i try to use my toon as zwave bridge i successfully added an smart thermostat (popp thermostaatkraan) but cant set the setpoint can somebody help me to the right direction?
Toon as zwave bridge
Re: Toon as zwave bridge
If you want to use your Toon to control smart thermostats you need to switch it from boiler control to thermostat control. The POPP works perfectly with this.
Easiest method is to factory reset your toon and select Quby as 'country' and then follow the wizard. Are you ok to go through factory reset?
Also, in this mode there is no command from the Toon to start the boiler and/or boilerpump. The Toon thermostat mode is designed for continu hotwater pressure in the central heating, which is common for city heating. If you want to use a normal boiler as heater you need some own logic to start the boiler and pumps using this mode or put the boiler in weather mode (WAR).
Factory reset does that mean i lose all the history of my solar/energy usage?
- Administrator
If you use a Toon1 that is true.
On a Toon2, usage data is saved while doing a reset.
You could also try to insert these lines in these files and then reboot. Not sure if it works directly
<feature>zoneControl</feature> in /qmf/config/config_happ_scsync.xml
<FT_ZoneControl_rel>1</FT_ZoneControl_rel> in /qmf/etc/qmf_tenant.xml
Owh and I remember that this only works if you have a toon 2 but maybe recent firmware also allows it on toon 1.
