I'm trying to tidy the connection between my PC and an Oregon Scientific WMR-968 Weather Station. I would like to move the power adator to be next to the PC and feed the 12v down the RS232 cable alongside the signal then at the weatherstation split it out back to the power socket. It only takes a few mA so no problem using Cat5.
I thought it would be easy and the weatherstation would only need pins 2 3 and 7 connected (or 3 2 and 5 as it is 9 pin) and I could then feed the power over say pins 8 and 9 but it doesn't work.
Do I maybe need to link some other pins together at either the PC or Weatherstation ends ? Or maybe use different pins for the 12v ?
Someone else must have done this ?
WMR-968 Weather Station RS232 problem
Jump to
- Forum matters
- ↳ News Forum
- Hardware Forum (English)
- ↳ Z-Wave Forum
- ↳ Fibaro
- ↳ Plugwise Forum
- ↳ Gadgets Forum
- ↳ Visonic Alarm systems
- ↳ LEDS, DMX & Lights Forum
- ↳ Opentherm Gateway Forum
- ↳ 1-Wire Forum
- ↳ PLCBUS Forum
- ↳ Smart Metering Forum
- ↳ ZigBee Forum
- ↳ Toon news and information
- ↳ Manuals/tutorials
- ↳ Toon Apps
- ↳ Toon Rooting
- ↳ Toon Hardware
- ↳ Toon Firmware
- ↳ Toon external control
- ↳ Toon miscellaneous
- ↳ Toon software development
- Software Forum (English)
- ↳ Announcements & News
- ↳ Linux Forum
- ↳ Windows Forum
- ↳ DomotiGa Forum
- ↳ OpenHAB Forum
- ↳ MQTT & Node.js
- Projects Forum (English)
- ↳ Home Automation Projects
- ↳ Bwired Forum
- ↳ Homeseer algemeen Forum
- ↳ Homeseer Scripts Forum
- ↳ Homeseer HStouch Forum
- ↳ Homeseer Plugins Forum
- Other (English)
- ↳ Off Topic
- ↳ Downloads & Links Forum
- ↳ Domoticaboek Heino Peters
- ↳ Dealers Corner
- ↳ Test
