Firmware 5.30.4
bekke517
Firmware 5.30.4
Post by bekke517 »
I'd like to know if it is save to install thenew version of the firmware 5.30.4
TerrorSource
Re: Firmware 5.30.4
Post by TerrorSource »
Yes it is.
We've tested it and runs fine :)
michel30
Re: Firmware 5.30.4
Post by michel30 »
Ip updated my Toon 1 and all okay..
Thanks again for the nice update script.
Flarrestein
Re: Firmware 5.30.4
Post by Flarrestein »
Works perfect here.
Ossegek
Re: Firmware 5.30.4
Post by Ossegek »
Where can i find the change log
Re: Firmware 5.30.4
Post by TheHogNL »
Ossegek wrote:Where can i find the change log
Check the (dutch) forum https://toonforum.nl/d/4-softwareversie-overzicht/57
Hmmbob
Re: Firmware 5.30.4
Post by Hmmbob »
I'm on 5.30.4, but my Toon v1 keeps saying the "new TSC resource file available, reboot gui" message and reboots on its own but then the message appears again.
It's also rather slow, way slower than after the last update.
Any idea what's happening?
Re: Firmware 5.30.4
Post by TheHogNL »
Hmmbob wrote:I'm on 5.30.4, but my Toon v1 keeps saying the "new TSC resource file available, reboot gui" message and reboots on its own but then the message appears again.
It should not reboot on its own. A new TSC resource file is published which includes some new icons for new toonstore apps. Nothing important.
That message should only appear when you hit 'check update' in TSC menu and it will then download the new resource file and asks you to restart the GUI.
You probably have seen the 'there is a new TSC resource file availabe. Please update using the TSC menu'. This directs you to this.
In your case, I think something else is wrong. Disk full? Too many apps running?
Hmmbob
Re: Firmware 5.30.4
Post by Hmmbob »
Thanks!
Diskspace does not seem to be an issue:
eneco-001-392594:~# df -h
Filesystem                Size      Used Available Use% Mounted on
ubi0:rootfs             103.3M     80.5M     22.8M  78% /
tmpfs                    61.6M    368.0K     61.3M   1% /var/volatile
Apps:
Boilerstatus 1.0.7
Newsreader 1.1.3
Buienradar 8.5.6
Toonstore 5.0.9
This is the message:
I've rebooted "the hard way" (unplugged it from the wall, waited 30sec, replugged) - let's see if that helps.
Re: Firmware 5.30.4
Post by TheHogNL »
Hmmbob wrote:Thanks!
Apps:
Boilerstatus 1.0.7
Newsreader 1.1.3
Buienradar 8.5.6
Toonstore 5.0.9
You do need to confirm that message by pressing the > in the message
mAiden
Re: Firmware 5.30.4
Post by mAiden »
Nice to see you here Hmmbob !!
Look what TheHogNL say, just tap on the ">", message will be gone.
This shows only a new TSC resource file is published which includes some new icons for new toonstore apps. Nothing important
Hmmbob
Re: Firmware 5.30.4
Post by Hmmbob »
Thanks both!
Return to “Toon Firmware”
