15:52:24.156330 BC0120186 Read-Ack CH water pressure: 1.52
15:52:24.373355 T00000300 Read-Data Status: 00000011 00000000
15:52:24.756792 BC0000300 Read-Ack Status: 00000011 00000000
15:52:25.373775 T80130000 Read-Data DHW flow rate: 0.00
15:52:25.420122 R80190000 Read-Data Boiler water temperature: 0.00
15:52:25.754411 B40192200 Read-Ack Boiler water temperature: 34.00
15:52:25.766441 A70130000 Unk-DataId DHW flow rate: 0.00
15:52:25.974005 T80190000 Read-Data Boiler water temperature: 0.00
15:52:26.351789 40192200
15:52:26.574574 T801A0000 Read-Data DHW temperature: 0.00
15:52:26.959990 BC01A1A00 Read-Ack DHW temperature: 26.00
15:52:27.178631 T00000300 Read-Data Status: 00000011 00000000
15:52:27.556635 BC0000300 Read-Ack Status: 00000011 00000000
15:52:27.774050 T00110000 Read-Data Relative modulation level: 0.00
15:52:28.153510 BC0110000 Read-Ack Relative modulation level: 0.00
15:52:28.374938 T00120000 Read-Data CH water pressure: 0.00
15:52:28.759924 BC0120186 Read-Ack CH water pressure: 1.52
15:52:28.975575 T00000300 Read-Data Status: 00000011 00000000
15:54:35.357326 45.00,52.00,0,0,0,0,0,0,0,0
15:55:03.642795 Command: PR=M
15:55:03.750572 PR: M=G
15:55:12.042132 Command: GW=R
15:55:13.269213 OpenTherm Gateway 4.2.5.3
15:55:13.329368 T1002011C Write-Data Master configuration: 00000001 28
15:55:13.453841 R00060000 Read-Data Remote parameter flags: 00000000 00000000
15:55:13.488453 Medium power
15:55:13.514440 T1002011C Write-Data Master configuration: 00000001 28
15:55:13.539159 R00060000 Read-Data Remote parameter flags: 00000000 00000000
15:55:13.880053 C0060303
15:55:13.918912 AD002011C Write-Ack Master configuration: 00000001 28
15:55:14.142348 T00030000 Read-Data Slave configuration: 00000000 0
15:55:14.525890 B40030100 Read-Ack Slave configuration: 00000001 0
15:55:15.242378 T00060000 Read-Data Remote parameter flags: 00000000 00000000
15:55:15.627762 BC0060303 Read-Ack Remote parameter flags: 00000011 00000011
15:55:15.841600 T00050000 Read-Data Application-specific flags: 00000000 0
15:55:16.242603 B40050100 Read-Ack Application-specific flags: 00000001 0
15:55:16.446810 T000A0000 Read-Data Number of TSPs: 0
15:55:16.828142 BF00A0000 Unk-DataId Number of TSPs: 0
15:55:17.042314 T000C0000 Read-Data Size of fault buffer: 0
15:55:17.429804 F00C0000
15:55:17.643391 T00120000 Read-Data CH water pressure: 0.00
15:55:18.034386 BC0120186 Read-Ack CH water pressure: 1.52
15:55:18.243205 T00110000 Read-Data Relative modulation level: 0.00
15:55:18.628794 BC0110000 Read-Ack Relative modulation level: 0.00
15:55:18.852207 T00120000 Read-Data CH water pressure: 0.00
15:55:19.185627 BC0120186 Read-Ack CH water pressure: 1.52
15:55:19.450720 T80130000 Read-Data DHW flow rate: 0.00
15:55:19.840767 B70130000 Unk-DataId DHW flow rate: 0.00
15:55:20.044957 T00140000 Read-Data Day of week and time of day: Unk 00:00
15:55:20.449826 BF0140000 Unk-DataId Day of week and time of day: Unk 00:00
15:55:20.645026 T80190000 Read-Data Boiler water temperature: 0.00
15:55:21.055518 B40192200 Read-Ack Boiler water temperature: 34.00
15:55:21.246712 T801A0000 Read-Data DHW temperature: 0.00
15:55:21.662220 BC01A1A00 Read-Ack DHW temperature: 26.00
15:55:22.267350 F01B0000
15:55:22.445583 T801C0000 Read-Data Return water temperature: 0.00
15:55:22.866487 BC01C1A00 Read-Ack Return water temperature: 26.00
15:55:23.046526 T00110000 Read-Data Relative modulation level: 0.00
15:55:23.508393 BC0110000 Read-Ack Relative modulation level: 0.00
15:55:23.648781 T00120000 Read-Data CH water pressure: 0.00
15:55:24.051744 BC0120186 Read-Ack CH water pressure: 1.52
15:55:24.253454 T00210000 Read-Data Exhaust temperature: 0.00
15:55:24.632458 BC0211B00 Read-Ack Exhaust temperature: 27.00
15:55:25.735271 70130000
15:55:25.951801 T80190000 Read-Data Boiler water temperature: 0.00
15:55:26.331573 B40192200 Read-Ack Boiler water temperature: 34.00
15:55:26.549246 T801A0000 Read-Data DHW temperature: 0.00
15:55:26.937420 BC01A1A00 Read-Ack DHW temperature: 26.00
15:55:27.151812 T00300000 Read-Data DHW setpoint boundaries: 0 0
15:55:27.535864 B40303C23 Read-Ack DHW setpoint boundaries: 60 35
