Can minicom but can't do the auto
- Starting Member
Changing cables for a few days now and can't get auto root to work. BUT i can get in with a terminal screen. I have the r8 version.
The other cables beside the rx, tx and gnd aren't needed for a r8 right? When i disconnect the other jtag cables it won't work either.
I'm using a raspberry pi 2b.
This is a strange situation isn't it?
Re: Can minicom but can't do the auto
did you read the readme correctly? I think you forgot to enable serial and disable terminal on serialPieterraxis wrote:Hi,
- Starting Member
Yep, been there
- Starting Member
Wtf is Toon running on?
I started a ping and i'm in an infinite loop now.
Non of these commands land: Q, q, escape, shift escape, ctrl shift backspace and, ctrl s, ctrl z of course ctr c
I'm scared to reboot now i'm manually rooting.
Did you get the cables right?
1 2
3 4
Not
1 7
2 8
1 2
3 4
Not
1 7
2 8
in the 'safe' mode or single mode you don't have Getty running and therefore missing commands like ctrl-cPieterraxis wrote:Wtf is Toon running on?
- Starting Member
Nu start ik toon en kom ik in # maar zelfs het commando get werkt niet. Zit ik nu weer in een bananen shell dan?
eneco-001-095676:~# get http://files.domoticaforum.eu/uploads/T ... .0_qb2.ipk
-sh: get: not found
-sh: get: not found
INIT: Entering runlevel: 5
Starting syslogd/klogd: done
HCBv2 apps started via runlevels, performing 'addstartables && reload && init 5 or 5'.
HCBv2 adding: netcon comm eventmgr pwrusage scsync smartplug thermstat usermsg bxtproxy co.
HCBv2 startables unchanged, not writing /etc/inittab.
Eneco Toon by Quby
eneco-001-095676 login: root
eneco-001-095676:~# get http://files.domoticaforum.eu/uploads/Toon/ipk/qb2/openssh-sftp-server_7.3p1-r10.0_qb2.ipk
-sh: get: not found
eneco-001-095676:~#
- Starting Member
Also, i have a feeling i'm not root while beeing #.
This is what a LS shows. Shouldn't it be more?
eneco-001-095676:~# ls
backup_files iptables.save update-rooted.sh
iptables.backup passwd.backup update_rooted.sh
eneco-001-095676:~#
Looks like i'm not owning the toon
eneco-001-095676:~#
- Starting Member
Ladies and Gents,
Thanks, it worked.
A Tip for you admins to do for the rest of the globe is to make a pretty manual in Html here on the forum. Had to switch tabs between martin jacobs github, ehaco, bor, einstein and your copied 'code' text which i pasted in ms word.
I did take i peep in the store and i saw pihole stats... You adventurous adventurer
Thanks, it worked.
What is wrong with the PDF manual in viewtopic.php?f=100&t=11235#p82533 ?Pieterraxis wrote:Ladies and Gents,
Thanks, it worked.
It states, only try manual root if you are brave. Just use the toonrooter if otherwise.
- Starting Member
ahhhh
apparently i knew what i was doing.
however this manual is a bit outdated. If you follow the manual don’t follow it without thinking and knowing what you are doing
I was stuck at this step until I found this thread and apparently I didn't know what I was doing=)ahhhh
apparently i knew what i was doing.Code: Select all
If you want to make money on pay per lead affiliate program check out this article leadnetwork.com/pay-per-lead-affiliate- ... am-network I think it could be helpful
