Opkg can't update due to feed.hae.int disappearing
Posted: Sat Oct 10, 2020 5:03 pm
by markismus
My Toon has been running lovely for a few years, but it got stuck at 5.13.xx and started generating error messages.
So I updated the Toon manually to 5.33.9 and I got the message:
 * opkg_download: Failed to download http://feed.hae.int/feeds/qb2/oe/angelica-1.6.0-master-psplash-curl/armv5e/libqt5websockets5_5.11.2+git0+e71467cb56-r0_armv5e.ipk: Couldn't connect to server.
If I try do a opkg update, it fails with signature error. It turns out that feed.hae.int is defined in the /etc/hosts file as 172.18.192.1 and it fails to respond to pings.
Is there another repository to which I can point in the hosts file?
As the update seems to work as it should, I wonder whether this is just a relic. Is opkg still used and needed in firmware 5.33.9?
Thanks for reading this, cheers from Rotterdam-Blijdorp,
Markismus
Re: Opkg can't update due to feed.hae.int disappearing
Posted: Sat Oct 10, 2020 6:18 pm
by TheHogNL
markismus wrote:Hello,
As the update seems to work as it should, I wonder whether this is just a relict. Is opkg still used and needed in firmware 5.33.9?
Markismus
Still being used as the update process yes. For the feed.hae.int to be accessible you have to have the vpn open to Eneco/Quby. A safe way is to start "sh update-rooted.sh -o"
Posted: Sat Oct 10, 2020 6:34 pm
by markismus
Thanks! Works like a charm.
