Using the appropriate led controller it is possible to adjust the brightness of the led without any flickering effect. Not all led controllers are capable for led dimming; proper dimming for led lighting (avoiding led colour shift) can only be done by pulse width modulation based controllers.
LT-SYSTEM-3600RC is a full colour multifunctional rgb led controller based on PWM technology and designed to control colour changing combinations of LED strip lighting with 4-pin 3-loop cables (common anode). It can be adjusted through manual buttons or matching remote control device. Also this unit can run as a standalone controller or linked with an rgb amplifier which can unlimitedly expand its capabilities.
http://www.hiline-lighting.com/pd-dimma ... roller.cfm
Dimmable wireless LED RGB controller
I thought it was a wireless Lan version!
But is wireless the remote with the antenna?
How is the remote operating on which frequency 433mhz?
This is actually a Radio frequency (RF) dimmable RGB led controller (Version 2+); operating frequency is 433Mhz. It is a constant voltage led controller and can operate from 5 to 24V DC (6A/CH).
We will soon have ready to ship version 3.00 of this controller (will be shown into our website and will replace V2+).
More details for the new version (PDF format) can be found at:
http://www.hiline-lighting.com/files/LT ... 0RC-V3.pdf
Note: Similar dimmable led controller (led dimmer) already available for single color led applications; for more info please check out the following link:
http://www.hiline-lighting.com/pd-wirel ... dimmer.cfm
