Firmware 5.33.100 rooting
timkoers
Post by timkoers »
I'm trying to root a Toon running firmware 5.33.100.
I can't seem to install busybox_1.27.2-r4_qb2.ipk or dropbear on this firmware.
opkg install http://files.domoticaforum.eu/uploads/Toon/ipk/qb2/busybox_1.27
.2-r4_qb2.ipk
Downloading http://files.domoticaforum.eu/uploads/Toon/ipk/qb2/busybox_1.27.2-r4_qb2.ipk.
Installing busybox (1.27.2-r4) to root...
Multiple replacers for glibc, using first one (libc6).
Multiple replacers for libgcc, using first one (libgcc1).
Configuring busybox.
Configuring dropbear.
Collected errors:
 * pkg_run_script: package "busybox" postinst script returned status 255.
 * opkg_configure: busybox.postinst returned 255.
 * pkg_run_script: package "dropbear" postinst script returned status 255.
 * opkg_configure: dropbear.postinst returned 255.
The update script returns two weird things at the start
sh /root/update-rooted.sh -f
Version: 4.27  - TheHogNL & TerrorSource & yjb - 11-9-2020
If you like the update script for rooted toons you can support me. Any donation is welcome and helps me developing the script even more.
https://paypal.me/pools/c/8bU3eQp1Jt
Only fixing files.
/root/update-rooted.sh: line 1029: can't create /proc/sys/vm/vfs_cache_pressure: nonexistent directory
/root/update-rooted.sh: line 1029: can't create /proc/sys/vm/drop_caches: nonexistent directory
creating backup of inittab...
creating backup of hosts...
FIXING: Downloading resources.rcc TSC mod for this version 5.33.100.
EDITING: disabling Eneco subscription feature apps to free up memory on this toon 1
EDITING: disabling samba nmbd on toon 1 as probably it is not necessary
Finished fixing files!
Now comes the next problem, no display when I turn on the Toon. I measured the LED voltages on the ribbon cable, and they are 0.
Could the software be the cause of this problem, that is not enabling the display?
mAiden
Re: Firmware 5.33.100 rooting
Post by mAiden »
You dont need busybox. Dropbear is enough..
Try: sh /usr/lib/opkg/info/dropbear.postinst
timkoers
Post by timkoers »
mAiden wrote:You dont need busybox. Dropbear is enough..
How do I change the root password without passwd?
And is the software not booting or something the cause of the screen not turning on?
mAiden
Post by mAiden »
First : Toon knows passwd command, without installing busybox.
Connect Toon with serial pins to a pc, and open Putty.
If you boot Toon now. What do you see in the serial terminal?
Post by TheHogNL »
Many times asked on this forum how to change the password.. search for openssl
And I think you broke your ribbon cable. If the serial output still works then your toon is fine but the ribbon cable is broken.
Post by TheHogNL »
Owh forgot to ask.. why still manual rooting? Just use ToonRooter and you didn't need to ask your first question.
timkoers
Post by timkoers »
I did shortcircuit the toons power inputs for a brief moment, that shouldn't cause any issues right?
Well this Toon doesn't. It's not there in /usr/sbin
Might that be related to version 5.33.100?
I have accessed the serial successfully, but I'm talking about the actual display at the front of the unit.
Post by TheHogNL »
timkoers wrote: I did shortcircuit the toons power inputs for a brief moment, that shouldn't cause any issues right?
It could be that that fried the led driver. As serial access is still working the Toon is ok on the software side.
And yes, passwd is not working on toons from I think about firmware 4.0.0 with default busybox.
But you really don't need a new busybox just to change a passwd. Search for openssl in the forum how to change your password using openssl and sed.
timkoers
Post by timkoers »
Do you have some kind of schematic, or do you know which chip is the led driver?
Post by TheHogNL »
No sorry.
Post by TheHogNL »
No sorry.
timkoers
Post by timkoers »
Do you have an Toon you can measure the LED voltage of, so I can try to see if the screen itself works or if it's just the LED?
Post by TheHogNL »
timkoers wrote:Do you have an Toon you can measure the LED voltage of, so I can try to see if the screen itself works or if it's just the LED?
Just looked at a toon I have but there are no real clue's which of the pins of the 40 (or so) ribbon cable are for powering the leds. If you think the 4 pin ribbon cable is for led power, no, that is for the touch/digitizer.
timkoers
Post by timkoers »
I feel so freaking stupid. The RESET button got stuck on the side of the case, thus holding the Toon into it's reset state, not activating the screen.
Thanks everyone. I'll test the firmware and the root and get back to you
timkoers
Post by timkoers »
Just a FYI, since the problem is already fixed; if you look up the large ribbon cable, there should be a soldering point, on which a tiny 2 lane ribbon cable is attached to. The soldering points are marked with LED- and LED+. They are underneath kapton tape however.
Return to “Toon Firmware”
