Toon 2 not able to update too any version
Posted: Sun Apr 10, 2022 4:04 am
by DennisD
My toon 2 isn't able to update from version 5.39.7.
Alright, I will try to upgrade to 5.49.7
Could not enable VPN in a normal reasonable time!
DEBUG information:
default via 192.168.1.1 dev wlan0 metric 10
192.168.1.0/24 dev wlan0 scope link src 192.168.1.176
# <persistent /etc/hosts content can be added to /etc/hosts.template file>
127.0.0.1 localhost.localdomain localhost qb-659916001600-1804A01D7W
172.24.0.1 feed.hae.int feed
127.0.0.1 api.quby.io
127.0.0.1 ping.quby.nl
END DEBUG information
I checked resolve.conf
domain localdomain
nameserver 192.168.1.1
Tried running sh /root/update-rooted.sh -f but unfortunately it doesn't help with this vpn error
Re: Toon 2 not able to update too any version
Posted: Sun Apr 10, 2022 9:09 am
by TheHogNL
Try to run the VPN manually and look for errors:
/usr/sbin/openvpn --config /etc/openvpn/vpn.conf
(control-C to stop it)
Posted: Sun Apr 10, 2022 9:19 am
by DennisD
This is the log:
qb-659916001600-1804A01D7W:~# /usr/sbin/openvpn --config /etc/openvpn/vpn.conf
Sun Apr 10 09:18:29 2022 OpenVPN 2.3.6 arm-angelica-linux-gnueabi [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Oct 18 2017
Sun Apr 10 09:18:29 2022 library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.09
Sun Apr 10 09:18:29 2022 WARNING: file '/etc/openvpn/certs/device.key' is group or others accessible
Sun Apr 10 09:18:29 2022 Control Channel Authentication: using '/etc/openvpn/certs/ta.key' as a OpenVPN static key file
Sun Apr 10 09:18:29 2022 RESOLVE: Cannot resolve host address: vpn.qutility.quby.com: Name or service not known
Sun Apr 10 09:18:34 2022 RESOLVE: Cannot resolve host address: vpn.qutility.quby.com: Name or service not known
Sun Apr 10 09:18:39 2022 RESOLVE: Cannot resolve host address: vpn.qutility.quby.com: Name or service not known
Sun Apr 10 09:18:44 2022 RESOLVE: Cannot resolve host address: vpn.qutility.quby.com: Name or service not known
^CSun Apr 10 09:18:46 2022 RESOLVE: signal received during DNS resolution attempt
Sun Apr 10 09:18:46 2022 SIGINT[hard,init_instance] received, process exiting
Posted: Sun Apr 10, 2022 9:45 am
by TheHogNL
So you have set your toon on the 'qutility' tenant, which was a test tenant for quby internal development. Since Eneco took over quby, the qutility tenant is not working anymore.
Please run "/qmb/bin/qmf-set-tenant.sh eneco-nl" to switch back to the eneco tenant
Posted: Sun Apr 10, 2022 10:57 am
by DennisD
I presume you meant /qmf/bin/qmf-set-tenant.sh eneco-nl because qmb folder does not exist.
After running /qmf/bin/qmf-set-tenant.sh eneco-nl i got this:
Succesfully loaded 16 items to be translated
Updating '/qmf/qml/qb/lang/lang_de_DE.qm'...
Generated 129 translation(s) (129 finished and 0 unfinished)
Updating '/qmf/qml/qb/lang/lang_es_ES.qm'...
Updating '/qmf/qml/qb/lang/lang_fr_BE.qm'...
Updating '/qmf/qml/qb/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/qb/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/qb/lang/lang_en_GB.qm'...
Updating '/qmf/qml/qb/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/domesticHotWater/lang/lang_de_DE.qm'...
Generated 49 translation(s) (49 finished and 0 unfinished)
Updating '/qmf/qml/apps/domesticHotWater/lang/lang_es_ES.qm'...
Generated 44 translation(s) (44 finished and 0 unfinished)
Ignored 5 untranslated source text(s)
Updating '/qmf/qml/apps/domesticHotWater/lang/lang_fr_BE.qm'...
Updating '/qmf/qml/apps/domesticHotWater/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/domesticHotWater/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/domesticHotWater/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/domesticHotWater/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/boilerMonitor/lang/lang_de_DE.qm'...
Generated 100 translation(s) (100 finished and 0 unfinished)
Ignored 14 untranslated source text(s)
Updating '/qmf/qml/apps/boilerMonitor/lang/lang_es_ES.qm'...
Generated 31 translation(s) (31 finished and 0 unfinished)
Ignored 83 untranslated source text(s)
Updating '/qmf/qml/apps/boilerMonitor/lang/lang_fr_BE.qm'...
