Hi All,
I have two solar pannel inverters on differend phases.
I added 2 power meters (KWH meters) and needed a solution to combine the pulses of the 2 power meters to one pulse.
On the Arduino forum they helped me and here is the solution: https://forum.arduino.cc/t/2-power-mete ... /854753/27
Use a Arduino nano V3.
Connect the S0 from the power meters to pin 2 -> ground and pin 3 -> ground.
I created a small housing for the Arduino nano. You can at the Toon sensor on the case.
Toon will now receive the pulses from both power meters.
The only problem now is the pulses are not in a stable rithm. Sometimes you will see a very high output (300000 KWH) and somethimes a very low output.
There is a new script that maybe fix this, but I did not test it, yet.
Multiple powermeters Zon op toon
Forum about Toon hardware, both versions 1 and 2 of Toon
Jump to
- Forum matters
- ↳ News Forum
- Hardware Forum (English)
- ↳ Z-Wave Forum
- ↳ Fibaro
- ↳ Plugwise Forum
- ↳ Gadgets Forum
- ↳ Visonic Alarm systems
- ↳ LEDS, DMX & Lights Forum
- ↳ Opentherm Gateway Forum
- ↳ 1-Wire Forum
- ↳ PLCBUS Forum
- ↳ Smart Metering Forum
- ↳ ZigBee Forum
- ↳ Toon news and information
- ↳ Manuals/tutorials
- ↳ Toon Apps
- ↳ Toon Rooting
- ↳ Toon Hardware
- ↳ Toon Firmware
- ↳ Toon external control
- ↳ Toon miscellaneous
- ↳ Toon software development
- Software Forum (English)
- ↳ Announcements & News
- ↳ Linux Forum
- ↳ Windows Forum
- ↳ DomotiGa Forum
- ↳ OpenHAB Forum
- ↳ MQTT & Node.js
- Projects Forum (English)
- ↳ Home Automation Projects
- ↳ Bwired Forum
- ↳ Homeseer algemeen Forum
- ↳ Homeseer Scripts Forum
- ↳ Homeseer HStouch Forum
- ↳ Homeseer Plugins Forum
- Other (English)
- ↳ Off Topic
- ↳ Downloads & Links Forum
- ↳ Domoticaboek Heino Peters
- ↳ Dealers Corner
- ↳ Test
