Firmware 5.33.9 reboot after update
ams123
Post by ams123 »
after i update the toon 1
he now get in a reboot loop
what can i do
Toon solarpannels
mAiden
Re: Firmware 5.33.9
Post by mAiden »
Turn the power off of Toon for couple min.
Try it agian.
Other option is: delete some custom apps.
ams123
Re: Firmware 5.33.9
Post by ams123 »
how its rebooting only
Toon solarpannels
ams123
Re: Firmware 5.33.9
Post by ams123 »
this is the error in the lof file
/mnt/data/update/upgrade-qb2.sh: line 1285: /etc/init.d/show-fb-image: not found
>> logKeyValText: key(upgrade-exit-status), value(execute-error-opkg-upgrade) and text({"fromVersion":"5.22.14","toVersion":"5.33.9"})
>> 2020-10-08 13:15:52 +0100 (pid 18503) execute-error-opkg-upgrade 'Exit code 255 for: opkg upgrade'
Toon solarpannels
TerrorSource
Re: Firmware 5.33.9
Post by TerrorSource »
Login via Putty/ssh and do the update manually
Download the update script and run:
update-rooted.sh -v 5.33.9
ams123
Re: Firmware 5.33.9
Post by ams123 »
Forcing version: 5.33.9
sed: write error
sed: write error
sed: write error
Upgrade script downloaded. We need to download the upgrade files first. No upgra de is done yet. Do you want me to download the files (yes) or quit (anything els e)?
yes
First removing some files to free some disk space. Removed 'ebl' resource files because this toon is using 'base' resource files.
Progress: 0% .
Toon solarpannels
ams123
Re: Firmware 5.33.9
Post by ams123 »
what files can i remove
Toon solarpannels
ams123
Re: Firmware 5.33.9
Post by ams123 »
i try to force update manuel but after few minuts he reboot again
Toon solarpannels
TerrorSource
Re: Firmware 5.33.9
Please don't double or triple post.
There should be an EDIT button where you can edit your last post.
The script itself should remove files to make some space before running.
ams123
Re: Firmware 5.33.9
Post by ams123 »
the script run but the toon reboot after a few minuts so the script cant run longer
Toon solarpannels
TerrorSource
Re: Firmware 5.33.9
my guess, with the information so far, is that it's best to restore the Toon
ams123
Re: Firmware 5.33.9
Post by ams123 »
pleas tel me how
Toon solarpannels
TerrorSource
Re: Firmware 5.33.9
ams123 wrote:pleas tel me how
What have you found searching this forum? ;)
Let me help: viewtopic.php?f=95&t=12462&start=0&hilit=restore
Re: Firmware 5.33.9
Post by TheHogNL »
ams123 wrote:the script run but the toon reboot after a few minuts so the script cant run longer
Please make you questions a bit longer. Like what did you do? What is the log saying just before the reboot etc.
It is very annoying to see your message right now.
Return to “Toon Firmware”