Generated 73 translation(s) (73 finished and 0 unfinished)
Ignored 41 untranslated source text(s)
Updating '/qmf/qml/apps/boilerMonitor/lang/lang_nl_NL.qm'...
Generated 114 translation(s) (114 finished and 0 unfinished)
Updating '/qmf/qml/apps/boilerMonitor/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/boilerMonitor/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/boilerMonitor/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/heatingOverview/lang/lang_de_DE.qm'...
Generated 25 translation(s) (25 finished and 0 unfinished)
Updating '/qmf/qml/apps/heatingOverview/lang/lang_es_ES.qm'...
Updating '/qmf/qml/apps/heatingOverview/lang/lang_fr_BE.qm'...
Updating '/qmf/qml/apps/heatingOverview/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/heatingOverview/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/heatingOverview/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/heatingOverview/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/customerService/lang/lang_de_DE.qm'...
Generated 24 translation(s) (24 finished and 0 unfinished)
Updating '/qmf/qml/apps/customerService/lang/lang_es_ES.qm'...
Generated 20 translation(s) (20 finished and 0 unfinished)
Ignored 4 untranslated source text(s)
Updating '/qmf/qml/apps/customerService/lang/lang_fr_BE.qm'...
Updating '/qmf/qml/apps/customerService/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/customerService/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/customerService/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/customerService/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/statusUsage/lang/lang_de_DE.qm'...
Generated 87 translation(s) (87 finished and 0 unfinished)
Updating '/qmf/qml/apps/statusUsage/lang/lang_es_ES.qm'...
Updating '/qmf/qml/apps/statusUsage/lang/lang_fr_BE.qm'...
Updating '/qmf/qml/apps/statusUsage/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/statusUsage/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/statusUsage/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/statusUsage/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/clock/lang/lang_de_DE.qm'...
Generated 1 translation(s) (1 finished and 0 unfinished)
Updating '/qmf/qml/apps/clock/lang/lang_es_ES.qm'...
Updating '/qmf/qml/apps/clock/lang/lang_fr_BE.qm'...
Updating '/qmf/qml/apps/clock/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/clock/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/clock/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/clock/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/weather/lang/lang_de_DE.qm'...
Generated 53 translation(s) (53 finished and 0 unfinished)
Updating '/qmf/qml/apps/weather/lang/lang_es_ES.qm'...
Updating '/qmf/qml/apps/weather/lang/lang_fr_BE.qm'...
Updating '/qmf/qml/apps/weather/lang/lang_nl_NL.qm'...
Generated 53 translation(s) (52 finished and 1 unfinished)
Updating '/qmf/qml/apps/weather/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/weather/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/weather/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/homescreen/lang/lang_de_DE.qm'...
Generated 23 translation(s) (23 finished and 0 unfinished)
Updating '/qmf/qml/apps/homescreen/lang/lang_es_ES.qm'...
Generated 21 translation(s) (21 finished and 0 unfinished)
Ignored 2 untranslated source text(s)
Updating '/qmf/qml/apps/homescreen/lang/lang_fr_BE.qm'...
Updating '/qmf/qml/apps/homescreen/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/homescreen/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/homescreen/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/homescreen/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/imageViewer/lang/lang_fr_BE.qm'...
Generated 0 translation(s) (0 finished and 0 unfinished)
Ignored 7 untranslated source text(s)
Updating '/qmf/qml/apps/imageViewer/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/imageViewer/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/imageViewer/lang/lang_en_GB.qm'...
Ignored 6 untranslated source text(s)
Updating '/qmf/qml/apps/imageViewer/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/inbox/lang/lang_de_DE.qm'...
Generated 8 translation(s) (8 finished and 0 unfinished)
Updating '/qmf/qml/apps/inbox/lang/lang_es_ES.qm'...
Updating '/qmf/qml/apps/inbox/lang/lang_fr_BE.qm'...
Generated 6 translation(s) (6 finished and 0 unfinished)
Updating '/qmf/qml/apps/inbox/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/inbox/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/inbox/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/inbox/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/fiona/lang/lang_nl_NL.qm'...
Ignored 26 untranslated source text(s)
Updating '/qmf/qml/apps/fiona/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/smokeDetector/lang/lang_de_DE.qm'...
Updating '/qmf/qml/apps/smokeDetector/lang/lang_fr_BE.qm'...
Updating '/qmf/qml/apps/smokeDetector/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/smokeDetector/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/smokeDetector/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/smokeDetector/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/upsell/lang/lang_fr_BE.qm'...
Updating '/qmf/qml/apps/upsell/lang/lang_nl_NL.qm'...
Generated 38 translation(s) (38 finished and 0 unfinished)
Updating '/qmf/qml/apps/upsell/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/internetSettings/lang/lang_de_DE.qm'...
Generated 123 translation(s) (123 finished and 0 unfinished)
Updating '/qmf/qml/apps/internetSettings/lang/lang_es_ES.qm'...
