otmonitor - once in a while garbled characters
Posted: Wed Dec 22, 2021 11:30 am
good people, I am looking for some help.
Hardware setup:
1) OTGW as per: https://www.domoticaforum.eu/viewtopic. ... 816#p83670
2) Connected via USB to a Raspberry Pi 2 Model B Rev 1.1
3) Firmware: 5.1
4) otmonitor latest release as per: http://otgw.tclcode.com/download.html#utilities
The setup seems to generally work - however there are two issues:
1) Once in a while, garbled characters appear in the message log:
2) The setup does not react to any serial commands
It seems, that the data from the Thermostat (slave) is received ok and transmitted ok to the boiler (master).
It also seems, that any command sent to the gateway is not accepted - or that the master communication is not picked up correctly?
Any pointer will be helpful!
Thanks a ton!
Hardware setup:
3) Firmware: 5.1
08:07:26.317114 T00120000 Read-Data CH water pressure: 0.00
08:07:26.692215 B60120000 Data-Inv CH water pressure: 0.00
08:09:39.314946 OpenTèOpenTherm Gateway 5.1
08:09:39.849861 T10100A00 Write-Data Room setpoint: 10.00
08:13:18.562804 ÂD01OpenTherm Gateway 5.1
08:13:19.107584 T00060000 Read-Data Remote parameter flags: 00000000 00000000
08:14:10.308148 BC0060707OpenTherm Gateway 5.1Read-Ack Remote parameter flags: 00000111 00000111
08:14:10.929511 T801C0000 Read-Data Return water temperature: 0.00
08:15:07.171046 B401ÿOpenTherm Gateway 5.1
08:15:07.755978 T10181E1C Write-Data Room temperature: 30.11
08:15:08.149806 BD0181E1C Write-Ack Room temperature: 30.11
08:15:58.975463 OpenTherm Gateway 5.1
08:15:59.562786 T80001300 Read-Data Status: 00010011 00000000
08:15:59.889181 B40001322 Read-Ack Status: 00010011 00100010
08:16:24.912759 OpenTherm Gateway 5.1
08:18:03.536337 BD07Å0ÿÏŸðÉnTøOpenTherm Gateway 5.1
10:21:44.056213 Command: PR=M
10:21:44.104255 B50829üOpenTherm Gateway 5.1Write-Ack Message ID 130: 9
10:21:44.471934 T80001300 Read-Data Status: 00010011 00000000
10:21:52.533889 Command (via websocket): PS=1
10:21:52.581171 BCOpenTherm Gateway 5.1
10:22:12.796233 BC0060707
10:22:13.330103 T80001300 Read-Data Status: 00010011 00000000
Thanks a ton!
