Page 1 of 2
Toon firmware 5.25.8 released??
Posted: Fri May 01, 2020 2:19 pm
by Havym
Is there a new release for the rooted community and is it safe to install on my rooted tone?
Just asking just to be sure i dont mess up my toon.
Re: Toon firmware 5.28.8 released??
Posted: Fri May 01, 2020 3:08 pm
by TheHogNL
I don't know anythign about 5.28.8. Where did you see that?
Posted: Fri May 01, 2020 3:16 pm
by TerrorSource
You can see all checked versions here: https://github.com/ToonSoftwareCollecti ... onversions
Posted: Fri May 01, 2020 10:56 pm
by Havym
I'm sorry.... to much number 8 :shock:
I saw 5.25.8 on my Toon appear today... i checked the list so i can update safely :D
Re: Toon firmware 5.25.8 released??
Posted: Sat May 02, 2020 8:05 am
by TheHogNL
Yes you can update to 5.25.8, no problem. However there is always a slight possibility that something goes wrong.
Posted: Sat May 09, 2020 12:03 pm
by Joskep
Since the last update today the Toon responses allmost directly after touching while in dimmode. I don.t know if that was the meaning, but thanks :-) :D
Posted: Sat May 09, 2020 12:13 pm
by TerrorSource
We have pulled 5.28.6 for rooted Toon's a few minutes ago. There's a substantial possibility that the Toon loses his root.
If this happens with your rooted Toon, we are working on a solution but the Toon must be re-rooted for now.
Posted: Sat May 09, 2020 4:13 pm
by Joskep
Mmm hopefully it stil works ;-( I just updated to this firmware.
If everything works the same, the Toonstore is present, then i don.t have to worry?
Hopefully you can explain how i can see its still rooted., SSH acces as ROOT stil works.
Posted: Sat May 09, 2020 4:22 pm
by TerrorSource
Joskep wrote:Mmm hopefully it stil works ;-( I just updated to this firmware.
if you update from 5.22.14 or 5.25.8 you shouldn't have any issues.
If you update from versions before 5.22.14 you *might* have issues
Posted: Sat May 09, 2020 4:46 pm
by Joskep
Thanks!! I updated from 5.28.8
Posted: Sat May 09, 2020 8:53 pm
by TheHogNL
If toonstore is present you don't need to worry.
Posted: Tue May 12, 2020 10:05 am
by michel30
Is it okay for the Toon 1 to update to the latest firmware? or could I better wait that the new script is released to do the upgrade?
Thanks,
Posted: Tue May 12, 2020 10:24 am
by TerrorSource
michel30 wrote:Hello,
Thanks,
script is already updated.
You can update to 5.28.6 from 5.22.14 or 5.25.8
If you are on a version lower then 5.22.14 you need to go to 5.25.8 first, then update to a newer version.
Posted: Tue May 12, 2020 12:40 pm
by TheHogNL
And for a Toon1 there was no issue and no need to update to 5.26.8 first.
Posted: Tue May 12, 2020 2:11 pm
by NLKris
Found out that Philips hue not always worked on firmware 5.25.8. 'New' Toons didn't ask me to connect my Hue bridge. Also a search in the menu didn't work out.
So I updated to 5.28.6 and since then it working fine again. If you might have trouble using hue on 5.25.8, maybe 5.28.6 is also the solution for you!
Greetz.