Updating '/qmf/qml/apps/internetSettings/lang/lang_fr_BE.qm'...
Updating '/qmf/qml/apps/internetSettings/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/internetSettings/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/internetSettings/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/internetSettings/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/thermostat/lang/lang_de_DE.qm'...
Generated 84 translation(s) (84 finished and 0 unfinished)
Ignored 8 untranslated source text(s)
Updating '/qmf/qml/apps/thermostat/lang/lang_es_ES.qm'...
Updating '/qmf/qml/apps/thermostat/lang/lang_fr_BE.qm'...
Updating '/qmf/qml/apps/thermostat/lang/lang_nl_NL.qm'...
Generated 92 translation(s) (92 finished and 0 unfinished)
Updating '/qmf/qml/apps/thermostat/lang/lang_nl_BE.qm'...
Generated 90 translation(s) (90 finished and 0 unfinished)
Updating '/qmf/qml/apps/thermostat/lang/lang_en_GB.qm'...
Generated 91 translation(s) (91 finished and 0 unfinished)
Ignored 1 untranslated source text(s)
Updating '/qmf/qml/apps/thermostat/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/thermostatSettings/lang/lang_de_DE.qm'...
Generated 89 translation(s) (89 finished and 0 unfinished)
Updating '/qmf/qml/apps/thermostatSettings/lang/lang_es_ES.qm'...
Generated 81 translation(s) (81 finished and 0 unfinished)
Ignored 34 untranslated source text(s)
Updating '/qmf/qml/apps/thermostatSettings/lang/lang_fr_BE.qm'...
Updating '/qmf/qml/apps/thermostatSettings/lang/lang_nl_NL.qm'...
Generated 112 translation(s) (112 finished and 0 unfinished)
Ignored 3 untranslated source text(s)
Updating '/qmf/qml/apps/thermostatSettings/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/thermostatSettings/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/thermostatSettings/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/installWizard/lang/lang_de_DE.qm'...
Generated 7 translation(s) (7 finished and 0 unfinished)
Updating '/qmf/qml/apps/installWizard/lang/lang_es_ES.qm'...
Updating '/qmf/qml/apps/installWizard/lang/lang_fr_BE.qm'...
Updating '/qmf/qml/apps/installWizard/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/installWizard/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/installWizard/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/installWizard/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/settings/lang/lang_de_DE.qm'...
Generated 3 translation(s) (3 finished and 0 unfinished)
Updating '/qmf/qml/apps/settings/lang/lang_es_ES.qm'...
Updating '/qmf/qml/apps/settings/lang/lang_fr_BE.qm'...
Updating '/qmf/qml/apps/settings/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/settings/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/settings/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/settings/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/controlPanel/lang/lang_de_DE.qm'...
Generated 204 translation(s) (204 finished and 0 unfinished)
Ignored 31 untranslated source text(s)
Updating '/qmf/qml/apps/controlPanel/lang/lang_es_ES.qm'...
Generated 191 translation(s) (191 finished and 0 unfinished)
Ignored 44 untranslated source text(s)
Updating '/qmf/qml/apps/controlPanel/lang/lang_fr_BE.qm'...
Updating '/qmf/qml/apps/controlPanel/lang/lang_nl_NL.qm'...
Generated 235 translation(s) (235 finished and 0 unfinished)
Updating '/qmf/qml/apps/controlPanel/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/controlPanel/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/controlPanel/lang/lang_fr_FR.qm'...
Generated 193 translation(s) (193 finished and 0 unfinished)
Ignored 42 untranslated source text(s)
Updating '/qmf/qml/apps/eMetersSettings/lang/lang_de_DE.qm'...
Generated 271 translation(s) (271 finished and 0 unfinished)
Updating '/qmf/qml/apps/eMetersSettings/lang/lang_es_ES.qm'...
Generated 278 translation(s) (278 finished and 0 unfinished)
Updating '/qmf/qml/apps/eMetersSettings/lang/lang_fr_BE.qm'...
Generated 272 translation(s) (272 finished and 0 unfinished)
Updating '/qmf/qml/apps/eMetersSettings/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/eMetersSettings/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/eMetersSettings/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/eMetersSettings/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/strvSettings/lang/lang_de_DE.qm'...
Generated 140 translation(s) (140 finished and 0 unfinished)
Updating '/qmf/qml/apps/strvSettings/lang/lang_es_ES.qm'...
Updating '/qmf/qml/apps/strvSettings/lang/lang_fr_BE.qm'...
Updating '/qmf/qml/apps/strvSettings/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/strvSettings/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/strvSettings/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/strvSettings/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/solar/lang/lang_de_DE.qm'...
Updating '/qmf/qml/apps/solar/lang/lang_es_ES.qm'...