15:55:27.753703 T00110000 Read-Data Relative modulation level: 0.00
15:55:28.133578 BC0110000 Read-Ack Relative modulation level: 0.00
15:55:28.351084 T00120000 Read-Data CH water pressure: 0.00
15:55:28.741594 BC0120186 Read-Ack CH water pressure: 1.52
15:55:28.953119 T80310000 Read-Data Max CH setpoint boundaries: 0 0
15:55:29.352848 B40315028 Read-Ack Max CH setpoint boundaries: 80 40
15:55:29.552254 T80380000 Read-Data DHW setpoint: 0.00
15:55:29.956469 B40382D00 Read-Ack DHW setpoint: 45.00
15:55:30.152250 00390000
15:55:30.565372 B40393400 Read-Ack Max CH water setpoint: 52.00
15:55:30.754585 T80670000 Read-Data Solar storage config/memberid: 00000000 0
15:55:31.172708 B70670000 Unk-DataId Solar storage config/memberid: 00000000 0
15:55:31.362549 T107C0300 Write-Data OpenTherm version Master: 3.00
15:55:31.777409 B707C0000 Unk-DataId OpenTherm version Master: 0.00
15:55:31.954430 T007D0000 Read-Data OpenTherm version Slave: 0.00
15:55:32.334798 BF07D0000 Unk-DataId OpenTherm version Slave: 0.00
15:55:32.377532 AC07D0300 Read-Ack OpenTherm version Slave: 3.00
15:55:32.557116 T10010000 Write-Data Control setpoint: 0.00
15:55:32.945937 BD0010000 Write-Ack Control setpoint: 0.00
15:55:33.049332 Command: TC=25.51
15:55:33.136706 TC: 25.51
15:55:33.148758 T90101201 Write-Data Room setpoint: 18.00
15:55:33.759155 90101201
15:55:34.133503 B70100000 Unk-DataId Room setpoint: 0.00
15:55:34.181961 AD0100000 Write-Ack Room setpoint: 0.00
15:55:34.355243 T90101201 Write-Data Room setpoint: 18.00
15:55:34.742257 B70100000 Unk-DataId Room setpoint: 0.00
15:55:34.790298 AD0100000 Write-Ack Room setpoint: 0.00
15:55:35.358826 T90101201 Write-Data Room setpoint: 18.00
15:55:35.400960 R80190000 Read-Data Boiler water temperature: 0.00
15:55:35.732768 B40192200 Read-Ack Boiler water temperature: 34.00
15:55:35.770121 A50101201 Write-Ack Room setpoint: 18.00
15:55:35.958623 T00110000 Read-Data Relative modulation level: 0.00
15:55:36.338380 BC0110000 Read-Ack Relative modulation level: 0.00
15:55:36.558779 T00120000 Read-Data CH water pressure: 0.00
15:55:36.942992 BC0120186 Read-Ack CH water pressure: 1.52
15:55:37.157419 T80130000 Read-Data DHW flow rate: 0.00
15:55:37.543612 B70130000 Unk-DataId DHW flow rate: 0.00
15:55:37.757033 T00110000 Read-Data Relative modulation level: 0.00
15:55:38.360912 00120000
15:55:38.714569 BC0120186 Read-Ack CH water pressure: 1.52
15:55:38.957459 T00140000 Read-Data Day of week and time of day: Unk 00:00
15:55:39.364206 BF0140000 Unk-DataId Day of week and time of day: Unk 00:00
15:55:39.561062 T90181567 Write-Data Room temperature: 21.40
15:55:39.972168 BF0180000 Unk-DataId Room temperature: 0.00
15:55:40.160687 T80190000 Read-Data Boiler water temperature: 0.00
15:55:40.579031 B40192200 Read-Ack Boiler water temperature: 34.00
15:55:40.760431 T801A0000 Read-Data DHW temperature: 0.00
15:55:41.176453 BC01A1A00 Read-Ack DHW temperature: 26.00
15:55:41.362387 T001B0000 Read-Data Outside temperature: 0.00
15:55:41.960941 801C0000
15:55:42.351007 BC01C1A00 Read-Ack Return water temperature: 26.00
15:55:42.564620 T00210000 Read-Data Exhaust temperature: 0.00
15:55:42.944724 BC0211B00 Read-Ack Exhaust temperature: 27.00
15:55:43.163856 T00110000 Read-Data Relative modulation level: 0.00
15:55:43.550520 BC0110000 Read-Ack Relative modulation level: 0.00
15:55:43.763231 T00120000 Read-Data CH water pressure: 0.00
15:55:44.146520 BC0120186 Read-Ack CH water pressure: 1.52
15:55:44.368334 T80380000 Read-Data DHW setpoint: 0.00
15:55:44.734365 B40382D00 Read-Ack DHW setpoint: 45.00
15:55:45.362057 T80130000 Read-Data DHW flow rate: 0.00
15:55:45.409569 R80190000 Read-Data Boiler water temperature: 0.00
15:55:45.737409 B40192200 Read-Ack Boiler water temperature: 34.00
15:55:45.776673 A70130000 Unk-DataId DHW flow rate: 0.00
15:55:45.970100 T80190000 Read-Data Boiler water temperature: 0.00
15:55:46.297994 B40192200 Read-Ack Boiler water temperature: 34.00
15:55:46.409984 5.3
15:55:46.576227 T801A0000 Read-Data DHW temperature: 0.00
15:55:46.953191 BC01A1A00 Read-Ack DHW temperature: 26.00
15:55:47.164156 T00390000 Read-Data Max CH water setpoint: 0.00
