Backlight
Backlight
A good afternoon,
JL an OTGW connected between Intergas 36 and Isense V30, after connecting and set date and time,
the Isense background lighting starts to flash after a few minutes OTGW is new, boiler is from 2014, have already replaced power supply without resultant, someone any idea
Gr, Carolus
Gr, Carolus
Re: Backlight
Start OTmonitor and connect it to the OTGW. Make sure the OTGW is set to GW mode (GW=1). Enable logging to a log file. You may also want to enable all options under Options -> Thermostat -> Clock and click "Set Clock", so you don't have to manually set the date and time. Then (re)connect the iSense. If the problem persists, provide the log file.
Re: Backlight
Hello, GW mode, i don't understand that how to do
Re: Backlight
Hello, i set
After this so far so good! Thanks I hope so! 20 minutes
Thanks, I will report back
Gr, Carolus
Gr, Carolus
Re: Backlight
Sorry,
noops flashing again
Re: Backlight
no errors in the logfile
Re: Backlight
After this, i view youtube, https://www.youtube.com/watch?v=Rx-rUxzMN8Q The monitor showing nothing
- opentherm.PNG (128.48 KiB) Viewed 3084 times
Re: Backlight
It looks like you haven't got your OTGW/OTmonitor combination working yet. I suggest you focus on that first before worrying about details like backlight.
Re: Backlight
Hello, Thanks
Isense is now working with OTGW finaly, OT monitor is now running
Its may be that the backlight of the Isense goes to a lower power when not touched?
Thanks for all
Thanks for all
Re: Backlight
The iSense backlight switches off when not touched for some time. This can be configured via Menu -> Settings -> Users -> Display -> Light time-out (Dutch: Instellingen -> Gebruikersinst. -> Scherm -> Verlichting). But that's not what I would consider "flashing".
When you touch the display, the log will show "Medium power" and the iSense backlight switches on. After the configured time, the backlight switches off and the log shows "Low power".
Re: Backlight
No,no, The first time when installed the Isense blue light, After a few hours - days later when I touch the isense, no more blue background (low power) everything dark. I put the batteries back in and this will work!
OT monitor no no signal low - medium power in the logs!
Gr, Carolus
Gr, Carolus
Re: Backlight
If you have a solution that works for you and you continue to refuse to provide the log I asked for, I guess this topic can be closed.
For other people that happen to stumble upon this thread: The iSense can work just fine without batteries when connected to the OTGW.