Updating '/qmf/qml/apps/solar/lang/lang_fr_BE.qm'...
Updating '/qmf/qml/apps/solar/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/solar/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/solar/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/solar/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/benchmark/lang/lang_de_DE.qm'...
Generated 208 translation(s) (208 finished and 0 unfinished)
Updating '/qmf/qml/apps/benchmark/lang/lang_es_ES.qm'...
Updating '/qmf/qml/apps/benchmark/lang/lang_fr_BE.qm'...
Updating '/qmf/qml/apps/benchmark/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/benchmark/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/benchmark/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/benchmark/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/systemSettings/lang/lang_de_DE.qm'...
Generated 164 translation(s) (164 finished and 0 unfinished)
Updating '/qmf/qml/apps/systemSettings/lang/lang_es_ES.qm'...
Updating '/qmf/qml/apps/systemSettings/lang/lang_fr_BE.qm'...
Updating '/qmf/qml/apps/systemSettings/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/systemSettings/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/systemSettings/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/systemSettings/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/heatRecovery/lang/lang_de_DE.qm'...
Generated 29 translation(s) (29 finished and 0 unfinished)
Updating '/qmf/qml/apps/heatRecovery/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/graph/lang/lang_de_DE.qm'...
Updating '/qmf/qml/apps/graph/lang/lang_es_ES.qm'...
Updating '/qmf/qml/apps/graph/lang/lang_fr_BE.qm'...
Updating '/qmf/qml/apps/graph/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/graph/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/graph/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/graph/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/airQuality/lang/lang_de_DE.qm'...
Generated 33 translation(s) (33 finished and 0 unfinished)
Updating '/qmf/qml/apps/airQuality/lang/lang_es_ES.qm'...
Updating '/qmf/qml/apps/airQuality/lang/lang_fr_BE.qm'...
Updating '/qmf/qml/apps/airQuality/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/airQuality/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/airQuality/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/airQuality/lang/lang_fr_FR.qm'...
Tenant symlink is now:
lrwxrwxrwx 1 root root 21 Apr 10 10:48 /qmf/var/tenantdir -> /qmf/tenants/eneco-nl
But results stay the same tenant is not changing
output /usr/sbin/openvpn --config /etc/openvpn/vpn.conf
Sun Apr 10 10:56:21 2022 OpenVPN 2.3.6 arm-angelica-linux-gnueabi [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Oct 18 2017
Sun Apr 10 10:56:21 2022 library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.09
Sun Apr 10 10:56:21 2022 WARNING: file '/etc/openvpn/certs/device.key' is group or others accessible
Sun Apr 10 10:56:21 2022 Control Channel Authentication: using '/etc/openvpn/certs/ta.key' as a OpenVPN static key file
Sun Apr 10 10:56:21 2022 RESOLVE: Cannot resolve host address: vpn.qutility.quby.com: Name or service not known
Sun Apr 10 10:56:26 2022 RESOLVE: Cannot resolve host address: vpn.qutility.quby.com: Name or service not known
^CSun Apr 10 10:56:28 2022 RESOLVE: signal received during DNS resolution attempt
Sun Apr 10 10:56:28 2022 SIGINT[hard,init_instance] received, process exiting
Also renamed qmf-tenant.xml to see if a new .xml would be created but unfortnately it doesn't
Posted: Sun Apr 10, 2022 1:57 pm
by WickedMaster
/etc/openvpn/vpn_port.conf contains the VPN-server hostname. You can try to change that one manually.
Example vpn_port.conf:
remote vpn.eneco.toon.eu
remote-cert-tls server
port 443
dev tap0
connect-retry 63
route-metric 1024
Don't forget to restart the Toon after changing the VPN-config.
Posted: Sun Apr 10, 2022 3:20 pm
by TheHogNL
That file should be automatically filled with the correct vpn hostname (hcb_config process i believe).
Did you restart after changing the tenant?
Also, normally changing the tenant isn't supported without factory reset so maybe you need a factory reset for that.
Posted: Sun Apr 10, 2022 6:23 pm
by DennisD
WickedMaster wrote: ↑Sun Apr 10, 2022 1:57 pm
port 443
dev tap0
connect-retry 63
route-metric 1024
Won't stick, after reboot it changes to vpn.qutility.quby.com
TheHogNL wrote: ↑Sun Apr 10, 2022 3:20 pm
I did a reboot but didn't stick either, just tried a factory reset but tenant remains unchanged, must i complete the install wizard before running the tenant script or only wifi to ssh into the toon?
Posted: Sun Apr 10, 2022 10:47 pm
by DennisD
Finally managed to upgrade. I used both the manual adjustment of the vpn_port.conf file and the change tentant script, but without rebooting. Maybe a little risky but it worked, added bonus is that the tenant and vpn is now correct for future upgrades.
Thanks guys
