Control Zigbee lamp direct via remote + via Software?
Forum and Topics about ZigBee devices.
Moderators: Digit, Willem4ever
Postby DJF3 » Wed Mar 11, 2020 11:38 am
Team,
Is it possible to control a light via 2 different methods simultaneously?
Example: Ikea Tradfri light with (square) wireless dimmer
  • Switch ---(zigbee)---> Light so switching works directly independent of software/hub/gateway
  • Phoscon --> Conbee II ---(zigbee)---> Light so a computer/API can control the light
If the software is not running you would still be able to control the lights directly but if the software is working it can also control the light.
Q: Can I have a light "registered" with both the nearby switch and the Conbee-zigbee-usbstick+software?
Cheers!
DJ
DJF3
Re: Control Zigbee lamp direct via remote + via Software?
Postby Akatar » Wed Mar 11, 2020 6:10 pm
it depends,
with homeseer it works, connect the bulb and remote to the ikea hub and use the tradfri plugin to control it from homeseer (i use it like this)
Akatar
Postby DJF3 » Thu Mar 12, 2020 6:59 pm
Which plugin is that? The JowiHue plugin?
DJF3
Postby Akatar » Thu Mar 12, 2020 7:31 pm
DJF3 wrote:Which plugin is that? The JowiHue plugin?
No it's the tradfri plugin, not in the updater.
only on the homeseer board. the plugin in the first post is the wrong one, the correct one is a couple of pages further.
https://forums.homeseer.com/forum/homes ... omeseer-trådfriseer/page10
0.0.1.11
Akatar
Return to ZigBee Forum
